| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #136 (permalink) |
| Newbie Join Date: Jul 2005 Location: Gurgaon
| So i got my holux GPSlim236 + destinator 6 + PDA mount combo this time on my trip to the US. I will be reaching back to delhi in mid october, which is when I plan to buy the Satguide destinator maps for delhi. The holux unit is really small - matchbox sized (much smaller than i expected it would be) and catches the gps signal really quick. I recommend it to anyone thinking of purchasing a gps receiver. The destinator software + US maps are also excellent, but the real test would be in india using the delhi/ncr map. |
| | #138 (permalink) |
| BHPian | hey netarchie..I guess any sunfilm would probably weaken the signal to the in built PDA GPS receiver..so,acquiring a fix would surely take much longer time than in a non-sunfilm car..(I mean non front windscreeen sunfilmed car).. I don't have front sunfilm on any of my vehicles..but do have side+rear films.. I would suggest you connect an external GPS antenna to your unit incase you wanna v kool your front windscreen buddy.. -sr
__________________ Driven by Dreams ! |
| | #139 (permalink) | |
| Senior - BHPian | Netarchie: My safari had a very dark film on the windows, rear & side glasses. And a very transparent film on the inside of the windscreen. Then I acquired a Garmin iQue 3200 GPS. This used to work fine inside the car when mounted on the winddscreen and used to find the staellites very fast. After getting challaned quite a few times for the dark screen I decided to go in for the 3M 33% film. The idiot at the accessories shop while removing the film also removed the windscreen film. I had to then get the 3M film installed on the windscreen. Eversince that, my GPS would not catch the sat from inside. I had to invest ina Rs.9000 external antenna from Garmin for the GPS. This now works like a beauty.. So, before you V-Cool, put a patch of the film just above where you fix ur GPS on the windscreen. try locally for a couple of days to see as to how fast or slow ur GPS gets the fix. After satisfying yourself then only go for the full filming of the screen. Or else invest in an external antenna. Quote:
| | #141 (permalink) |
| BHPian | Hi, I've started using my GPS receiver with my pocket PC and using mapking mpas for the same. I felt that these maps are not so accurate and moreover the area i live in (HSR layout) doesnt have much details for that area. I have however not been to other areas and just started using it for a day. I'll also try that with other areas and yet to learn / go thru the manual to see other features like routing and how to make use of fuzzy learning and stuff like that. I had one question about the maps for highways, what u guys using for highways and other places in karnataka? suppose if I plan a trip to couple of other districts in KA or TN, is there any map that can help me find the right route! thanks.
__________________ Ketan ======== |
| | #142 (permalink) | |
| BHPian | Quote:
__________________ To live is not just to survive, but to thrive with Passion, Compassion, some Humor & your own Style ! | |
| | #144 (permalink) |
| Team-BHP Support ![]() | http://www.arrl.org/tis/info/pdf/021...20for%20gps%22 This is a simple DIY antenna if you dont want to spend big $$ for external antennas.
__________________ Reclaiming.....! |
| | #146 (permalink) |
| BHPian | Found this site - www.mapmyindia.com ... Will be usefull for non GPS users also.
__________________ netarchie |
| | #149 (permalink) | |
| BHPian | Quote:
One thing wanted to ask - won't the front sun screen slowly get pulled off from the area from the area where the PDA GPS suction mount is stuck on the front windshield?..because the suction created when you put the GPS suction disc mount will surely be trying to pull on the front tint...right?.. cheers, -sr
__________________ Driven by Dreams ! | |
| | #150 (permalink) | |
| Senior - BHPian | I've been using the Garmin suction mount for the last one year on my Safari that has a windscreen sun-film by 3M. I have removed the mount only twice and no issues with the film getting sucked/damaged or removed. However, I had to remove the mount twice because had to install on a friend's vehicle for a demo. Otherwise the mount remains stuck at one place in my Safari..:-) Quote:
| Thread Tools | |
Similar Threads | ||||
| In Dash GPS/Audio Receiver | mav2000 | Product Discussions | 14 | 6th October 2008 12:48 |
| Tower Speakers for Onkyo receiver | hyper-VTEC | Gadgets, Computers & Software | 57 | 9th May 2008 14:29 |
| Things to know before getting a GPS system for your car | nishantgandhi | Technical Stuff | 4 | 31st January 2008 07:47 |
| Fully loaded Car receiver | morphean | Ask the Gurus | 18 | 2nd November 2006 13:57 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
