| LinkBack | Thread Tools | Search this Thread |
| | #16 | |
| Senior - BHPian Join Date: Oct 2008 Location: Punya Nagari
Thanked: 210 Times
| Quote:
Yes, Fiat already uses or at least strongly recommends synthetic. They use Selenia 5W-40. Here's an interesting thread for Fiat India car owners - http://www.****************/pre-serv...nterval-4.html Sorry guys - this link is being masked for some reason.it is teamfiat dot co dot in pre-service-query/822-engine-oil-change-interval-4.html Mods - is this default behaviour or is it related to this particular Fiat related site? Last edited by R2D2 : 19th July 2012 at 18:58. Reason: Strange Behavior? - Link being masked | |
| | #17 | |
| Team-BHP Support ![]() | Quote:
Maruti licensed the 1.3L Multijet engine from Fiat and used it for its cars that include Swift, DZire, SX4 amongst others. Maruti manufactured these engines under license at its own facility in Manesar. The demand v/s supply from this factory wasn't adequate and resulted in long waiting periods for their diesel range of cars. Maruti therefore roped in Fiat powertrain pvt. ltd. to manufacture the 1.3L Multijet engines for them to meet demands while it expands its engine production capacity in parallel. This could be a stop gap arrangement and Maruti would eventually insource engine manufacturing when it is able to meet demand. Now, coming back to the point of engine oil specifications, engines manufactured by Maruti Suzuki Powertrain (or whatever it is called), specified mineral oil for replacement and that is how it has been with my Swift. At the same time, engines manufactured by Fiat Powertrain specify synthetic oil for replacement. As a Japanese company that heavily implements strict processes that seldom deviate from standard I believe they wanted to eliminate any confusion or customization for different sets of engines. Imagine the failure points at service station level if the service advisors were given the task of identifying the engine oil specification based on VIN plates. To avoid this they standardized the specification. This is just my belief and I could be wrong. ![]() | |
| | (2)
| | #18 | |
| BHPian Join Date: Jul 2007 Location: Delhi
Thanked: 12 Times
| Quote:
I purchased this car in July 2012, i am really confused shall is this with Mineral Oil or Synthetic oil. The dealer is insisting that it is synthetic oil and oil change will be done at 10,000 kms. I am not sure, this is true or not as the owners booklets say replace oil at 1,000 kms Would appreciate inputs | |
| | #19 |
| Distinguished - BHPian ![]() Join Date: Dec 2007 Location: Kanpur
Thanked: 1,192 Times
| 5W50 will be a synthetic, while 20W50 can be a mineral or at most semi-synth. The cost difference will be 3x minimum.So naturally the former is far more pervasive. With more and more cars having hydraulic tappets I can see the trend to switch towards thinner (when cold) oils. Modern engines are quite happy with SAE40 (or even SAE30) so maybe there is no need to go for a SAE50 limit. Last edited by sgiitk : 6th August 2012 at 15:32. |
| | #20 | |
| BHPian Join Date: Nov 2007 Location: Bangalore-Kollam-Trivandrum
| Quote:
You can run your car on any superior quality material, for example using a formula one Tyre will not harm your car any way but will increase the ride quality. So its you who need to decide what is appropriate for you car after referring to the standard recommendations from the manufacturer. I know many people who run their car on synthetic engine oils and iridium spark plugs even though their cars manufacturer does not recommend that or their vehicles are not used in extreme conditions. They use it just because of some recommendations or by referring to some enthusiast who use it for some specific purpose. I would say you can adhere to the recommendations from the manufacturer unless you feel like you are stretching the performance of the car. If your owners booklets say replace oil with mineral oil at 10K Kms then go with that. | |
| | #21 | |
Thanked: 12 Times
| Quote:
Its a Diesel model not petrol. So i am really not sure... whether the manufactured has put mineral oil or synthetic oil. In case its a mineral oil, i don't want to swtich to synthetic too soon. Amit | |
| | #22 | |
| Quote:
Even I too don't recommend changing to synthetic if your vehicle came filled with Mineral Oil from the company. | |
| | #23 | |
Thanked: 12 Times
| Quote:
If its mineral, then i need to change that with Mineral oil at 1,000 oil. | |
| | #24 | |
| BHPian Join Date: Aug 2009 Location: Bangalore, Cochin
Thanked: 17 Times
| Quote:
Mine is a March 2012 swift and the manual clearly says first oil change at 10k and service intervals of 10000k thereafter. The recommended oil is 5W4, and I don't think I have an option to change it to mineral one. | |
Similar Threads | ||||
| Engine Oil Change - Synthetics or Minerals? | sparkglow | Technical Stuff | 21 | 18th May 2013 18:22 |
| Engine Oil Change : Paid Service vs Buying Oil yourself vs Full DIY | neosmart | Technical Stuff | 58 | 14th May 2013 14:15 |
| New A.S.S SCAM - compulsory engine flush with oil change. | UniqueMods | Technical Stuff | 26 | 6th March 2013 16:25 |
| Swift Vdi oil change - DIY | shibujp | Technical Stuff | 15 | 20th February 2013 10:02 |
| Engine oil change at 5000 or 10000kms? | rajivanoj | Technical Stuff | 149 | 20th February 2011 09:59 |
