Thread Tools
Old 14th April 2006, 23:12   #1 (permalink)
twister's Avatar
Default converting a FWD to a RWD....POSSIBLE?
hi!!!
is it possible to convert a Front Wheel Drive system into a Rear Wheel Drive by any sort of modification ??
if yes,then how??n how much wud it cost?? n and will it be fruitful or just a waste of time,money n energy??
PS - im not talking about any particular car,just consider a chassis with an engine mounted in the front,delivering power to the front wheels.
thanx
__________________
Remember kids, if you happen to find yourself upside down and on fire, you've just discovered the meaning of "too fast".
twister is offline   Reply With Quote
Old 14th April 2006, 23:23   #2 (permalink)
revharder's Avatar
it'll give serious problems in handling and performance.
better not to try this.
revharder is offline   Reply With Quote
Old 15th April 2006, 00:40   #3 (permalink)
2fast4u's Avatar
this will be a unique creation as never seen Cross engine with RWD - maybe some exist but i am ignorant on that. practically its gonna be very hard to get the engine turning wheels if its in cross position may have to change to Inline, i suppose.
__________________
332kmph 1999 unrestricted GSXR1300R
ROYAL ENFIELD MACHISMO 1992
636
RB20DET NISSAN
2fast4u is offline   Reply With Quote
Old 15th April 2006, 08:29   #4 (permalink)
viper's Avatar
It is definitely possible but will require extensive modifications depending on what the base car is.
Viper
__________________
NO ONE DARES COME CLOSE
viper is offline   Reply With Quote
Old 15th April 2006, 11:58   #5 (permalink)
BUSA's Avatar
Wink
Viper can you please tell us the cost and the time it will take to be done. Lets take the base car as the Octavia RS as thats one machine which can have 400bhp but requires RWD as it torque steers. Also let us know can a FWD be converted to AWD and its cost as well. Again taking base car as Octavia RS.
__________________
thecarsandmore.blogspot. com
Old 15th April 2006, 12:54   #6 (permalink)
viper's Avatar
Busa,
If and when you do want to get it done give me a call. I do not talk shop on TBHP.
Viper
__________________
Old 15th April 2006, 13:31   #7 (permalink)
humyum's Avatar
Yes dude..u can convert a front wheel drive to rear wheel drive..take for example a maruti 800...u can change the direction of the engine...nd fix it like the omnis engine is fixed(same engine..different positions)..nd then fix the omnis gear box,propeller shaft,live axle..but u ll need to raise the suspension of the maruti 800..for that..otherwise the propeller shaft will end up touchin speed breakers..nd breakin...
__________________
Its not the age,Its the mileage
Old 15th April 2006, 19:36   #8 (permalink)
Team-BHP Moderator
Mpower's Avatar
Octy is easiest, just get the HALDEX parts from the GOLF 4 motion, bolt on and drive away.
__________________
The difference between the men and the boys....................is the speed of their toys.
Old 17th April 2006, 12:42   #9 (permalink)
sbasak's Avatar
It is often possible.
You may observed that even FWD cars have transmission tunnels inside the car.
So the tranmission shaft can be carried to rear differential, if required.
However, most probably the cost will not justify it.
__________________
Life is a math which you need to solve without knowing the answer!
sbasak is offline   Reply With Quote
Old 17th April 2006, 22:13   #10 (permalink)
twister's Avatar
can ne`1 please direct me to some website where i can get full information regarding the same conversion in DETAIL please???
__________________
Old 18th April 2006, 04:46   #11 (permalink)
Team-BHP Moderator
Mpower's Avatar
If you have no particular car in mind, then how do you expect to find a detail plan to convert it to RWD.
