Old 5th May 2006, 13:15   #31
venkatrx's Avatar
How can we know, if the compressor is ON or OFF? as i have heard the compressor, switches on and off as it happens in a refrigerator.
venkatrx is offline   Reply With Quote
Old 5th May 2006, 13:20   #32
Good question. When we are driving it is hard to tell when the compressor is on / off but during idling we can sure make out from the sound of it and also from the rpm going high.
Ajay is offline   Reply With Quote
Old 5th May 2006, 13:20   #33
ivor's Avatar
In my Swift, I find it difficult to figure out when the compressor has cut off, but on my old carb Zen it was very simple. The engine would feel like it had suddenly been cut loose. It was audible too as one could no longer hear the AC compressor when it had cut-off.
ivor is offline   Reply With Quote
Old 5th May 2006, 17:47   #34
Thanked: 54 Times
Sorry, greatmana2000 but the engineer makes far more sense than your explanation, which seems to be referring to auto climate control.[/quote]
Well,may be my understanding of the laws of physics is bad ... hmmm
Laws of physics are the same for auto climate control or for an aircon ..
Old 16th May 2006, 08:37   #35
Thanked: 61 Times
Default The big question still unanswered .
Dose runnig the AC at low increase milage ???
I feel the engine loses less power if the fan is at max and the AC is at Minimum ?? And the cooloing is alos good .
Please commect.
bhogalrajnish is offline   Reply With Quote
Old 16th May 2006, 11:40   #36
humyum's Avatar
Thanked: 2,502 Times
In my maruti 800 while we are crusing on the highway at say 80 km/hr with the ac on u can actually feel that the compressor has cut off as the speed automotically increases to say 90 or 100 with the pedal pressure kept constant when it was at 80.I have noticed this many times and the compressor used to cut even when the blower was on full blast.
Old 16th May 2006, 18:16   #37
revharder's Avatar
Thanked: 49 Times
Please commect.
the moment compressor turns-off automatically, you'll find good power and when its runnning, you'll get less power.
when AC is at min., the compressor will cut-off very quickly and will also get ON very quickly too.
try to manage the cooling efficiency firstly by the blower speed and then by AC's temperature.
it is just a practice which i follows, no hard and fast rule as such!
revharder is offline   Reply With Quote
Old 16th May 2006, 23:27   #38
Maneesh's Avatar
Question Fuel consume /hour
Hi,My car is Lancer LxD.I have a doubt with its fuel consuming.I mean ,how much fuel is consumed by the engine / hour(Not moving ), in a steady 800 RPM idling?
Maneesh is offline   Reply With Quote
Old 19th May 2006, 11:40   #39
Good advice.. thank u
prakash2757 is offline   Reply With Quote
Old 22nd May 2006, 01:46   #40
Thanked: 157 Times
In my Baleno I have never been able to tell compresson on off cycles...probably it stays on all the time when the AC is on
Buffetfan is offline   Reply With Quote
Old 22nd May 2006, 01:51   #41
karthik247's Avatar
Thanked: 16 Times
Doesn't this auto on/off happen only in Climate Control AC's?? In the normal ones i guess u need to adjust it manually by switchin the AC on or off.
One way to know if the compressor is on is by starting the car and switching on the AC, cuz when the compressor works there will b a rise in engine RPM.(arnd 100-200rpm).
karthik247 is offline   Reply With Quote
Old 24th May 2006, 19:46   #42
In baleno I can make out cut-in and cut-off while idling (due to changes in rpm and engine noise), but it is hardly noticeable while driving. May be during constant cruising it can be felt (never noticed that). One thing is sure that the effect of AC (on performance )is very less for this car.
santosh.s is offline   Reply With Quote
Old 24th May 2006, 23:48   #43
2fast4u's Avatar
with my 15 yr old nissan i dont feel power loss maybe 10% which is not noticeable but it surely guzzles more fuel maybe 25% more than without the AC. and in this oldy there is still the cutout happening on / off i believe it has to be a thermostat.
what i feel cars with bigger engines will not face much of engine power loss with ac on than the cars with smaller cubic capacity.
2fast4u is offline   Reply With Quote
Old 2nd June 2006, 20:06   #44
Thanked: 157 Times
agree..while parking you can tellbut while driving a bit difficult
Old 26th March 2008, 23:11   #45
praveen_v's Avatar
Thanked: 120 Times
Default how to use the aircon optimally??
Note from Mod - Threads merged
I am having a confusion on how to use the aircon in the car optimally, giving sufficient cooling while having minimum impact in the fuel economy. I searched for the topic but my keywords did not bring any suitable matches.
Generally people (including me) keep the a/c temperature knob at max cool and so the aircon runs continuously loading the engine all the time. I dont think the aircon will cut off if kept in max cooling position since it can never cool so much in summer.
So inorder to acheive sufficient cooling and save some fuel, can I lower the temperature knob to some lower level (say 60% cooling) so that the compressor cuts off once the temperature is reached?? What's causing the confusion to me is, some people say that frequent cutting off and switching on of compressor will kill it. is that true??
praveen_v is offline   Reply With Quote
Car Aircon: Unicool Car Aircon, Ghatkopar (W) parsh Mumbai 26 18th August 2017 00:47
Real world fuel economy ratings - Peugeot, Citroen and DS take the lead volkman10 The International Automotive Scene 5 29th March 2017 19:07
Aircon Repair & Service - Correa Car Cool (Malad, Mumbai) StrangeWizard Mumbai 2 24th December 2013 01:42
Declared Fuel Economy of 2 & 4 Wheelers nick17s The Indian Car Scene 2 31st May 2010 16:04
