Old 23rd April 2006, 05:40   #1
mithun's Avatar
Thanked: 58 Times
Smile The Speed at which you downshift from 5th gear
At what speed do you downshift from the fifth gear ?
I know that different cars are having different torques, so the speed at which people downshift will not be similar ?
And do you downshift based on the speedo/tacho or from the engine responsiveness ?
I downshift when the speedo goes below 40 KM/HR.
Old 23rd April 2006, 08:43   #2
I got a zen and downshift from fifth gear is done once speed drops below 50kmph
the real Big B is offline   Reply With Quote
Old 23rd April 2006, 08:50   #3
DCEite's Avatar
Thanked: 607 Times
ummm... when i am not in too much hurry... its usually 40kmph.. sometimes even below it!
DCEite is offline   Reply With Quote
Old 23rd April 2006, 11:11   #4
We dont go by speed to downshift from 5th
We need to feel the engine RPM and then downshift
So it depends and differs from cars to cars
iamdstig is offline   Reply With Quote
Old 23rd April 2006, 11:30   #5
TCX
Hmmm........I mostly shift by feeling so I wasn't sure and so I just took the car out to check, around 65-70 Km/Hr. Anything below that and my car Jerks.
TC
TCX is offline   Reply With Quote
Old 23rd April 2006, 11:46   #6
Kaizer Sozay's Avatar
I Too have a zen & downshift a little below 40. No shudder whatsoever at 40, so i continue in 5th gear
Kaizer Sozay is offline   Reply With Quote
Old 23rd April 2006, 12:26   #7
sbasak's Avatar
As long as the engine produces enough torque to pull the car at 4th gear, you can downshift.
Just try to see at what speed in 5th gear the car begins to jerk. That is the threshold speed for your car.
More torque the engine produces, less the speed where you can move to 5th gear.
sbasak is offline   Reply With Quote
Old 23rd April 2006, 14:53   #8
Deeps's Avatar
Thanked: 68 Times
I never shift up or down based on the speedo...but only looking at the tacho! Usually when there's no hurry I shift up at about 2500rpm and shift down at 1500rpm. But for 5th i shift down at 17-1800 since the torque produced in that gear is pretty low.
Edit: All this on a Clio 1.4 petrol.
Deeps is online now   Reply With Quote
Old 23rd April 2006, 16:41   #9
Scuderia's Avatar
I guess it depends more on
1. Engine RPM
2. The acceleration you expect to have further ahead. You may need to downshift even at 80, in order to make an overtake; or continue in 5th even at 40, if you intend to maintain the speed, with slight or gradual acceleration.
Scuderia is offline   Reply With Quote
Old 23rd April 2006, 18:58   #10
frankmehta's Avatar
Thanked: 2,334 Times
40 kmph......
and i upshift to 5th gear at 50
Old 23rd April 2006, 19:36   #11
Dark Knight's Avatar
In my baleno..I can even hold not downshifting even upto 30 km/hr.
This car has truly great torque. No shudders in 5th. even at that speed.
Dark Knight is offline   Reply With Quote
Old 23rd April 2006, 19:39   #12
karthik247's Avatar
Thanked: 16 Times
You can't just judge and shift gears at a perticular speed. It depends more on the situation, and ur driving style.
karthik247 is offline   Reply With Quote
Old 23rd April 2006, 22:53   #13
Rehaan's Avatar
Thanked: 25,038 Times
Am i the only person who downshifts from 5th gear at ~90km/h?
FE? whats that?
cya
R
Rehaan is offline   (1) Thanks Reply With Quote
Old 23rd April 2006, 23:08   #14
drifter's Avatar
Hehe im close to you rehaan...70kmph for downshifting from 5th. Still managing 11kmpl in city hehe. Gotta love the crdi
Drifter
drifter is offline   Reply With Quote
Old 23rd April 2006, 23:29   #15
karthik247's Avatar
Thanked: 16 Times
Rarely use 5th, i upshift at 150kmph from 4th on the highway
And its very rare that i use 5th below 50kmph, until its absolutely necessary and i'm low on fuel n don't have money
Mahindra TUV300 AMT loses engine power @ 100 kmph, AMT doesn't downshift silverknight Technical Stuff 21 25th November 2015 10:33
Hi-RPM Downshift | Considering a Swift VDis (in lieu of Innova) btirthankar Hatchbacks 51 20th April 2009 19:38
5th-gear noise?! ghostrider4385 Technical Stuff 25 7th February 2006 00:07
Do you ever forget in which gear you are in? sbasak Shifting gears 40 15th December 2005 15:34
5th gear presenters!!! Shan2nu Shifting gears 7 12th February 2005 18:10
