Old 5th June 2007, 14:07   #61
Rtech's Avatar
Thanked: 212 Times
No. Needed the battery urgently, so got the Amaron installed.
Old 5th June 2007, 14:09   #62
Thanked: 87 Times
Robin, I'm using a couple of Aamron din74's, and they are better than exides.
price should be max 6400. check with their dealer opposite bengal chemicals at prabhadevi. or also can check with Rajesh at pump below mela flyover,, can give my reference.
scooby05 is offline   Reply With Quote
Old 5th June 2007, 14:14   #63
Thanked: 87 Times
just checked mrp 7620 less 7.5%
neway youve already fiited it, sorry for late response.
Old 5th June 2007, 14:45   #64
Rtech's Avatar
Thanked: 212 Times
Yup. Battery fitted last evening. Still awaiting word of the final cost as they (Four Seasons) haven't told me what they're going to charge just yet.
Old 12th June 2007, 11:24   #65
shuvd's Avatar
Question Urgent! Help!
Hello all.
My 1.8 Octavia's Exide needs replacement. It lasted for 25 months. I have a low ICE setup (Pio 7950UB/Pio 4ch amp/GTO 607/Pio 6x9/JBL BTX250 Bass tube). I recently got a pair of 6000k HIDs.
So, Gurus please recommend a new battery for my ride.
Thanks in advance.
shuvd is offline   Reply With Quote
Old 12th June 2007, 12:24   #66
wolfinstein's Avatar
You're going to get varied opinions here, Some love the Exide, some the Amaron, and Some the Bosch..!
Amaron Markets well than Exide..But Exide still is the most preferred battery as OEM's for Car Companies.
wolfinstein is offline   Reply With Quote
Old 12th June 2007, 12:57   #67
shuvd's Avatar
As if i was not confused enough! All cars in our family have Exide. Some run fine, some have problems. But, I'm willing to experiment. On the forum, general consensus seems to be Amaron. What would you suggest considering my requirements?
Old 12th June 2007, 13:03   #68
Exide...Naturally! I don't find any loosing points against it, I've had my share with Amaron too, But will still go with Exide.
Old 12th June 2007, 13:05   #69
Have you checked for Panasonic, in my tests, they have performed the best.
Gurkha is offline   Reply With Quote
Old 12th June 2007, 13:10   #70
Thanked: 43 Times
go for OEM. The price is right, and besides Skoda garage cannot accuse you of not following their recommendations.
filcord is offline   Reply With Quote
Old 12th June 2007, 13:47   #71
.anshuman's Avatar
Thanked: 8,928 Times
I m so disappointed with Exide batteries that i switched to amaron 48 month warranty batteries on both my cars,and to my experience amaron has been performing superbly,i have 2 mono amps on my car and they put quite a load on battery,ive hear ICE at fairly high volumes without engine on still never faced any issues ever,its been 2 years since i got this battery on accent.
Old 12th June 2007, 23:08   #72
aZa
aZa's Avatar
Thanked: 17 Times
yep i shifted to Amaron pro batteries too! Working like a charm now
Old 26th June 2007, 16:11   #73
Rtech's Avatar
Thanked: 212 Times
Just to update, I paid Rs.6,750 (inclusive of Tax) for the Amaron DIN74. MRP as mentioned by Scooby is Rs.7620.
Old 8th June 2009, 03:15   #74
Ravveendrra's Avatar
Thanked: 404 Times
Default Amaron Pro for Laura
I fitted an Amaron Pro battery into my Laura last week. It cost me rs.7,800/- and comes with a 30 month replacement warranty and a further 30 months of discounts on replacements.
The model is DIN74 and the Ah rating is 75.
Cheers,
Ravveendrra is offline   Reply With Quote
Old 8th August 2009, 10:52   #75
Abbas's Avatar
Thanked: 27 Times
Hey Guys !!!
Is there any way to check in a DIY way weather the batt is drained and has no other issues. And after you give it to charging, They generally take a whole day. So, when you go to take delivery, how do we confirm that its fully charged. Also, most of the time when we give it for charging, they generally say that the batt is gone and you need to replace it, so that they could get a bigger sale.
I got conned in the same way once in bhopal when i was driving from vizag to delhi. I bought a new batt just because the shop keeper told me i need to. When i cam eback to vizag and gave my old batt for charging, they said it was all fine, just needed a charge.
So, how do we save ourselves from getting conned? s there any simple method we can have a check ourselevs.
Abbas is offline   Reply With Quote
Battery dealer installs 3-wheeler battery in my car!! Now what? Soumyajit9 Technical Stuff 29 19th December 2016 11:06
PICS: SF Sonic Battery Factory. Detailed report on the making of a Car Battery S2!!! Technical Stuff 29 16th April 2016 11:39
Replacing Existing Battery with a Cummins Shakti Truck Battery? condor Technical Stuff 12 25th November 2010 15:29
Battery question - Can I use Indica Spec Battery in Scorpio, or other such swaps? shekharlele Technical Stuff 18 7th September 2010 09:05
Using a battery tender to revive discharged battery xxaarraa Technical Stuff 2 14th May 2008 19:56
