Thread Tools
Old 26th March 2008, 23:21   #46 (permalink)
toiingg's Avatar
Reduce the blower speed to 1 or 2 (once its cool inside) and let the ac run continuously. Let the temperature knob be at max cooling.
__________________
tong-tong
toiingg is offline   Reply With Quote
Old 26th March 2008, 23:22   #47 (permalink)
esteem_lover's Avatar
Plenty of threads on this praveen. Honestly, can you drive with anything less than max in chennai summer (which is always) ? Even if it is cold, the atmosphere inside the car when only the blower is working is intolerable. Moreover i do not think you save anything worthwhile. Maybe you can sweat it out & get yourself a cone ice cream from the wayside with the money that you saved.
__________________
If you can use, some exotic booze,
Theres a bar in far bombay
Come fly with me, we'll fly we'll fly away -
Frank Sinatra
esteem_lover is online now   Reply With Quote
Old 26th March 2008, 23:29   #48 (permalink)
praveen_v's Avatar
Hehe.. I agree chennai summer needs full aircon. BUt even in winters, i have never seen the compressor cutoff with the temp set at max cool. It gets really cold inside the cabin well before the max cool temperature. The thing is, if I can find my comfortable temperature and reduce the temperature accordingly, will it do any harm since the compressor will turn off and on frequently??
I was looking for some way to minimize the compressor usage (without turning off the ac ofcourse ) and still maintain a comfortable temperature
__________________
Anyone driving slower than you is an idiot, and anyone going faster than you is a maniac. ~Author Unknown
praveen_v is offline   Reply With Quote
Old 26th March 2008, 23:30   #49 (permalink)
Originally Posted by praveen_v View Post
What's causing the confusion to me is, some people say that frequent cutting off and switching on of compressor will kill it. is that true??
I don't think that it will kill the compressor. I have been switching off ac while overtaking and switch on immediately later on highway 100s of times (on non-4 lane NH4 few years before) and by now I am sure I would have killed it. Add to that automatic cut-off that happens even if the temperature hadn't dropped significantly in spite of knob position at the coolest level.
alto99 is offline   Reply With Quote
Old 26th March 2008, 23:35   #50 (permalink)
Actually toiingg has a point. when you set the blower speed to 1 or 2, then the air closer to the blower gets recirculated, which means that only the coldest air gets back into your blower, this would make the compressor to switch off earlier than otherwise.
here's another thread that discusses a similar issue http://www.team-bhp.com/forum/techni...old-start.html (Switching on Your AC in Cold Start)
__________________
Frank Sinatra
Old 26th March 2008, 23:42   #51 (permalink)
praveen, i follow this but i dont know wether it truely saves the fuel or not.. when ever i feel the load on engine(while i am overtaking an vehicle/shifting down to lower gears/slwoing down for some reason) i usually switch off the AC compeltely but with the blowers ON.
a.ashokdurai is offline   Reply With Quote
Old 27th March 2008, 08:32   #52 (permalink)
hrishig's Avatar
You can use ~80 - 90 % heat rejection films on every glass including the front glass.
This will definitely reduce the A/C usage and will improve mileage.
hrishig is offline   Reply With Quote
Old 27th March 2008, 08:39   #53 (permalink)
Like 2 drops per litre ? I am yet to hear of increased FE due to sun films. You want FE, turn the AC off & do not over rev.
__________________
Frank Sinatra
Old 27th March 2008, 09:04   #54 (permalink)
Well, yes it does help. Having a front windscreen film along with sun control films on all glass panels does help in getting better fuel efficiency.
try these two things.
1. Front windscreen film (Vkool/Llumar)
2. Use blower at speed of 1 or 2
sukiwa is offline   Reply With Quote
Old 27th March 2008, 10:46   #55 (permalink)
I used both options, but my FE droped by 2km/l by full usage of AC before the current full tank. Previously it was 11.5 kmpl, now its 9.5 kmpl. Wonder why, Probably, my run in is not yet over. Currently at only 1200 km in 6 month
lambuhere1 is online now   Reply With Quote
Old 27th March 2008, 12:37   #56 (permalink)
My minus 2 cents to this. How does turning the AC in heating mode (turning the knob to red) affect the FE? would it still load the compressor and affect pick up etc? i understand this heater is often used for windscreen defogging, right?
__________________
If you're incompetent you have to be honest, and if you're crooked you have to be clever.
harsha.cs1 is offline   Reply With Quote
Old 27th March 2008, 14:59   #57 (permalink)
trrk's Avatar
> reduce the temperature accordingly, will it do any harm since the compressor > will turn off and on frequently??
You can do this withou problems. Even in cars which I have used for long periods never had problems with the compressor as I have been using the AC the way you describe.
Though I don't remember the source now, I read long back about this. If your car is hot, you start off with the temperature knob in the maximum and the blower also in the maximum position (recirculation mode). Lower the front windows an inch or so for a couple of minutes and then put them up. When you feel it is cold enough, turn the temperature knob away from the maximum position in gradual intervals until you find the position you feel is comfortable for you. Beyond this it won't be comfortable anymore. If after a couple of minutes, you can try and reduce the blower speed again in steps. If only the front seats are occupied, a blower speed of 2 or max 3 (in a 4 speed unit) with the temperature knob at around 10 o'clock postion (when the max is at the left end as you look at the temp knob for most of the day.
When there are rear passengers the situation is different.
In my CVT, the temperature knob is usually around the 10 o' clock position with the blower at 2 when I am alone or only the front seats are occupied. If it is hot maybe a notch to the left is sufficient here.
The methodolgy is same for my Marina too!
You can try this. You can also check if there is mileage improvement. Temperature knob at maximum always makes the compressor work longer.
__________________
Rajesh
-Marina LS, Oct 05, 44223 (44771) kms, 13.94 kpl
-City CVT, Sep 07, 15423 kms, 13.23 kpl
trrk is online now   Reply With Quote
Old 27th March 2008, 23:54   #58 (permalink)
abhik's Avatar
Guys i appologise for my ignorance but why does everybody keep saying that the blower speed regulates the power of the air-con?
My understanding is the the tempature guage(marked my blue for cool going to red for hot)regulates the cooling and the power of the a/c. the blower(marked by 1.2.3.4 for speed) just regulates the fan speed. The cooling effect differs due to the speed of the cool air being thrown at you but the cooling power by the compressor remains the same if temperature regulator is constant in one position. So the blower at 2nd level(speed 2) or 4th level should not make a difference to FE. If the temperature regulator is adjusted then it should affect FE.
__________________
ABHIK
<<<If everything seems under control, you're just not going fast enough>>>
abhik is offline   Reply With Quote
Old 28th March 2008, 11:17   #59 (permalink)
The amount of air flown over the evaporator coils will be less, hence the heat transfer would also be less resulting into less rise in temperature of AC gas. Less rise in temperature of AC gas means cut-off of ac compressor and less usage of AC.
Old 31st March 2008, 15:56   #60 (permalink)
folks, still looking forward to hearing on the effects of turning the AC on heating mode? Thanks...
__________________
Thread Tools
Will A/C blower speeds affect the Fuel Economy? arunkumar_rec Technical Stuff 12 19th December 2007 13:07
Alto Fuel Economy Woes ScarySkulls Technical Stuff 148 11th November 2007 17:50
Does Weather Affect Fuel Economy wolfinstein Technical Stuff 33 14th June 2007 01:52
Electronic ways of IMPROVING fuel economy Godfather Technical Stuff 8 1st October 2006 08:50
Tyre pressure vs fuel economy sbasak Technical Stuff 15 27th February 2006 22:31
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
