View Poll Results: I have TRIED it and have found that ...
It works wonders for my car/bike. I highly recommend it. 21 35.00%
Slight improvement, but I recommend it. 24 40.00%
No difference at all. Don't bother trying this non-sense stuff. 14 23.33%
It screwed my car!!! Stay away from acetone!!! 1 1.67%
Voters: 60. You may not vote on this poll
Old 21st April 2007, 02:01   #286
abhibh's Avatar
Thanked: 34 Times
2ml Per liter. Well i test drove Maniks car for good 10 KM with AC and car picks up very well @40 KM with AC after Acetone.
Old 22nd April 2007, 01:26   #287
manikjeet's Avatar
Thanked: 110 Times
ok let me now tell my view on adding acetone to my car the engine was smooth and silent and the car is pulling from 20 in 5 gear with a/c on my driver was saying it never use to pull below 40 in 5 th gear before
and i will say if you haven't added acetone to your ride do so what are you waiting for (waiting for me to come and add it for you kya)
manikjeet is offline   Reply With Quote
Old 22nd April 2007, 02:05   #288
abhibh's Avatar
Thanked: 34 Times
For people who may get a bit confused when maniks car speedo is showing 20 he is actually doing like 5 - 7 kmph more
Old 22nd April 2007, 02:23   #289
Hi all,
There is no second tought about the benefits of Acetone.Be it a new car or older one.Benefits are there.But it varies according to the condition of vehicle & many more thing.
It has been said that this tiny amount added in fuel improves the combustion and nothing else.Getting more efficient combustion is yet a far cry even for new generation car.
Combustion is not efficicient.If fuels burns totally then it produces water vapour and very less pollution but its not the case.Hence catalytic convertor came into picture that to at tail end.Our aim must be to reduce pollution from exhaust valve itself.Acetone helps in the way.
We can think of combustion as a two stage phenomenon.First when spark ignites in deminishing cylinder means when piston is going up & volume shrinking.Secons stage is when piston changes direction & moves down.Here cylinder volume is increasing.Now all flames that started during first stage must get lighted up till piston moves at Bottom when exhaust opens.If it happens so then full amount of fuel is ignited giving maximum energy and high torque with least pollution.
But the senario is so different.During second stage of combustion the flame front gets exhausted and near halfway it deminishes because of heavier fuel particles.Fule particles needs to be in very tiny sizes so that they vapourise easily.Air particles being lighter collides fast with light fuel molecules but those heavier one remains unburned giving loss of power.
Now acetone is one of slow burning liquid.It burns very slowly.When its added in tiny amount in fuels it tends to make combustion live till piston completes the power stroke and exhaust valve opens.Its during this stroke we need explosion to be alive till piston goes down.Acetone added fuels behaves in this manner making combustion ignited till exhaust opens.This is the delay in combustion.It never makes combustion fast as many thinks.This results in more heat energy used efficiently by fuel particles which normally gets carried away when exhaust opens resulting in pollution.
Thus we get full combustion hence increase in power which is nothing but result of total burn.
This is what I understood using this wonderful stuff.
Enjoy...........
finetuning is offline   Reply With Quote
Old 22nd April 2007, 22:43   #290
Default 1.8ml/lit
to the moderators!--
sorry for the missing letters in the posts,.
hi acetone buffs--
now as am trying with 1.8 ml/lit my consumption has shooted to 15kmpl...
now ill try 1.6ml/lit and give u the update!
the stale petrol actually gives better power with acetone-- may be with less volatile fractions already evaporated, more dense fuel will have higher calorific value !!
any experiences?
TURBOSAM is offline   Reply With Quote
Old 23rd April 2007, 18:52   #291
Hi TORBOSAM,
Thats very good...you mean to say you got 150 Km per 10 ltr of normal fuel from your earlier 130 km.....I m sure you will soon hit the nail.....you can continue testing in the same manner...I expect something around 1.2 to 1.4 passing you maximum benefit......once again thanks for sharing such wonderful result.....
This clearly shows how little variation in combination makes such difference....hence its advisable that every one finds their own combination......
I even tried as low as just 0.8 ml and found difference....
Enjoy...
Old 24th April 2007, 15:31   #292
Ravi Yadav's Avatar
I recently stated adding acetone. Earlier without acetone i used to get and average of around 15kmpl (highway+city). After adding acetone i have noticed the following changes,
1. The vehicle runs really smoother.
2. A slight increase in power specially on 3 rd gear.
3 .And the most important of all i have stared getting a FE of 18(highway+city).
I must say acetone does help and now i would like to go in for the boric acid treatment and will keep everyone updated on the findings.
Ravi Yadav is offline   Reply With Quote
Old 24th April 2007, 21:53   #293
Default welcome to acetone family!
hi ravi.
welcome to acetone family started by his highness fine tuning. for everyone's better understanding, lets start quoting the car and engine version when we state the figures , only if u dont mind!
Old 24th April 2007, 23:39   #294
manikjeet's Avatar
Thanked: 110 Times
latest mileage figures what alto return are 18+ haven't calculated properply
earlier it use to give around 14 max in city but now its giving 18+ in city with 25% a/c on
Old 25th April 2007, 02:05   #295
Thanked: 20 Times
please mention the quantity(ratio) of acetone used mr. ravi yadav
swathyd is offline   Reply With Quote
Old 26th April 2007, 15:34   #296
great ravi
i think fine tuning and kaiser should start cllecting hafta for such mind blowing fe figures!!! great!
Old 29th April 2007, 23:30   #297
Kaizer Sozay's Avatar
Originally Posted by TURBOSAM View Post
great ravi
Thanks for the suggestion, but just want to spread the good word around, If anyone has benefited from this thats thanks enough.
Kaizer Sozay is offline   Reply With Quote
Old 30th April 2007, 10:47   #298
Ravi Yadav's Avatar
Hi Turbosam,
I have a maruti 800 (96 model).I use 22 ml acetone per liter.I always use speed from bpcl. All the figures are without A.C. Don't have an a.c. in my vehicle.Hat' s off to finetuning and kaizer this wonderfull additive.
Old 30th April 2007, 23:58   #299
Thanked: 20 Times
hey finetuning,
Did u see what mr.yadav is using , 22ml acetone per ltr of petrol. !!!!!
Any comments on it.
Old 1st May 2007, 00:04   #300
Originally Posted by swathyd View Post
hey finetuning,
Any comments on it.
I think its a typo, im sure he must be using around 2.2ML
My Experience With adding Boric Acid in Engine oil finetuning Technical Stuff 426 19th November 2015 20:35
My Experience Of Adding Boric Acid In Petrol finetuning Technical Stuff 52 16th July 2013 20:16
My Experience Of Adding Xylene in Petrol finetuning Technical Stuff 61 19th February 2008 03:40
Does adding few ml of Acetone improve FE & performance? finetuning Technical Stuff 7 27th March 2007 20:36
