Old 23rd August 2014, 13:20   #61
wooka's Avatar
Thanked: 11 Times
Default Re: Hit a brick @ high speed.. Damage won't go away.. Need help
For chassis alignment does the car have to be pick up off the ground? Cause I'm headed out right now.. Should I go to HASS first or simply to a good denter?
wooka is offline   Reply With Quote
Old 23rd August 2014, 13:57   #62
audioholic's Avatar
Thanked: 6,135 Times
The alignment machine usually provides caster and set back values also. Check that. I saw this being rectified on a swift in front of my eyes. The strut mounting area itself was bent due to the car hitting a divider at high speed. The aligner pulled out the old strut back to its actual position. Later the strut was replaced with a new one once its castor angle was rectified.
Personally I hate the idea of road side garages trying jugaads to get such things back in place. I have such a garage opposite my house. They correct such faults by tying a chain between the car and a tree, and reverse the car to get it back to shape. Else in such a case they will manually pull it out somehow. I will faint if such work is done on my car, even though how much money I would save by not getting it done professionally.
audioholic is online now   (1) Thanks Reply With Quote
Old 23rd August 2014, 15:17   #63
wooka's Avatar
Thanked: 11 Times
Mod Note : There are several spelling & grammatical errors in your posts. This negatively affects the forum experience for other readers.
Kindly ensure that you proof-read your posts prior to submission. Also, it would be a good idea to use spell-checkers.
wooka is offline   Reply With Quote Received Infraction
Old 24th August 2014, 16:45   #64
wooka's Avatar
Thanked: 11 Times
Default Re: Skoda Rapid(ly) Overhauled - Suspension & Brakes
Awesome!
Moving on, the castor values were well within tolerable limits. In fact, near identical, I think 123' for both the left and right front struts. The car was lifted off a hydraulic lift further high up for me to inspect everything as well. . Besides a few grease marks I came away happy. Everything is in good shape. The ball joint had broken the day of the accident as I recall now. The mounting bracket, suspension arm etc all seemed to be fine.
The problem is thus - i had one tyre changed that very day - accelere, here comes the pain. I subsequently had the suspension arm changed and the second front tire changed after a camber bolt adjustment. Too late - the damage was done. The tyre guy further increased my toe in during the second front tyre change, to a total of 5 in.
End result - its the accelere I had changed earlier, subjected to a bent suspension arm, poor camber and extreme toe in, paid. The outer tread was marginally more worn out. We inverted this tyre on the same rim and voila, the car has started to pull to the other side ever so slightly.
Finally I've been told to wear out the tyre a bit till it settles down, and my Jk's from the rear have been rotated to the front. All is fine for now. . Thanks a lot for your help, everyone, =)
Old 27th August 2014, 11:43   #65
Thanked: 19 Times
@Turbohead: This unfortunately seems to be a shoddy mechanical anomaly right from the manufacturer.
Two days ago after reading your thread verbatim,I happened to see a Rapid in my office premises waiting to pick up some one.Luckily the car was about to take a turn but was at standstill, I managed to have a look at the inner wall of the tyres.
To my utter disbilief it had the same uneven and rather premature tyre wear.The car was a personal vehicle(atleast from the no. plate) and was comparitively new.
Looking at this my bielief is reinforced that this has to be a crucial manufacturing defect.I think SKODA should take this on warfooting and correct it by initiating a recall.
cotterpin is offline   Reply With Quote
Old 14th January 2016, 23:54   #66
Hello all. I am a new member. Noting this issue.... Yes it is a hugely common issue with vento/rapid because of relatively high castor that causes camber to change with tyre wear significantly more than several other vehicles...
It is definitely around the 30000 km mark that you will notice that both these cars start wearing the inside of the front tyre and a while later the inside of the rear tyres. It is not per say a design flaw just a slack approach to using an existing setup for a bigger car.
Beware though, even after changing the tyres you will find that damage has been done to the suspension and housing units to the point that it cannot be fixed easily. You will find a tiny amount of wobble under hard braking, wandering at speeds over 120 kph, wheels becoming misaligned faster.
Suggestion is to keep a watch on the tread wear after replacing tyres and replacement of suspension with fully adjustable one and a strengthening brace(back and front) should keep your vw/skoda running very nice wear patterns for years and kms to come. Enjoy motoring.
autopilotrik is offline   Reply With Quote
Skoda's Advisory on the Rapid's brakes VeyronSuperSprt Technical Stuff 51 19th February 2018 14:15
A red hot rapid install in a red hot (Skoda) Rapid Samridh In-Car Entertainment 28 18th August 2013 00:49
Skoda Octavia at 175k kms- Suspension, Brakes, Axles etc overhaul query metanoia75 Technical Stuff 1 26th November 2011 12:54
Gypsy - Overhauled!! rmonie 4x4 Vehicles 70 4th October 2010 00:06
Problem in partly overhauled 5 speed maruti 800 ramkris Technical Stuff 19 3rd August 2010 13:25
