Old 21st April 2006, 18:15   #1
Thanked: 76 Times
Default Change in mileage and Handling
I own a Indica 2004 V2 diesel and i recently changed to Alloy wheels. After the change i face the following issues.
  1. My mileage dropped from 15.5 KMPL to 13.5 KMPL.
  2. My steering wheel starts vibrating at 100KMPH, which peviously was doing 120KMPH without any issue.
Is this because of Alloy wheels? If so what should i do to fix these issues.
msk_kapoor is offline   Reply With Quote
Old 21st April 2006, 18:22   #2
aZa
aZa's Avatar
Thanked: 17 Times
tell us more bout ur tyres ?
Get balancing and Alignment done, this should correct most of the problems
Old 21st April 2006, 18:27   #3
ksethuram's Avatar
Get balancing and Alignment done as aZa said. Also check the air pressure in the tyres.
Also tell us more whether it is tube/tubeless, size and make.
ksethuram is offline   Reply With Quote
Old 21st April 2006, 18:40   #4
extreme_torque's Avatar
Thanked: 1,489 Times
The alloy dealer might have given you a damaged piece... check your alloy wheels also when going for alignment n stuff.
extreme_torque is offline   Reply With Quote
Old 22nd April 2006, 23:23   #5
Kaizer Sozay's Avatar
Did you change your Tyres also, coz if you have changed the profile it will have a difference on the FE. Get your wheel balancing done also
Kaizer Sozay is offline   Reply With Quote
Old 23rd April 2006, 21:03   #6
Thanked: 157 Times
After doing the alignment and balancing...if you still need help then there is another thread on this forum about "Hub Centric rings" ...getting one custome made for your wheels should iron out matters
Buffetfan is offline   Reply With Quote
Old 23rd April 2006, 22:34   #7
drifter's Avatar
Solution to your vibration issues.
http://www.team-bhp.com/forum/tyre-a...oy-wheels.html (Solution for vibrations after installing alloy wheels)
As far as mileage issues are concerned...the FE should not see any difference if the new tyres were of the same size as the original ones.
Drifter
drifter is offline   Reply With Quote
Mileage labels on cars soon; 10L fine for violation of mileage standards coolclouds The Indian Car Scene 22 14th June 2012 15:13
Which hatch back has best suspension and road handling bill1182 The Indian Car Scene 96 13th July 2011 17:52
Help::Alloys on zen, performance and mileage change? ~~VinZ~~ Tyre & Alloy wheel Section 61 1st May 2011 10:45
5.5 lac budget. Best in-class acceleration and handling? senthildsk Sedans 57 5th August 2006 23:55
power v/s chassis and the importance of handling normally_crazy Technical Stuff 17 8th March 2006 20:51
