Old 23rd September 2011, 21:08   #46
Akshay1234's Avatar
Thanked: 7,239 Times
Default Re: The Speed at which you downshift from 5th gear
Originally Posted by rahul_9327 View Post
@ others . Sorry if i wasn't clear. Actually wanted to know about downshifting from 5th to 4th in higher speeds like at 100/110 and not at lower speeds. My fear is, will downshifting at high speeds do any harm to engine or may be get the vehicle to spin.
There won't be a problem of downshifting even till about 130 to 4th gear, if you need that extra bit of power. Maybe you can set 120 as your limit to downshift to 4th in the Spark.
Mahindra TUV300 AMT loses engine power @ 100 kmph, AMT doesn't downshift silverknight Technical Stuff 21 25th November 2015 10:33
Hi-RPM Downshift | Considering a Swift VDis (in lieu of Innova) btirthankar Hatchbacks 51 20th April 2009 19:38
5th-gear noise?! ghostrider4385 Technical Stuff 25 7th February 2006 00:07
Do you ever forget in which gear you are in? sbasak Shifting gears 40 15th December 2005 15:34
5th gear presenters!!! Shan2nu Shifting gears 7 12th February 2005 18:10
