Old 2nd May 2006, 19:22   #1
extreme_torque's Avatar
Thanked: 1,489 Times
Default Problem with Palio 1.2... Help!
Hi Guys,
I am having a peculiar problem with my Palio 1.2 (Pre NV). Going at constant speeds (approx 60-80 kmph) the engine coughs sometimes and looses power, it behaves as if the fuel supply got cut for an instant, when i press the accelerator padle at that moment further nothing happens, but everything returns to normal in 2-3 seconds. The mileage is 8-9 kmpl with AC on most of the time.
What could the problem be?
Do i need to clean the injectors?
Hw do i make sure that oxygen sensor on my car is working fine?
IS there anything wrong with the engine?
Lavkesh
extreme_torque is offline   Reply With Quote
Old 2nd May 2006, 23:20   #2
nitrous's Avatar
Thanked: 285 Times
Check ignition coil. One/more of the plugs is not firing.
Old 2nd May 2006, 23:33   #3
a4_attitude's Avatar
I believe fuel injectors need cleaning
a4_attitude is offline   Reply With Quote
Old 3rd May 2006, 13:38   #4
Iknowthisguy's Avatar
At the outset it does seem to be a problem with your fuel supply. First change your fuel filter & try to replicate the issue..if it still persists then go for injector cleaning.
Iknowthisguy is offline   Reply With Quote
Old 4th May 2006, 13:11   #5
Will go to service center this sunday. Just wanted second opinions so that service guy cannot cheat me.
Old 4th May 2006, 13:17   #6
mohit's Avatar
Thanked: 125 Times
I second this. I faced a similar problem where my 800 would suddenly show the symptoms you described. Was finally traced to a damaged plug cable.
mohit is offline   Reply With Quote
Old 4th May 2006, 13:43   #7
When the problem happens do any of the warnings lights on the dash board glow? As Nitrous said, it could be the ignition coil or it could be a problem with the alternator if the battery light glows.
5u3zEr0 is offline   Reply With Quote
Old 4th May 2006, 14:11   #8
No warning light glows as such. Is there a flat spot somewhere in the 1.2's rev range... coz after a certain point when i press the accelerator there is a sudden step up in power.
Old 5th May 2006, 09:02   #9
Rehaan's Avatar
Thanked: 25,042 Times
Hi extreme_torque,
Sounds like a problem i once had (My Accent ECU "hangs" occasionally), which finally turned out to be a burnt/shorted wire on my fuel pump.
cya
R
Battery problem or starter problem or....?? Srinivas Technical Stuff 21 16th June 2017 14:06
Caliper Noise Problem - Common Problem But No Solution Yet vigsom Technical Stuff 48 17th July 2014 19:55
Help me diagnose the problem in Palio 1.2 ELX extreme_torque Technical Stuff 45 18th December 2009 12:01
Swift 2nd Gear Problem EDIT: Now first gear problem BUSA Technical Stuff 85 2nd September 2009 18:47
NHC - BullKit Problem :EDIT: now detected to strut problem ibcool Technical Stuff 13 9th September 2007 12:02
