Old 30th August 2012, 14:43   #1
tsk1979's Avatar
Thanked: 16,421 Times
Default Starter motor solenoid lock - Causes?
Recently while the safari was at workshop, the door motor was being worked upon. On attempting to start the engine, suddenly click click sounds came, with no engine turn.
Even with jump starting same sounds came.
Then the workshop guys engaged car in gear, rocked her back and forth, and reattempted started. Guess what. Engine started.
The tech told me the "solenoid" got locked. It happens once in a 500 times kind of thing. Won't happen again.
I am worried. If it happened once, why won't it happen again?
Whats the cause?
Old 30th August 2012, 15:50   #2
Thanked: 245 Times
Default Re: Starter motor solenoid lock - Causes?
I have seen this one before long time back in other cars, I think its a gear lock in the starter which the solenoid has to rotate.
dadu is offline   (1) Thanks Reply With Quote
Old 30th August 2012, 16:01   #3
n.devdath's Avatar
Thanked: 2,150 Times
Whats the cause?
When the mechanic tried to start the engine, the pinion which is triggered by the solenoid switch meshed with the flywheel but could not rotate it due to:
1. The bendix drive could have lost lubrication.
2. The yoke which pushes the bendix might have gotten jammed slightly.
These are common issues and generally hard to replicate. Generally, an opening, cleaning and lubrication of the solenoid switch assembly solves it, if it repeats itself.
When the mechs rocked the vehicle, the flywheel turned slightly and it freed up the bendix and the yoke and it was pulled back to its place which solved it.
n.devdath is offline   (2) Thanks Reply With Quote
Old 27th April 2017, 08:04   #4
Thanked: 165 Times
Whats the cause?
How do you ascertain that the solenoid has got locked? And that there is no problem with battery or starter motor?
My Altis isn't starting since Tuesday evening. The battery looks to be alright, as all other electronics are working fine. I cleaned the terminals and tried to start, but it did not.
And all the while, the starter motor is making machine gun like click sounds. I tried tapping the motor slightly with a screwdriver, I tried pushing the car back and forth in 3rd gear, still it did not. The clicks were happening though.
Swapnil4585 is offline   Reply With Quote
Old 27th April 2017, 09:51   #5
R2D2's Avatar
Thanked: 2,040 Times
On the face of it the battery is a goner. The battery can seem normal but fail when under a heavy load. Please have it load tested at the first opportunity.
But if you are sure about the battery then check for any voltage drop from the battery positive post to starter motor solenoid coil. Ditto for the negative/earth side.
R2D2 is offline   (3) Thanks Reply With Quote
Old 27th April 2017, 17:27   #6
Thanked: 165 Times
You are absolutely right sir. The battery was dead and a new one, Amco, has been deployed today.
Old 27th April 2017, 21:01   #7
R2D2's Avatar
AMCO? Didn't think they make a 45 AH battery for the Corolla Altis/Honda Civic. Which model did you buy?
R2D2 is offline   (1) Thanks Reply With Quote
Accent Viva Crdi: Purge Control Solenoid Valves - Rs.16.5k! EDIT: Fixin it DIY style! AbhiJ DIY - Do it yourself 64 11th December 2014 13:38
Fabia Starter Motor; Solenoid Switch jnpai Technical Stuff 3 18th September 2011 21:44
Security : Gear lock, steering lock venkatrx Modifications & Accessories 11 25th January 2011 18:04
Starter/Solenoid problem M800 shipnil Technical Stuff 4 18th May 2009 17:10
Battery or started/solenoid tsk1979 Technical Stuff 2 10th May 2005 16:18
