Old 18th October 2012, 00:32   #1
gaurangsaini's Avatar
Post Steer-by-wire hitting the roads - bad news or bad news?
Drive-by-wire tech introduced back then made throttle response precise. Ideally, steer-by wire should make steering response/handling sharper. Sadly, this most definitely means that the only connection between the driver and the tarmac will get snipped. Sad times ahead
http://www.bbc.co.uk/news/technology-19979380
gaurangsaini is offline   Reply With Quote
Old 18th October 2012, 10:39   #2
Rokztar's Avatar
Thanked: 35 Times
Default Re: Steer-by-wire hitting the roads - bad news or bad news?
I wouldnt be so quick to draw a conclusion.If the feedback is electronic it can be made to feel like anything ones heart desires.
More info here
http://www.autoblog.com/2012/10/17/n...y-wire-system/
Rokztar is offline   Reply With Quote
Old 25th October 2012, 18:58   #3
vinair's Avatar
Thanked: 976 Times
Default Independent steering system
Is this another gizmo or is there a real time need for this technology??
read on - http://autocarpro.in/contents/NewsDe...=1&NewsID=1854
vinair is offline   Reply With Quote
Old 25th October 2012, 23:25   #4
dutta_d1's Avatar
Thanked: 35 Times
Default Re: Independent steering system
Nice technology. Probably the "ABS" of steering. But in a quick glance, seems more prone to failure too. Probably will take some time to getting used to.
Also not sure how good it would work in India, especially with the camera system as Indian roads are not so cleanly built or marked.
dutta_d1 is offline   Reply With Quote
Old 27th October 2012, 21:13   #5
Thanked: 2,404 Times
I wonder if it will be legal in most countries. An old world (ie mechanical) backup system is required for all safety related items if the primary actuation means is electronic.
Sutripta
Sutripta is offline   (2) Thanks Reply With Quote
Over and Under steer and how to tackle them. Tom Technical Stuff 31 26th July 2011 10:47
Torque Steer McLaren Rulez Technical Stuff 44 1st September 2009 16:53
