Closed Thread
Thread Tools
Old 27th April 2006, 10:46   #1 (permalink)
bruce's Avatar
Default Baleno power difference
Hi Friends,
I need a technical input regarding Baleno's power difference.
I heard the EURO-III version is 91bhp@6000 RPM , but the earlier version like the 2003 one is 94 bhp.
Is this true?
If it is what are reasons for reducing the power of the car, by EURO norms?
TIA
__________________
Bruce
_______________________________________
If at first you don't succeed, skydiving is not for you!
bruce is offline
Old 27th April 2006, 10:52   #2 (permalink)
cooldude1988765's Avatar
Yes it is true and it is because of the euro3 emission norms.
cooldude1988765 is offline
Old 27th April 2006, 11:28   #3 (permalink)
bruce's Avatar
Default What is it about the EURO3 norms?
IS there a technical reason why the drop in BHP is?
__________________
Bruce
bruce is offline
Old 27th April 2006, 11:43   #4 (permalink)
Team-BHP Moderator
Technocrat's Avatar
All the Euro -3 cars from MUL have 32 bit ECU while the E2 ones had 16 bit ECU. So this could be the reason, although it makes me wonder that why would an ECU upgrade decrease power, may be some other changes.
Also Euro 3 are not just emission norms itsa complet norm for vehicles whihc include emission levels as well.
For example of inclusion of headlamp leveling device in all E3 cars. Also in E2 the inclusion of separate high mount stop lamp are as per the norms guidelines.
__________________
180, 225, 150, ??? -> 159?
Technocrat is offline
Old 27th April 2006, 15:49   #5 (permalink)
Euro 3 are indeed emissions norms and nothing more. Their Indian version, (based on Indian driving cycle) is known as Bharat Stage III. Euro-III was introduced in Europe in 2000. (Euro-II in 1996 and Euro-I in 1992). India went Bharat-III (only in NCR and select cities) from 1 April 2005. Europe went Euro-IV from 1st January, 2005.
Norms like headlamp levelling device and centre stop lamp at the rear have nothing to do with emission norms. They are laid down in the rules framed under the Motor Vehicles Act. These rules keep changing from time to time. Many more changes are in the offing.
directinjection is offline
Old 27th April 2006, 16:00   #6 (permalink)
SUV
SUV's Avatar
Er ... I thought all the above combined with Emission Norms are "Bharat Stage III" .....
SUV is offline
Old 27th April 2006, 16:09   #7 (permalink)
venkatrx's Avatar
Originally Posted by bruce
Hi Friends,
Is this true?
TIA
Maruti salesman told that 94 bhp is @ 6000 rpm and 91 bhp is @ 5500 rpm...so nothing has changed itseems.
www.marutibaleno.com mentions 91 bhp @ 5500 rpm
[so i am not sure where you got "91bhp@6000 RPM" from?]
just have a look at this page, at the top para he talks about 94 and then in the spec he talks about 91 [observe the rpm at which the power is measured]
http://www.iloveindia.com/cars/marut...ti-baleno.html
__________________
Lexus IS 200, the best looking sedan of all times.
venkatrx is offline
Old 27th April 2006, 16:23   #8 (permalink)
mclaren1885's Avatar
It is indeed true that the BHP figures of the Euro-III baleno have dropped down to 91 ps from 94 ps .. However the peak power is now produced at 500 rpms lesser at 5500 .. Same is the case with the torque as well i guess .. Peak torque is developed at 500 rpms lesser ..
However against the company claims of 91ps , the E-III balenos feel more like they are putting out nothing more than 80 horses at the wheel .. V1p3r's and monish's baleno the two E-II that i have driven move way faster .. And im sure just 3 bhp drop in power cant make that much of a difference ..
E-III cars have much better ECU's .. Its difficult to fool around with them .. We tried removing the revv limiter on a E-III ECU and the revv limiter started kicking in at 20 , 40 , 60 km/hr ... However given the right set of tools these E-III ECU's have a lot of potential ..
Also something that we found out was the E-III's have a EGR valve which is absent on the E-II's .. Also , the cat con has been moved closer to the manifold and thus acts as a major restriction to the flow of exhaust gases .. These are the resons for the power drop in the Euro-III balenos .. Also there are two more mufflers to muffle the sound by a long margin ..
To overcome this , pyscho has disconnected the EGR valve and also removed the cat con and installed a free flow on my baleno .. The end muffler growls like crazy at anything over 1600 rpms , thus my shifts have now got down to 1500 rpms and with all the engine mods im still getting a mileage of around 15 ... This along with a brilliant headwork has just transformed my car into the next level of performance nirvana ..
