Old 26th February 2017, 13:02   #16
GranvilleDsouza's Avatar
Thanked: 134 Times
Originally Posted by Mr.Boss View Post
Going by your statement it should be the issue with Selector cable. If you are interested and the car is untouched by the mechanic, open the hood and check the gearbox area for selector cable mechanism to understand what went wrong.
Yup, the lock on the selector cable has broken. Asked him why, he says can happen in 8 years of having the car. He has tied it and done some jugaad with a wire for now cause I have some work to attend to and need the car. Locks don't come separate have to change the cable will do it tomorrow.
GranvilleDsouza is offline   (2) Thanks Reply With Quote
M800: Problem in slotting the car into gears rrsteer Technical Stuff 3 15th April 2010 22:26
tvs starcity - 4-gear vs 5-gear papikondalu Motorbikes 0 14th April 2010 12:45
i10 gear stuck in reverse gear drkunaldas Technical Stuff 33 23rd November 2009 02:21
Swift 2nd Gear Problem EDIT: Now first gear problem BUSA Technical Stuff 85 2nd September 2009 18:47
Top Gear in 'Top Gear' (3 veyrons offered for shoot) SumitB Shifting gears 8 4th August 2008 13:22