__________________
Old 18th April 2006, 23:26   #12 (permalink)
twister's Avatar
@ mpower :- okay,lets take the OHC 1.5 into consideration....remove the whole body structure...every single thing....so now we are left with just the engine , chassis and the wheels...okay? (like,the way all the new busses ,autos n blah blah come) now i want the engine to turn the rear wheels instead of the front ones......for that we have two options
1) remount the engine (90* flip) + put a differential at the bakk ,connect it to the engine wit a long shaft....and make the rear wheels turn
2) place the engine @ the bakk and make it turn the rear wheels like it does the front ones
** is it possible to mount the engine at the bakk by creating new mounting points???
i just want to know the whole concept very CLEARLY in detail...please help
thnx
__________________
Old 19th April 2006, 03:52   #13 (permalink)
Team-BHP Moderator
Rehaan's Avatar
If you really want to get creative (since you have mentioned option 2), then you could leave the engine as is and have a chain driven rear axle
cya
R
Old 19th April 2006, 14:59   #14 (permalink)
veyron1's Avatar
@twister; NO, it is not possible to convert a OHC to a RWD as you mentioned. the only POSSIBLE way is to mount the engine at the rear- but the expense or cost of doing that might exceed the cost of the car itself, by "x" times- no to mention the mechanical complexity, and the fact that the car could be virtually undriveable under daily conditions.
secondly, the chassis of the OHC is not designed for taking RWD mods- the frame is monocoque, so no "stripping" the body and doing the mods; the entire body IS THE CHASSIS.
thirdly, the tunnels that you see in FWD cars do not have clearance to accomodate a propeller shaft. the tunnel is designed for frame/chassis rigidity, nothing else.
four; twister, if you REALLY wanna wonder about the RWD conversion, try this; the honda cr-v has a transverse mounted engine with part-time 4wd. instead of mounting the engine longitudinally, start wondering about RWD/4wd with transverse mounting, which has a better probability of success. like Mpower mentioned, the vRS can be converted to AWD using the haldex kit- maintaining transverse engine mounting. BUT, i do not see any significant gains from the conversion; the haldex AWD design is heavily dependent upon electronics, isn't it? and the tractional gain would not be significant- unless the distribution can be split upto 80:20, biasing rear. ah, and at least 300 bhp for putting that AWD to use.
__________________
DAD
veyron1 is offline   Reply With Quote
Old 20th April 2006, 03:27   #15 (permalink)
Team-BHP Moderator
Mpower's Avatar
Veryron, you're almost there....but you can still pull off a RWD.
So take a CRV, trans bolt it on to the OHC engine, remove the front halfshafts. Lock the front diff, short circuit the visous coupling in the back, and you have a RWD OHC. Of course, you have to fabricate a rear cross member to mount the diff and the lateral arms and relocate the exhuast/cats from the tunnel to make way for the prop shaft. Also need new wheel hubs and uprights in the rear. CRV trans has what is called a PTO.
Option 2 is midengine.......basically you have to cut a BIG hole inthe floor pan where your rear seat and fuel tank reside. You will lose a lot of torsional stiffness! Fab a couple of longitudinal chassis rails that run from the B-pillar to the rear strut tower........so that you can hang the engine, new shifter linkage, new fuel tank location, new rear cross member/engine cradle and you are good to go.
Now if you want N-S engine, then it gets interesting and complicated. You have to extend the front chassis rails by 6 -10 inches and relocate the radiator/condensor etc. Drill into the engine block to fit the mounts fabricate a new mount on the rail. Find a RWD trans from another RWD car (say Versa). Mate it to the engine, design a new shifter linkage for it.......pray like hell that it wont hit the tunnel........but sadly it will.........so you cut the tunnel and open it up.........pray like hell that the clutch pedal will still fit. (now you know why you cant drive a Miata with snow boots) Now repeat all the steps I mentioned regarding rear K-member in option 1. Now you still need new body work, longer hood and fenders and your car will look and behave nose heavy. OHC hoodline is really low, so you're gonna have to put a bulge on the hood to clear the timing cover. Now you know why RWD cars have long hoods.
So, there you go.....in the order of difficulty and ...........insanity. Now tell me how much money you have in the bank?
__________________
Thread Tools
How to Drift on a FWD car ? slipstream Shifting gears 44 19th February 2008 06:31
Can you feel FWD or RWD difference while driving? sbasak Technical Stuff 66 12th November 2007 21:05
RWD, FWD, AWD-what would you choose? nitroxx Shifting gears 19 15th March 2007 04:48
Y-U-C-K. The Indian Audi A6 is FWD only! GTO The Indian Car Scene!! 32 7th May 2005 13:42
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445
