| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: Apr 2006 Location: bangalaore
| i have an complete externally modded esteem,stereo n a free flow. plannin to start engine work ,so i wanted to know what the possibilities are and what exactly my 1.3l engine could do after complete tuning and modification . and should i consider an engine swap with a baleno or vtec or somethin . dont plan on turning it into a drag car,just a street car with good acceleration . . please help !! |
| | #2 (permalink) |
| Senior - BHPian | well a good porting & polishing job courtesy our in-house pyscho and say a conical filter, you existing free flow and a tune up should give you that mild kick that you need. if you were yet using the carb version, i would maybe suggest a swap to a baleno engine, even in stock form the car would be so much faster. manson.
__________________ Robin |
| | #3 (permalink) |
| Senior - BHPian | Well if u are looking at just a street car then i sincerely suggest u contact psycho .. He specializes with the esteems .. A lot of members like anush , aditya , godfather , amitoj have gone out really satisfied ..
__________________ I am proud of you, binzy boy !!! Keep up the good work. |
| | #4 (permalink) | |
| Senior - BHPian | Quote:
__________________ I accidentally installed the deer whistles on my car backwards. Now everywhere I go, I'm chased by a herd of deer. | |
| | #6 (permalink) |
| BHPian Join Date: Nov 2004 Location: India-Mumbai-Colaba
| hey buddy..ive done esteem's myself..it is a superb car if your lookin for street speed..well the basic mods should bring a noticable change..just drop in a 4" conical filter and a 4x2x1 header (which you already have) upgrade the plugs,ignition wires,msd blaster coil 2,the esteem has a flat spot in the 4th and 5th gear..after such high speeds it tends to just die out in the 4th and 5th..you could use an after market fuel pressure regulator(FSE),high lift camshaft's and a head facing,porting polishing job should get you a beautiful fast ride,also make sure you get strut braces designed for the car..2 for the front upper and lower and one for the back,this gives amazing stability to the car and at high speeds there's very minimum body roll and flex once you have all this sorted you should have a more than fast street car..if you do need any other info please feel free to pm me..cheers..happy revvin...!
__________________ oVaBoosT - Performance Unleashed...!! |
| | #7 (permalink) | |
| BHPian | Quote:
| Thread Tools | |
Similar Threads | ||||
| Turbo? NOS? Engine Swap? High CR NA build? How would you modify your engine? | mclaren1885 | Modifications & Accessories | 50 | 26th March 2008 10:55 |
| Safari TCIC 2.0 Engine swap with 3.0L DICOR Engine | gd1418 | Modifications & Accessories | 17 | 18th November 2007 20:16 |
| innova engine swap possible? | neo_trace | Modifications & Accessories | 20 | 1st October 2007 23:18 |
| Palio Engine Swap | BUSA | Modifications & Accessories | 20 | 25th January 2007 11:15 |
| Engine Swap | Maverick3136 | Modifications & Accessories | 1 | 8th October 2004 08:16 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
