Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
View Poll Results: I have TRIED it and have found that ...
It works wonders for my car/bike. I highly recommend it. 17 36.17%
Slight improvement, but I recommend it. 21 44.68%
No difference at all. Don't bother trying this non-sense stuff. 9 19.15%
It screwed my car!!! Stay away from acetone!!! 0 0%
Voters: 47. You may not vote on this poll
LinkBack Thread Tools
Old 26th September 2008, 16:36   #436 (permalink)
Default More on acetone
Dear All,
Latest update on my Acetone trials .Distance travelled 194.6 km. petrol used 18.77 mileage 10.36 km pl.
One significant info is that the vehicle is able to go at lower speeds on higher gear ,for example on 5th gear I am now able go down to 45 kmph speed.I think this was not the case before, eventhough I am not too sure as I did not try it before.
Do you guys think it would run better if I add PIB.
Hi hexane is offline   Reply With Quote
Old 26th September 2008, 19:31   #437 (permalink)
Its difficult to source pure PIB but indirectly available through engine oils.Most of oils contains it in varied %.best source is using few ml of 2T oils per ltrs of fuel.It will difinitely add to benefits like smoother running,better power.
finetuning is offline   Reply With Quote
Old 16th October 2008, 17:40   #438 (permalink)
Default long time!!
indica <taxi.... from 17 -19 kmpl to 23-25 kmpl...
palio d...>1.3 mjd... 22 kmpl to 29 kmpl.... 1.12 ml per lit..
thanks fine tuning.... c ya
TURBOSAM is offline   Reply With Quote
Old 16th October 2008, 18:10   #439 (permalink)
DueLLeR's Avatar
Acetone in Diesel? I thought this thread discussed only adding it to Petrol. My two cents on this - Diesel, as a fuel, has a very high flash point. The fuel ignites with the high compression ratios rather than a spark. Acetone, as I know of it, is a aromatic hydrocarbon like Petrol, and volatile on top of that. Any amount of Acetone in Diesel would effectively bring down the flash point of the mixture (compared to pure Diesel) and could cause the cylinders to 'fire' before completing the compression stroke. Wouldn't this affect the timing of the engine and wreck havoc with the power delivery system?
Also, I doubt how well Acetone would mix with Diesel, Acetone being volatile and Diesel being oil-like. Would they even mix?
Cheers!
DueLLeR
__________________
"Diamonds for women, wheels for men. That's the way He planned it in Eden."
2004 Zen VXi | 2006 HH Karizma | 2008 Fiat Palio SDX
DueLLeR is offline   Reply With Quote
Old 16th October 2008, 19:58   #440 (permalink)
gd1418's Avatar
I dunno about this Alchemy, but acetone mixes very well with diesel, at least visually. Secondly the ratio is quite less to cause any major effect on the firing. I've been using for quite long without any issues till date. Of course the power delivery & smoothness improved considerably.
Cheers!
DueLLeR
__________________
Royal Enfield Bullet 1962
All Black 1998 Safari 4x4
All Black 2004 Scorpio GLx
Old 17th October 2008, 15:43   #441 (permalink)
K a s h's Avatar
I have been watching this thread for sometime now and have done some reading outside this forum also. In spite of all the discussions and conclusions that this is a myth (The Great Gas conspiracy), I have decided to give it a try and find it out for myself.
Can someone tell me where I can get acetone in Bangalore ?
__________________
K a s h
2006 Hyundai Getz 1.3
2003 Yamaha Rx135
K a s h is offline   Reply With Quote
Old 20th October 2008, 10:45   #442 (permalink)
I brought from Trust medical store, in Koramangala 1st block.
ashlyak is offline   Reply With Quote
Old 20th October 2008, 15:02   #443 (permalink)
maestro's Avatar
Acetone is an effective solvent for many substances, including some paints. It also can cause deterioration of rubber which is usually found in the fuel system (hoses, disc valves in filters etc). Considering this, I would not like to use it on my vehicle. I was reading some years back that using acetone caused massive corrosion of the combustion chamber surfaces.
maestro is offline   Reply With Quote
Old 2nd March 2009, 13:14   #444 (permalink)
Default xylene plus 2Toil
Dear All,
I am back with another round of testing. This time I tried to use the combination of Xylene and 2T oil.2ml(of the mixture) per litre of normal petrol. I have been driving around for three months(2000km per month) and I am getting between 10.3 and 10.6 km per litre.The significant difference noticed as compared to using acetone is that increase in power is not felt eventhough the engine runs smooth.
