Thread Tools
Old 20th April 2006, 20:31   #1 (permalink)
johy's Avatar
Default Santro fuel tank and siphoning
Hi all,
Where is the fuel tank of the Santro located? Secondly, is it possible to siphon off petrol from the Santro..like a dishonest driver might do...is that possible? If yes, how?
johy is offline   Reply With Quote
Old 20th April 2006, 21:41   #2 (permalink)
aZa
aZa's Avatar
U can take out petrol from the fuel line in the bonnet ... i saw one of my drivers do that ... i switched on the engine and took out one pipe the petrol was ooozing out like a tap ... uff
__________________
-[ " If the ride is more fly, then you must buy. " - Snoop Dogg ]-
Old 20th April 2006, 21:42   #3 (permalink)
Rehaan's Avatar
Hi Johy,
It is very much possible.
One way is for the driver to make friends with the attendant at the petrol pump, tell him to fill less than the amount acounted for on paper, and the dishonest driver then gives him a cut of the money that he just "made".
Another way is to open the fuel tank, slide a pipe in, and suck (siphon) the fuel out till it passes the crest of the bend in the tube and drops below the level of fuel in the tank and then capillary action takes over and the fuel keeps pouring out.
The third way is as aZa mentioned, but is usually more work and more obvious than the others.
Read this thread (Petrol Telgi?) about drivers stealing fuel on a large scale in bangalore.
cya
R
Old 21st April 2006, 01:34   #4 (permalink)
v1p3r's Avatar
Hey Rehaan, this isn't really possible with the newer generation of cars.
EDIT: seems the scam was on in Mumbai...
__________________
I've lost my phone. Please PM me your phone number if I'm on your contact list.
Old 22nd April 2006, 07:29   #5 (permalink)
johy's Avatar
R
Hi Rehaan and V1p3r,
So this method of siphoning is not possible with the new-generation cars like Santro?
Old 22nd April 2006, 11:00   #6 (permalink)
Rehaan's Avatar
Hey v1p3r,
Whats the reason you say that?
I guess hindsight is 20/20 but memory is not!
Where theres a will theres a way! Think of a smart way to catch your driver!
cya
R
Old 22nd April 2006, 19:28   #7 (permalink)
pramodkumar's Avatar
It is quit easy to take fuel out from the old carb engine but from the new mpfi engine then it is quite difficult to take petrol out. There is a way to catch your culprit driver if you exactly know your cars average. Top up your tank start meater from zero after 2-3 days again top it up and see if the milage matches with your data.
Thread Tools
Fuel Tank cleaning amitk26 Technical Stuff 7 14th September 2008 16:42
How do you refill your fuel tank? Which is the best practice? souravbasu Technical Stuff 77 17th July 2008 18:05
Fuel tank capacity measurement, how? giri Technical Stuff 36 5th September 2007 19:08
fuel tank 42lt.- fuel in-44lt. v.tec Technical Stuff 55 29th August 2006 20:50
can the fuel tank capacity be increased speedsatya Modifications & Accessories 3 28th May 2004 19:22
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459