__________________
I am proud of you, binzy boy !!! Keep up the good work.
mclaren1885 is offline
Old 27th April 2006, 17:04   #9 (permalink)
shuvc's Avatar
Wonder why popular feedback is that it is still feels quicker than the current crop of 100bhp cars .. are the other manufacturers overquoting their numbers ?
__________________
PIGZILNKILJBSCOMB
shuvc is offline
Old 27th April 2006, 17:21   #10 (permalink)
Could very well be true .. However , in the baleno E-III's its just that its been detuned to make it more FE .. The original bhp figures of 94 bhp can be easily achived by cracking the two problems mentioned in my previous post ..
__________________
Old 27th April 2006, 17:50   #11 (permalink)
frankmehta's Avatar
i wonder what a difference 3 bhp would make in the real world...
anyways a drop like that could easily be covered up by a k and n or a free flow...
frankmehta is offline
Old 27th April 2006, 17:53   #12 (permalink)
McLaren,
it is not 91 PS but 91 BHP (slightly more powerful). If the torque is produced at lower RPM, it should in fact perform better and not as 80hp car.
Are you saying that, due to E-III norms, the car is no more as powerful as it used to be? Samurai has E-III car, so he can comment as well.
Performance has been the USP of Baleno (along with brand name) and if Maruti strips it off, it will hamper sales. I would hate if this is true.
__________________
Drive fast, but drive safe.
RX135 is offline
Old 27th April 2006, 17:53   #13 (permalink)
balenopower's Avatar
AAAH...feels good i have 2000--2001 model...
__________________
Pedal to the Metal.....
wwwdotZigWheelsdot com
balenopower is offline
Old 27th April 2006, 18:04   #14 (permalink)
Default Have you noticed this from Maruti .... ?
When Bharat III Baleno was introduced, Maruti FAQ had this very enlightening
information (in fact it is still there in the Maruti Baleno site):
" Q: Will compliance to Bharat Stage III have any effect on the performance or
maintenance cost of the car ?
A: No "
In light of what we know now, does it not amount to spreading misinformation on
Maruti's part to sell cars ?
meerkat is offline
Old 27th April 2006, 18:29   #15 (permalink)
Originally Posted by RX135
McLaren, it is not 91 PS but 91 BHP (slightly more powerful). If the torque is produced at lower RPM, it should in fact perform better and not as 80hp car.Are you saying that, due to E-III norms, the car is no more as powerful as it used to be? Samurai has E-III car, so he can comment as well..Performance has been the USP of Baleno (along with brand name) and if Maruti strips it off, it will hamper sales. I would hate if this is true.
Thanks for correcting me RX , it is indeed bhp and not PS (too much confu with each manufacturer using a different term) .. Yes , the torque is produced at a lower rpm which certainly translates to better city driving but the car because of the restriction due to the cat con being moved closer doesnt revv quick enough .. That is the reason why it feels slow , specially once u drive a BS-II ..
Yes , i meant the BS -III cars arent as powerful as the BS- II's .. Performance has been the USP of the baleno , even the BS-III version is still capable of taking on the best in the segment in terms of performance and still keep ahead .. This drop in power is what psycho , monish and me noticed off lately and got down to eliminate this on my car .. Thought of reporting it here as well .. However the power might actually not be exactly down to 80 bhp like i quoted but certainly feels like .. But the car is certainly a tad slower than the BS-II's ..
Well , im not quite sure if maruti knows about this themselves .. We were testing a few cars for the drags redlining in each gear .. Thats when we figured out this difference .. Im sure with the change MUL would have expected a slight decrease but not to this extent , but i guess it wouldnt be easy for a common man to figure out unless one is into pure drag racing ..
__________________
Closed Thread
Thread Tools
difference between hydraulic and electronic power steering archat68 Modifications & Accessories 1 11th August 2007 19:46
difference between speed,power,xtramile,supershell and reliance petrols please? rider60 Technical Stuff 4 28th April 2007 18:27
Indica V2 Turbo : Power difference in DLS and DLG BunnyPunia Technical Stuff 7 20th April 2007 18:49
Power difference with Pete's box for Sumo/qualis apachelongbow Technical Stuff 7 12th May 2006 20:28
Difference between Power Screwdriver and Drill? sbasak Gadgets, Computers & Software 6 16th December 2005 21:37
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
