View Poll Results: Is Fuel Injection really such a great boon?
Yes, we're much better off without carbs and mechanical induction. 39 90.70%
No, carbs were cheaper to own, maintain and tune and gave us similar power and FE. 4 9.30%
Voters: 43. You may not vote on this poll
Old 5th May 2006, 17:59   #46
DRC
DRC's Avatar
Thanked: 48 Times
Originally Posted by Psycho
Well all these features are available with the aftermarket ECU's. The market today does not require a manufacturer to even be compliant to OBD2 for a user of a car to realise what is wrong with their cars based on the fault codes however worldwide OBD 2 is becoming mandatory. This could help consumers.
But at the same time access to modify ECU's are still limited to chip burning and tweaks. So if one feels the need to have a better control over their vehicle it is always better to have an aftermarket ECU / Piggyback unit connected to control the car.
I am thinking can we build our own ECU.... We will have full control
DRC is offline   Reply With Quote
Old 5th May 2006, 18:51   #47
Psycho's Avatar
Thanked: 95 Times
RD Karthik is already doing it, Megasquirt V3 also looks really promising.
Old 5th May 2006, 19:01   #48
DRC
DRC's Avatar
Thanked: 48 Times
Whooav!!!! I too join the team....
Old 8th May 2006, 21:59   #49
Mpower's Avatar
Thanked: 1,687 Times
Originally Posted by directinjection
When Indica was launched, its petrol version came fitted with a carburettor and developed (if I remember correctly) 60 or so BHP. When Indica 2000 was launched in 2000 with an MPFI version of the same engine, the power went up to 75 and then again to 85 in the Indigo/Cityrover version. The increase in power was obtained while still retaining the two-valves-per-cylinder configuration. So, it is probably wrong to attribute Esteem's power hike only to the four-valve set up.
Gee thanks Directinjection !! Someone already pointed that out before you. And I also replied to it as well in post #19.
How much do you commute every day? And how much time does it take? sbasak Shifting gears 112 26th December 2017 20:14
NHC:We want it,We will give it,We can't give it,Again,We have it,Will give it ,Got it joecherian Test-Drives & Initial Ownership Reports 18 6th April 2009 19:50
Does Maruti Swift really deserve this much HYPE ? mangywarez The Indian Car Scene 197 4th September 2006 13:12