I have tried driving other Corrollas' to check the difference. The obvious thing one can notice is the smoothness of engine and pick up is much better.
My next experiment is ,I want to use 2ml of acetone(to improve acceleration) along with 0.5 ml of xylene and 0.5 ml of 2T oil.I am thinking of using castrol 2T, I guess the quality of Castrol(PIB) is much better than other PSU grades,any thoughts on this , I think I will optimise with this ratio.
Will get back with results.
Old 2nd March 2009, 15:05   #445 (permalink)
Raccoon's Avatar
But why are you comparing them with PSU 2t oils? There are many other good/better brands to choose from - Veedol, Gulf, Shell, Motul, etc.
Your best and safest bet might be the fully synthetic from Motul... like I'v mentioned somewhere before. Supposed to burn the cleanest. But its pricy.
Btw, whats the source of your info that Castrol 2t contains PIB? They havent mentioned it anywhere, AFAIK. The only brand that mentions the use of PIB is Veedol.
Raccoon is online now   Reply With Quote
Old 7th March 2009, 15:51   #446 (permalink)
Default Pib
I really do not remember where I got it, but during my initial years in R&D when we discussed about usage of 2T oils ,low smoke ,low friction oils were requiring usage of PIB,if my memory is right at least 25%.Since all these newer oils are conforming to JASO FC which is a low smoke spec,I am assuming these oils should have PIB or other synthetic oils as an ingredient.
Old 5th August 2009, 18:18   #447 (permalink)
neoonwheels's Avatar
Can anybody tell me from where can I get PURE acetone in Pune? As TurboSam sais, he got 32% pure acetone in a 100% pure labeled bottle from chemist, so wondering if I can source it from somewhwre else in Pune.
__________________
NeoOnWheels
FIAT Grande Punto MJD Emotion Pk | Mar 2010
FIAT Palio 1.2 Sport | Apr 2005 - Feb 2010
neoonwheels is offline   Reply With Quote
Old 6th August 2009, 06:11   #448 (permalink)
TRAUMASURG's Avatar
Yes you may feel that it is giving you better mileage but in the long run it is going to give you a major headache .Acetone does dissolve the rubber hose ,seals and gaskets so be prepared for a major expense down the road.Do a google search on acetone and gasoline you will find articles both pros and cons
TRAUMASURG is offline   Reply With Quote
Old 6th August 2009, 08:49   #449 (permalink)
archat68's Avatar
2 ml of acetone in 1 liter of petrol means 0.2% acetone. Acetone in this concentration can not harm rubber and plastic components.
Pure acetone (100%) does but 0.2% does not. It's science.
archat68 is offline   Reply With Quote
Old 6th August 2009, 09:10   #450 (permalink)
Live To Jive's Avatar
Ask at some school or college who the supplier for lab chemicals is. They will be able to give you the details. Otherwise ask your wife. She probably uses it to remove nail polish.
Live To Jive is offline   Reply With Quote
Thread Tools
My Experience Of Adding Boric Acid In Petrol finetuning Technical Stuff 51 17th December 2009 04:32
My Experience Of Adding Xylene in Petrol finetuning Technical Stuff 61 19th February 2008 02:40
My experience with adding a new Battery in my car Sam Kapasi Technical Stuff 18 14th June 2007 14:41
Does adding few ml of Acetone improve FE & performance? finetuning Technical Stuff 7 27th March 2007 20:36
Powered by vBulletin
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright ©2000 - 2010, Team-BHP.com
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653
