Thread Tools
Old 27th April 2006, 14:06   #16 (permalink)
Team-BHP Moderator
Rudra Sen's Avatar
Originally Posted by Sam Kapasi
Let me also add that it's not like a HUGE dimming or anything, just that Rudra's a fussy sort of chap that cannot tolerate the slightest imperfection
My dear Sir, can we eliminate that slightest imperfection? Don't tell me it can't be done...
Old 27th April 2006, 14:21   #17 (permalink)
jkdas's Avatar
Originally Posted by navin
I intend to upgrade to a slightly bigger woofer amp (PA275) in both cars. That would increase capabity maginally and will report if this marignal increase pushed my battery to the point where light dimming is noticed.
PA is one of teh smallest amp I have seen. I get your point Navin ( you meant more wattage )
As I said my car has a PA275 and Pio 6000f; no dimming and teh battery is OEM ( I doono which; will chck if needed for you guys)
Karthik, what next?
__________________
"She may not look like much, but she's got it where it counts, kid."
Old 28th April 2006, 08:47   #18 (permalink)
Lightbulb
well should have gone for Amaron...
i had installed it in my old sierra...
didnt give any problems till 3.5 years after which i sold the car so done know if the new owner had any isssues...
__________________
I live my life a Quarter Mile at a Time...
zulfikar is offline   Reply With Quote
Old 28th April 2006, 09:12   #19 (permalink)
basilmabraham's Avatar
The battery on my Palio D went dead once. My wife was driving and was trying to manipulate a steep climb from stall. The ac and the music system was on. The engine stopped a few times as she wasnt an expert. This happened for a few times. And then the car wudnt start at all.
The battery had gone dead. I poured in some distilled water in the battery cells, most of them were dry (lack of maintenance). Waited for a few hours and with some help from neighbours got the vehicle jump started. Left the engine on for some time for the battery to charge. There was no problems after that.
Now, I am away from home and the car has been lying almost idle for a month now, only weekly starts by my good neighbour. It seems the battery has died again and the car wont start.
I guess all this happened because of my careless maintenance of the battery. Can anyone give tips on how to properly maintain the battery in a car. Also suggest replacements for the stock palio battery.
Sorry if there has already been a post on this topic.
__________________
Never be afraid to try something new.
Remember, amateurs built the ark, and professionals built the Titanic.
basilmabraham is offline   Reply With Quote
Old 28th April 2006, 11:13   #20 (permalink)
karthik247's Avatar
New batteries are like maintainance free. So it would be best to get those, and once in a while checkup would be helpful too
__________________
Slow and steady wins the race... But there is nothing like a 300kmph dash to the line!!
karthik247 is offline   Reply With Quote
Old 28th April 2006, 11:19   #21 (permalink)
Karthik are the maintenance free ones without the opening on the top. The one i had did have openings for fill ups. Wonder why palio came with this one. They shud have put in a maintenance free one.
__________________
Old 28th April 2006, 11:53   #22 (permalink)
satish_appasani's Avatar
My Palio D (August 2004) came with a Exide Freedom battery. The battery once died when the car was still in warranty. Got it freely replaced.
satish_appasani is offline   Reply With Quote
Old 28th April 2006, 12:07   #23 (permalink)
wolfinstein's Avatar
Maintaince Free Battery, Does not mean it should be sealed or so..I have seen maintaince free battery with openings on the top for having an ocassionla top up of electrolyte or battery water + No battery can be completely sealed as the battery releases Fumes, for which it needs to have gas vents on the top..!
__________________
" When was the last time, You did something for the first time "
wolfinstein is offline   Reply With Quote
Old 28th April 2006, 22:27   #24 (permalink)
karthik247's Avatar
Yes, even maintaince batteries have openings on top for occasional refills
__________________
Old 29th April 2006, 09:58   #25 (permalink)
Team-BHP Moderator
navin's Avatar
Funny. Sam I am running 2 amps in each of my cars) and have no issues with dimming.
maybe my moderate power needs keeps the issue contained. and trust me I am as fussy as Rudra.
navin is online now   Reply With Quote
Old 29th April 2006, 10:07   #26 (permalink)
Team-BHP Moderator
Rudra Sen's Avatar
OK Sir...what should I do to sort this out? You tell me what to do and I'll follow your instruction..blindly.
Old 29th April 2006, 10:25   #27 (permalink)
jkdas's Avatar
Thats what I was thinking too. I have two amps and my setup is fine. There should be some problem with Rudras. (can someone check teh ICE of a stock Optra; by playing it at full volume. )
Navin, dont ask Rudra to redo the whole wiring!
__________________
Old 1st May 2006, 01:31   #28 (permalink)
low_bass_makker's Avatar
If one has spent 5k on a battery U must go for optima it is avalable in india through amron itself and it cost nearly 10k.I does not need a refill it is sealed
__________________
156.6 db, naa....time is coming to cross it......
Old 1st May 2006, 10:01   #29 (permalink)
Revvhead's Avatar
The best cure for this, is when you are off for a month or so, is to disconnect your battery. That way it wont drain.
Weekly starts are all fine, but asfter you start (or rather your neighbour)
how long do you run it and at what revs.
Just a start, very short idle run and stop will only drain the battery without recharing it. Its worse than not starting at all.Remeber its startingt that sucks the most juice out.
So the other option is start and run ofr 5 mins or so, and revv the engine a bit when you do.
My Fiat had an ammeter, so you could see exactly at what revs the carging was happening.
Else your best bet is to Discoonect your battery.
__________________
The Swift DZire has a 6 Month waiting period to give you time to seriously reconsider buying something that Ugly
Revvhead is offline   Reply With Quote
Old 1st May 2006, 12:32   #30 (permalink)
pramodkumar's Avatar
I got a new central locking installed in my car, it came with a ignition cut off if the car is not opened properly then it will not let the car start. My damn mechanic did not know this and kept on trying all different things he knew and killed my stock battery which was 8 year old (i was lucky i guess). i got a new amron maintanance free for 2000 bucks has a 1 year warranty i guess . But now every thing is fine. (atleast at the battery end)
Thread Tools
urgent...battery needs replacement, what brand?? clipto333 Ask the Gurus 50 14th August 2008 15:31
Sub Replacement overdose14 Ask the Gurus 27 23rd January 2008 22:31
Signs that battery needs a replacement sreenivass Technical Stuff 23 11th April 2007 18:52
Engine Replacement sivankutty Technical Stuff 4 2nd September 2006 20:56
2 Din replacement kb100 Ask the Gurus 6 2nd March 2006 10:06
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445
