Old 4th September 2012, 13:38   #1
NOTORIOUS's Avatar
Thanked: 89 Times
Unhappy Alto powerless after Engine wash
Hello
I have started my alto in morning and it was fine , as i was topping up windshield water , i looked at engine bay and it was too dusty. i sprayed some water in engine bay with engine running. the car was fine but as soon as i reversed , it struggled and engine stopped.
I tried starting it but was not successful. i left the car there with open hood and told brother to fire her up in 1 hour.
now he has called that the car is started and running but has lost all its power.
Now can somebody explained that what went wrong ??? This was not first time i was washing engine bay , it has never happened to me earlier .
Waiting for your valuable suggestions.
Jas
NOTORIOUS is offline   Reply With Quote
Old 4th September 2012, 13:43   #2
rajeev k's Avatar
Thanked: 1,750 Times
Default re: Alto powerless after Engine wash
Is it firing in all its cylinders? Water in the plug wires can lead to misfiring and loss of power.
rajeev k is offline   Reply With Quote
Old 4th September 2012, 13:52   #3
NOTORIOUS's Avatar
Thanked: 89 Times
Note from Mod: There are several spelling & grammatical errors in your posts. This negatively affects the board experience for other readers.
Kindly ensure that you proof-read your posts prior to submission. Also, it would be a good idea to use spell-checkers.
NOTORIOUS is offline   Reply With Quote Received Infraction
Old 4th September 2012, 14:01   #4
dhanushs's Avatar
Thanked: 4,504 Times
Default Re: Alto powerless after Engine wash
Is the engine check light on? If so, the car should be in limp mode. It recently happend to my friends Fiesta.
Try clearing the error codes. ie, remove the battery terminals, put key in ignition press brake pedals, turn on HL's. After 15 mins, refit the terminals.
It should work.
Old 4th September 2012, 14:19   #5
NOTORIOUS's Avatar
Thanked: 89 Times
No , Engine check Light Is Not There !!!
Old 4th September 2012, 15:26   #6
devsoftech's Avatar
Thanked: 121 Times
Had a similar problem with my estilo. Issue was with water in ignitor.
devsoftech is offline   Reply With Quote
Old 4th September 2012, 15:48   #7
vasanthn21's Avatar
Thanked: 306 Times
I agree with Rajeev's opinion here.
One question though. How easy or difficult is it to find out if the car is misfiring, I know it is easy in a 2-wheeler.
vasanthn21 is offline   Reply With Quote
Old 4th September 2012, 16:23   #8
Thanked: 137 Times
Originally Posted by NOTORIOUS View Post
Hello
You should not spray water with hoses inside engine bay. Now I can think of the following things you need to check.
1. Distributor got water in it. Remove spark plug wires and wipe.
2. Water entered spark plugs. Remove and clean.
3. Water entered air intake. Remove air filter (or disconnect throttle body) and check.
Let us know.
carbookie is online now   Reply With Quote
Old 4th September 2012, 16:27   #9
manikjeet's Avatar
Thanked: 110 Times
Dont be scared its a simple diy
You have got water in the distributor, all you have to do is that open the distributor and clean it up and while doing so you can take a piece of very fine sand paper and also clean the points
manikjeet is offline   (1) Thanks Reply With Quote
Old 4th September 2012, 19:30   #10
rajeev k's Avatar
The 'distributor' doesn't have contact breaker points, is it not?
Old 4th September 2012, 22:10   #11
NOTORIOUS's Avatar
Thanked: 89 Times
Problem Solved !!!
i left the car in sun with hood open for 2 hours and voila it started in a single crank without any problem.
Thanks for your valuable suggestions.
Basic Car wash & Polishing - Vent Car wash (Tharamani, Chennai) scopriobharath Chennai 9 10th February 2015 16:59
Renault Pulse: Engine Start/Stop problem after car wash san_jayd Technical Stuff 12 12th September 2013 14:05
Car Wash - Blr (indiranagar) - Shri MHP wash center quadra Bangalore 14 23rd May 2013 01:55
Car Wash and Interior Detailing - Srd Magic Jet Car Wash (Sainikpuri, Secunderabad) windsurfer Other Cities 5 20th September 2011 15:06
Engine shudders after water wash mhawk.madhan Technical Stuff 9 26th October 2010 03:41
