Thread Tools
Old 15th April 2006, 02:25   #1 (permalink)
v.tec's Avatar
Default fuel tank 42lt.- fuel in-44lt.
well today..the weirdest thing happened..
i as usual..had gone to get my honda city's tank full..from BP..
assuming the FE my car is giving me..i still had around 3-4 litres left in the tank
so as usual..was gettin speed filled in.. and the auto cut mechanism worked at around 40.5 litres..and im like woah..i just had 1.5 litres left or something..then i told him to fill it up.after 15 seconds i looked up and saw the gauge at 44 and still counting!!!!!
and im like what the......!?!?!! i told him to stop immediately and asked him how its possible as my tank is only 42 litres..!! he didnt say anything..i said i want to check the accuracy of the pump..he showed me..and it was correct..so all i could do was pay the money and leave..but then how the hell did this happen?!!?!?!
v.tec is offline   Reply With Quote
Old 15th April 2006, 02:32   #2 (permalink)
panky12345's Avatar
boss, which pump was that ? plz share so that we wd b careful!
Old 15th April 2006, 02:41   #3 (permalink)
v.tec's Avatar
the one near archana, gk1..near moolchand flyover..im a regular customer there though..!
Old 15th April 2006, 04:43   #4 (permalink)
SLK
SLK's Avatar
Is it the same pump owned by Shell.... but it supplies BP?
That is a fine pump!... but its a very fast one!... .. my tank takes 28-29 ltr... within a minute.
Normally.. cars can take... 1-2ltrs extra... i.e. in the pipe that leads to the tank. But it is very difficult.... and takes a lot of effort.
1) you had no fuel .. and tank was completely empty.
2) no air inside!
__________________
Č╠╣€€Я$
$£Қ
SLK is offline   Reply With Quote
Old 15th April 2006, 09:34   #5 (permalink)
cheap_deal's Avatar
you say you checked the "accuracy of the pump". how did you do this? i smell something fishy going on at that pump.
cheap_deal is offline   Reply With Quote
Old 15th April 2006, 10:09   #6 (permalink)
aZa
aZa's Avatar
Oye VTEC this is definatly fishy ... and how did u check the accuracy of the pump ?
__________________
-[ " If the ride is more fly, then you must buy. " - Snoop Dogg ]-
Old 15th April 2006, 11:22   #7 (permalink)
iraghava's Avatar
All pumps have a measuring beaker in which if you ask to test the accuracy they will fill petrol infront of you to show you that the pump is dispensing the correct amount of fuel. The beaker has markings on it to show how much fuel is being pumped out.
As for that pump I think it is one of the most trusted and finest pumps in Delhi. I regularly go there to fill Petrol & get my car washed.
__________________
There is a very fine line between "Hobby" and "Mental Illness".
iraghava is online now   Reply With Quote
Old 15th April 2006, 11:28   #8 (permalink)
revharder's Avatar
it is not unusual for a tank to contain another 3-4 ltrs of petrol even after that auto-stop of dispensing nozzle.
revharder is offline   Reply With Quote
Old 15th April 2006, 13:22   #9 (permalink)
v.tec's Avatar
2) no air inside!
i very much had atleast 3-4 litres left...and that guy had gone on and on filling..i stopped him..otherwise i'm sure he must have put in a few more litres..
@ SLK : no its not the one owned by shell...that ones at the beginning of the moolchand flyover..
@iraghava : yeah i trusted that pump too..we get our petrol from only two pumps..around gk.. either this or another one in nehru place..that too being BP
yeah he did do it the way iraghava said..got a beaker and told me its 5 litres..and it came at exactly the same amount
@revharder : yeah you're right about that..but then that means the auto cut should have cut in around 38... and not at 40.5 and then moving on another 4 litres lol..
Old 15th April 2006, 14:21   #10 (permalink)
revharder's Avatar
there is no hard and fast rule of auto-stop of dispenser to cut at some exact level. sometimes it cuts even when tank is half full (or half empty!).
try closing the door (near to filler) a bit hardly , while petrol is filling; it might get auto-stopped.
so donot take that auto-cut as some point of measurement!
Old 15th April 2006, 14:33   #11 (permalink)
jesal's Avatar
Infractions: 0/2 (10)
does the nhc have a 45 liter tank right. i fill it up as soon as the reserve comes in. though when i start filling not more than 30 - 35 goes in so the reserve is 10 litres ?
__________________
Јєşåł Åŕỳā
Modifying Gone Mental
jesal is offline   Reply With Quote
Old 15th April 2006, 14:35   #12 (permalink)
v.tec's Avatar
@ jesal..
i know about nhc zx .. which has a tank of 42 litres.. reserve is 8 litres..
Old 15th April 2006, 15:33   #13 (permalink)
Vtec, what time of the day did you fill up? Many a times you would notice a 5 lit. plastic oil can kept next to the dispenser. On most occassions you will find that it contains fuel rather than oil. What these guys do is, empty the fuel in the hose into these cans. so when they fill your car and since the gun is inside the tank inlet you won't be able to see that for quite some time the fuel would not have actually come out of the gun, enevthough the pump shows the running numbers. They do this only with people who fill their tanks
I don't think this could have happened in your case because you claim that this is quite a reputed outlet.
So long....
varunroy is offline   Reply With Quote
Old 15th April 2006, 15:35   #14 (permalink)
Some time back in Mumbai there was a series of scams being exposed by PPs. One trick was to hold the nozzle lever at some half way point. Then the petrol would be slower to fill but the meter would be faster.
Newspapers also carried this in great details.
Whenever I go to a PP I ask the attendent to leave his hands free of the lever and stand clear. Do this the next time and see if this could have been the reason why this happened.
Venkat
__________________
Venkat, 48, Mumbai
Love to travel by Road.
Venkat is offline   Reply With Quote
Old 15th April 2006, 20:36   #15 (permalink)
Team-BHP Moderator
Zappo's Avatar
Yaar, do not get so overworked on this issue. If this pump is a really trusted one then their could also be a lot more things involved. On thing is that although the tank has a prescribed size that does not really mean it will fill up exactly till that much and then start overflowing. The tank has lot of twists and turns to fit around the car body. This makes it take more fuel at times. To see an analogy try filling up a 10 or 15 liter jerrican the next time. You will see that you can even fill up the hollow of the grip of this jerrican and then fill it up to the brim and it will easily take in 1 or 1.5 ltrs more. Besides that there are pipes/hoses running from the fuel tank which can add up the capacity by another few liters.
After all these, now consider at what time of the day did you go to fill up? Depending on the atmospheric temperature and also the pressure the fuel density can increase or decrease. This may result in more or less fuel going in for the same units displayed by the pump. Have you heard of the suggestions to fill up early in the morning or late at nights? That is because you stand to get more for the same unit of fuel pumped in.
__________________
Announcements are important.
  • Read the Advertising Announcement here.
  • Classifieds section has its rules. Read here.
Zappo is offline   Reply With Quote
Thread Tools
How do you refill your fuel tank? Which is the best practice? souravbasu Technical Stuff 77 17th July 2008 18:05
Fuel tank capacity measurement, how? giri Technical Stuff 36 5th September 2007 19:08
Location of the fuel tank lid? mohit333 Technical Stuff 4 23rd July 2007 02:44
Santro fuel tank and siphoning johy Technical Stuff 6 22nd April 2006 19:28
can the fuel tank capacity be increased speedsatya Modifications & Accessories 3 28th May 2004 19:22
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
