Old 24th August 2016, 18:20   #46
Thanked: 7 Times
Default Re: Fiat Linea 1.3L MJD - Timing Chain
I called up FASS Manager to ask about an intermittent TRDP error in Linea 1.4 petrol and on asking told him that the car has run 48k km. He dismissed the TRDP error saying that is minor and can be checked with their analyser but told me to get the timing chain replaced - he says it must be replaced at 60k or 5 years whichever is earlier. He told me it will cost approx Rs 5k. I see Rs 10k and other figures mentioned at various places which vary quite a lot - so how much does it really cost for a petrol Linea?
Also, since the car has not run much and is used sparingly, can the condition of the timing chain be checked before deciding to do a replacement - through any tell tale signs etc.?
I believe it is much cheaper if done outside FASS. Does anyone know anyone outside FASS who does it? I read somewhere on the forum about Batra in Lajpat Nagar who is very experienced in replacing timing chains.
Tarrodie is offline   Reply With Quote
Old 24th August 2016, 20:24   #47
h14
h14's Avatar
Thanked: 1,531 Times
The reason why the cost differs is since yours is a petrol and the petrol engine equips a timing belt and not a chain. To put it simple, belts are cheaper than chain.
5 yrs is decent time to change the belt, I would suggest you to change it for peace of mind too as unlike the chain the belt wouldn't make any noise or give symptoms and in case if it gets bad and snaps, you will end up with a bigger bill due to the damage.
h14 is online now   Reply With Quote
Old 26th August 2016, 12:04   #48
arun_josie's Avatar
Thanked: 4,339 Times
When the recommendation from Fiat is very clear(replacement at 60k or 5 years whichever is earlier), why take a chance for a critical component like timing chain?! Haven't you completed 5 years yet?
arun_josie is offline   Reply With Quote
Old 12th September 2016, 15:39   #49
Thanked: 7 Times
Agree. Need to change the timing belt immediately.
Does the water pump also need to be changed? I read somewhere that it should be replaced when the timing belt is. Besides, it may be better to change both together, saving some labour charges.
Old 16th September 2016, 13:34   #50
arun_josie's Avatar
You can refer to my below post for the list of items replaced along with timing chain,
http://www.team-bhp.com/forum/long-t...ml#post3821407
arun_josie is offline   (1) Thanks Reply With Quote
Fiat Linea and Fiat Punto (90 BHP) Owners. Timing chain issue & recall justin.das Technical Stuff 128 5th December 2017 19:56
MM550 chain timing Help! motocamp 4x4 Technical 6 21st April 2010 12:57
520 Chain (Karizma Chain) Query DeepakMenon Motorbikes 11 10th December 2009 12:29
Timing (cam) belt vs chain sbasak Technical Stuff 33 10th November 2009 16:00
ford ikon 1.6 timing chain noise? silver_shadow Technical Stuff 7 29th November 2008 19:50
