Thread Tools
Old 1st May 2006, 13:47   #31 (permalink)
kb100's Avatar
Default Upgrading Battery
Guru's
MY OE Battery in my Accent CRDi has lasted me over three years... its still going strong but I get indication that it must be on the decline... I just plonked in a pair of 140/100 headlights.... Plus am in the middle of planning my ICE... This is likely to have comps in front and back + ONE sub + two amps(maybe only one amp... undecided but the total of the fuses on the amps alone is 160 amps !!)
Hence I thought its best I get my battery replaced as well ..... my replacement battery had better be an upgraded one as well..
Please advice me on Brands/models... I was thinking of the yellow top .. (..Ultimas's I think they are called - distributed by Amaron) ...
Now the CRDi's engine bay is so packed that its impossible to fit anything other than the OE sized Battery.. Hell - I had to remove the Battery to even get at the healight bulb!!.. Therefore I was planning to place the battery in the rear Boot... can this be done??... how...guage of cables to be used... precautions to be taken etc...
Secondly - the alternator is rated at 120 amps.... with the upgraded headlights... the ICE ... etc.. will this be able to handle all of this PLUS charge the upgraded batt as well..?... or recommend a suitable batt upgrade which can work well with the above requirement..
Muchas Gracias!
__________________
A closed mouth gathers no Feet.
kb100 is online now   Reply With Quote
Old 1st May 2006, 13:56   #32 (permalink)
drifter's Avatar
Yes i have been in the same dillema...how to fit an upgraded battery and an upgraded alternator. Waiting for the electrical experts.
Drifter
__________________
Slow Everything Down And Feel Like God - Tata Safari
drifter is online now   Reply With Quote
Old 1st May 2006, 15:35   #33 (permalink)
veyron1's Avatar
well, perhaps you could try experimenting with the amaron's latest series- the ones with 48 month warranty. but the last they have in their range is 70 AH, i guess; last time i checked (which won't fit under the hood). otherwise, you could try with a new 50 AH one under the hood, and keep a SECOND battery (48 AH or so) in the boot, connected in series. but be warned, this type of setup is gonna DRAIN the alternator like hell. upgrading the current 120 AH alternator is not going to be so easy either. it can, however, be overhauled (the winding/armature setup can be replaced) and pumped up to 140 AH or so, but be sure to get it done from a reputed mech. getting a 160/180 AH alternator might be even better, but outer casing dia. and mountings will differ, so be prepared for some extensive work. and there's no guarantee that the existing pulleys will have enough clearance- since the engine bay's tight. plus a new alternator could cost you upwards of 17-22,000.
my opinion; get the current alternator overhauled, and get a second battery connected in series from the boot. about the wire gauges, no idea, as i haven't yet gone to such detailed info on these setups. and yes- be sure to get a proper voltage reg., as the electrics for the fuel lines run on the alternator; overloading the alternator could prove, well, ka-boom...
p.s- REMOVE those 100/140 bulbs A.S.A.P; those things will FRY the reflector; you could be looking at a set of new headlamps every other year. instead, get a good set of hella rally lamps (spot-lamps), with a good cut-out and proper wiring. else, go in for a HID setup; that would produce less than half as much heat, and give a brighter beam.
hope this layman's view helps...
__________________
DAD
veyron1 is offline   Reply With Quote
Old 1st May 2006, 15:54   #34 (permalink)
kb100's Avatar
I thought Amara Raja gave more than just a single years warranty on their batteries...
__________________
Old 1st May 2006, 16:32   #35 (permalink)
F50
Team-BHP Moderator
F50's Avatar
Threads Merged........
__________________
F50
When in doubt, throttle out.
F50 is offline   Reply With Quote
Old 2nd May 2006, 20:16   #36 (permalink)
kb100's Avatar
BUMP
Anyone any thoughts on Battery in the boot....??... Feedback/pros/Cons...
__________________
Old 2nd May 2006, 21:45   #37 (permalink)
DRC
DRC's Avatar
BUMP
Why?
If it is an additional one for amp or so, OK, still a lot of hardship for the alternator...
If it is a stand alone stuff, which has to power the starter motor also, not very good idea. There will be a lot of potential drop for the starter and hence lower voltage, may take longer cranks and strain thebattery..
__________________
_____________________
Stand on your head, upside down..
The world does not look any different, but you sure will look different!
DRC is offline   Reply With Quote
Old 2nd May 2006, 22:42   #38 (permalink)
nitrous's Avatar
Nice theory,man.
But, our members 'Sideways' and 'Ford Rocam' are happily using it.
__________________
The Road less travelled, is less travelled for a reason
Old 3rd May 2006, 11:24   #39 (permalink)
wolfinstein's Avatar
Well if you guys are wanting another soruce of power from the boot, I would suggest meet with any good UPS-Inverter seller, who can customize your power system using Sealed Batteries, and you can charge that battery every day/alternate days or week by a power cable...!
It will be better than placing a regular car battery in the boot...!
Plus the inverter will be specially desgined for you to fit in the boot, provide the right current as per your need and cost-effective...!
__________________
" When was the last time, You did something for the first time "
wolfinstein is offline   Reply With Quote
Old 3rd May 2006, 21:50   #40 (permalink)
veyron1's Avatar
@wolfinstein: the inverter would supply A/C current, not D/C. but yes, dry batteries are better than lead-acid batteries, as they can sustain heavy loads for a much longer duration. although getting an inverter setup might not be logical, the dry battery is a good idea, and would be a very good secondary source.
