Old 17th September 2012, 22:46   #1
Default Smoke from Innova a/c
Hi all,
Last evening, while returning home from office, Toyota Innova started to generate smoke from engine which came through the a/c vents as well. There was heavy traffic, thus could not stop on the way as the temp gauge was also not showing any reason for any concern. At home, I verified the coolant and engine oil which was fine. The smell of thick smoke is a concern now, parked it outside as there is smell of rubber or plastic or even both. Have to find out in the morning or should visit the dealer tomorrow itself. Did any of you had similar experience from Innova diesel? What is wrong, as I don't see any signs of oil or coolant leak.? Would appreciate your advise or thoughts. Thanks.
joommen is offline   Reply With Quote
Old 17th September 2012, 22:49   #2
alstonvaz's Avatar
Default Re: Smoke from Innova a/c
Check if any of the belts are stuck in the pullleys and got burnt.
alstonvaz is offline   (1) Thanks Reply With Quote
Old 18th September 2012, 06:34   #3
condor's Avatar
Thanked: 4,907 Times
Are you using fresh-air mode or re-circulation mode ?
Old 18th September 2012, 08:51   #4
parsh's Avatar
Thanked: 1,023 Times
joommen, it is better to get it thoroughly checked at Toyota dealership and be present at the shop floor, rather than poking around for any issues. It is difficult to predict what could have gone wrong. Back in 2006, when my Innova was relatively new, I had experienced once this kind of behavior while we were touring outstation. Took her to nearest dealership for checkup. Spent couple of hours but couldn't deduce anything, nothing wrong was detected. After that till date, there has been no such incident.
parsh is offline   Reply With Quote
Old 18th September 2012, 15:41   #5
Thanked: 36 Times
I have seen smoke in AC vents in my 2 months old Fiesta Classic but that is only for first couple of seconds after switching on. As I don't have ACC I keep switching ON / OFF the AC frequently on Long drives. Whenever I Switch ON I see Smoke coming through AC Vents for some 5 sec and works fine later on. This is also happening intermittently. What could be the reason ?
NaveenKBorra is offline   Reply With Quote
Old 18th September 2012, 16:01   #6
tsk1979's Avatar
Thanked: 16,422 Times
Is it odorless. If so, then do not worry. Its just ¨mist¨
tsk1979 is offline   (1) Thanks Reply With Quote
Old 18th September 2012, 16:09   #7
Thanked: 36 Times
Yes, Its odorless and not thick as well (Something you see when you open a refrigerator door). I have visited the dealership for rear cranking sound last month and I have also mentioned the same. They tried to test but it was all good, no smoke either.
Old 18th September 2012, 16:30   #8
ecenandu's Avatar
Thanked: 1,791 Times
Then its mist for sure. Hey, I used to do the same to control the cabin temperature i.e, by switching A/C ON and OFF. But passengers complained often when I do that, now I do it by adjusting the temperature knob and varying the blower speed. Try this method, it is much better.
ecenandu is offline   Reply With Quote
Old 18th September 2012, 16:50   #9
Thanked: 103,673 Times
Joommen,
The smell of rubber & plastic indicates that it could be an electrical burn too. You made a mistake by continuing to drive, but got away lucky. Please do get the vehicle thoroughly checked up by a Toyota dealership. Once they nail down on the problem, do update us as well.
Old 18th September 2012, 17:47   #10
carwatcher's Avatar
Thanked: 1,003 Times
One distant possibility can be someone burning plastic waste near the road. If the AC is on recirculation mode than this theory is not valid.
But still smoke coming from vents needs to be checked.
carwatcher is offline   Reply With Quote
Old 18th September 2012, 18:43   #11
Thanked: 172 Times
I felt the same when I saw it in Safari, when traveling on dusty patches or with some vehicle overtaking you releasing a lot of smoke ahead of you. Changing the circulation mode to block outside air from entering stopped the apparent "smoke" instantly.
But always better to be cautious and have it checked if you don't think above was not the case with you.
mayuresh is offline   Reply With Quote
Old 18th September 2012, 19:14   #12
devarshi84's Avatar
Thanked: 119 Times
The smell you talk of is not of burning rubber or plastic. Please check again and confirm. It is similar to a burning smell though. Did you find the smoke really chilly? If yes, then it was mist. Open the windows on a sunny day.
devarshi84 is offline   Reply With Quote
Old 4th October 2012, 10:27   #13
Thanks for all the inputs, I did speak to a Toyota service engineer and then took the car to the nearest dealer. The issue was with the clutch, thankfully no damage. The technician advised to avoid half-clutch but switch over to first gear while in heavy slow moving traffic, which is a common phenomenon even in Whitefield these days.
ECU Flashing for white smoke problem in Innova ? jalsa777 Technical Stuff 14 29th March 2012 11:30
Innova'tive Interiors :D (My Mica Grey Innova with Refreshed Interiors) Bhushanrulz Test-Drives & Initial Ownership Reports 45 26th July 2011 00:48
Which brand do you smoke?? Sam Shifting gears 151 15th November 2008 16:28
Smoke is Here smoke_2fst Introduce yourself 12 8th February 2005 23:09
Mysterious Smoke Stratos Shifting gears 4 20th April 2004 08:01