@DRC: technically, IF the second battery is standalone, then there's NO power drain from the primary, and hence no load to the starter/alternator ckt.
@nitrous; they're using only ONE battery from the boot; but the relocation is kinda tedious...
@kb100; amara raja ALWAYS gave 36 months warranty minimum on their batteries, the 1st year being a replacement quota. their new ranges have 48 months warranty. and IF you want to go in for a boosted electrical setup, there's nothing better than a second battery from the boot. but like i said, connections should be proper, in series, and the alternator should be beefed up.
__________________
DAD
Old 5th May 2006, 18:47   #41 (permalink)
Originally Posted by zulfikar
well should have gone for Amaron...
i had installed it in my old sierra...
didnt give any problems till 3.5 years after which i sold the car so done know if the new owner had any isssues...
I second you...my initial Exide in the Uno gave up after 24 months..I wanted to replace...Excide quote rws Rs 3600 for a 44 DIN...I finallay purchased an Amaron for 2500 Rs..notbecause it was cheaper but I was pissed with Exide for just lasting 2 years...
The Amaron is still in service after 42 months...but of late I am facing an alternator issue in the uno...as soon as I switch on the AC/blower, the Voltage dips from 13.5 volts to 11.5 volts and the battery gets discharged even after one hour of driving with AC...driving witout AC is no problem..so guess I will have to engage someone to find out where is current loss is happening...can you suggest someone good in hydereabd?
Buffetfan is offline   Reply With Quote
Old 5th May 2006, 18:49   #42 (permalink)
Originally Posted by basilmabraham
The battery on my Palio D went dead once. My wife was driving and was trying to manipulate a steep climb from stall. The ac and the music system was on. The engine stopped a few times as she wasnt an expert. This happened for a few times. And then the car wudnt start at all.
The battery had gone dead. I poured in some distilled water in the battery cells, most of them were dry (lack of maintenance). Waited for a few hours and with some help from neighbours got the vehicle jump started. Left the engine on for some time for the battery to charge. There was no problems after that.
Now, I am away from home and the car has been lying almost idle for a month now, only weekly starts by my good neighbour. It seems the battery has died again and the car wont start.
I guess all this happened because of my careless maintenance of the battery. Can anyone give tips on how to properly maintain the battery in a car. Also suggest replacements for the stock palio battery.
Sorry if there has already been a post on this topic.
I understandthe cells weree dry because the Service centre forgot to put water in them...this was the case with my Uno too....horrible service by Fiat
Old 5th May 2006, 18:59   #43 (permalink)
DRC
DRC's Avatar
@kb100; and IF you want to go in for a boosted electrical setup, there's nothing better than a second battery from the boot. but like i said, connections should be proper, in series, and the alternator should be beefed up.
By stand alone, I meant, there is no other battery, in the hood either.. If the battery is replaced to the boot, there are transmission losses (RI), which causes more drop of voltage at teh starter.
Did you mean, beefing up the alternator = to 24V, putting the batteries ion series means, a 24V setup...
__________________
Old 6th May 2006, 11:34   #44 (permalink)
Guys ...It depends on what battery they are currently using whether it is "Zero Maintenance"(Amaron) or Exide -Which needs topping up once in 45 days depending on usage..To gain maximum life out of a battery is to check the charging system once in 30 days.i.e the car's alternator which is heart & soul of the vehicle ,as new generation cars are fitted with MPFI they require correct voltage and current for their ECM's to run...
On battery maintenance:
Any ordinary battery requires water (Distill water) as they are subjected to heat and vibrations and due to reactions within battery during operation they loose water...To say in commom man language Any chemical reaction leads to heat thus it needs a coolant to perform better ...Hence water is the coolant....Unless the battery is an Amaron which does not require top up in its life span as it comes packed with Silver Alloy to eliminate heat.
But any battery has its limitations ..If the charging system fails it results in discharge of battery or worse permanent damage..
To improve battery life one has to follow these tips
Check the voltage pumped out of the alternator by measuring voltage across battery terminals using a Multimeter...
With NO LOADS( No Aircon/Headlights) it should be 14.00 +/- 0.20 Volts
with ALL LOADS( With Aircon/Headlights) it should be 13.80 +/- 0.20 Volts ..
This is in ENGINE IDLE condition . When the revs are increased more voltage/current is produced cutting off at 14.50 Volts respectively....
Overloading the alternator beyond the capacity of the alternator (i.e current rating) can reduce the life of the battery...If the vehicle is subjected to heavy loads it is wise to increase the capacity of the alternator to improve the life of the battery....Just by increasing battery capacity it would not add any value..IT IS JUST A MYTH..
For more u could call and talk to me at 9841019624
Mridul
mridul is offline   Reply With Quote
Old 6th May 2006, 21:08   #45 (permalink)
It must have been the alternator then also, Exide although is expensive but its no match for any other battery...! Quality/Life/Replacements..Exide have been almost no issues...! Amaron and SF would be a second choice...!
__________________
Thread Tools
urgent...battery needs replacement, what brand?? clipto333 Ask the Gurus 50 14th August 2008 15:31
Sub Replacement overdose14 Ask the Gurus 27 23rd January 2008 22:31
Signs that battery needs a replacement sreenivass Technical Stuff 23 11th April 2007 18:52
Engine Replacement sivankutty Technical Stuff 4 2nd September 2006 20:56
2 Din replacement kb100 Ask the Gurus 6 2nd March 2006 10:06
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
