Old 8th August 2008, 16:14   #541
DerAlte's Avatar
Thanked: 2,879 Times
Originally Posted by harjeev View Post
... that would certianly take alot of time as though the data is not huge, but number of files is very large and that is what takes time.
... On practical usage, I use upto zoom 15 or 16 in the cities(Delhi) and 17 is used if i am trying to find something specific. And for northern india i use zoom 13, and find the level of detail to be ok.
Thanks, Harjeev. Let me try another run with your parameters, and see how it goes.
Old 8th August 2008, 16:56   #542
tsk1979's Avatar
Thanked: 16,420 Times
guys, I have option of buying a GPS device for around 120$. There are no maps in that, but it runs Windows CE, and has a Sirf Star III chipset.
Will I be able to buy software like destinator etc.,(windows CE compatible) for use with this device?
Old 8th August 2008, 18:30   #543
rajismine's Avatar
Thanked: 252 Times
yes u can. I have used destinator and its good. Which GPS u are getting for $120. Can u give details pls. I also need one
rajismine is offline   Reply With Quote
Old 13th August 2008, 12:52   #544
Guys, I'm a novice and I've no idea about this GPS reciever. I tried to read all the post in this thread but couldn't get much idea. My requirement is that I should be able to find my route in Bangalore and on highways. What should I purchase for this and what will be the total cost? Please let me know.
javed406 is offline   Reply With Quote
Old 13th August 2008, 14:18   #545
KSM-Vtec's Avatar
Thanked: 440 Times
Guys i am also facing a similar situation and hence i have some Questions-
Which is a good GPS to buy?
Which is the best service provider?
What are the costs involved and how accurate are the GPS services available here in India?
Will i be able to find my way within a city?
KSM-Vtec is offline   Reply With Quote
Old 13th August 2008, 14:22   #546
NetfreakBombay's Avatar
Thanked: 402 Times
Cheapest option is this (assuming that your cell phone supports bluetooth and is a recent model)
You need to buy:
1. Bluetooth GPS receiver (3.5 to 5k)
2. Navigation software, free to try. Cost varies with package, number of cities etc
Or you can buy Maps + GPS device for around 15k.
NetfreakBombay is online now   Reply With Quote
Old 13th August 2008, 15:53   #547
KSM-Vtec's Avatar
Thanked: 440 Times
How good are the services in terms of details. Well i have sony p990i.
You need to buy:
Old 13th August 2008, 15:56   #548
rajismine's Avatar
Thanked: 252 Times
Hmm..
So here is what I know:
1.) The best and most popular GPS Devices coems with Sirf Star III chipset
2.) If you want to take a GPS Mobile phone, it would be helpful if it has a-GPS i..e. assisted GPS which would use cellphone towers to identify your locationa dn that helps in locking your location faster.
3.) You dont need a internet connection for GPS :-)
4.) You can navigate easily in city and on Highways.
5.) For india, a win CE platform GPS system should do good because of more flexibility with maps
6.) I personally suggest a GPS phone like Asus P320 or Asus P526 which will cost 10K-11.5K and has GPS already built in.
7.) Maps would cost another 5K for licensed or FREE for Cracked versions
8.) I use an Asus P526 with All India Satnav Cracked Maps with destinator 7 software and its wonderful:-)
9.) A standalone GPS device can cost anywhere between 6K to 25K depending on the GPS Chip included, Brand, Screen Size, Warranty adn Maps
Hope this helps :-)
Rajeev
Old 13th August 2008, 17:09   #549
Thanked: 402 Times
I use Nokia'a built in maps. Maps are quite detailed for Mumbai/Pune.
For sony, you can try mapmyindia's software. For details, you can check that online at :
MapmyIndia - maps, directions, and local search across India - just search, print and go!
Maps seem fine for the areas I checked. They have 5 day trial.
Old 13th August 2008, 17:18   #550
tsk1979's Avatar
Navgo SY885 for 133$
It is sold by dealextreme based in Hong Kong
Old 13th August 2008, 21:14   #551
DerAlte's Avatar
Unhappy MGmaps in a messy state
After a lot of false starts, I managed to download map for Bangalore region with Harjeev's parameters. Loaded the map (MGMapCache) on to the N82 card. But ...
1. Storage on the card has really gone crazy >>
2. Storage on PC HDD is not THAT bad, but still doesn't make sense >>
3. Blessed thing keeps querying me (on N82) whether it should be allowed to access user data - a zillion times!
What / where have I done something wrong?
Old 13th August 2008, 21:24   #552
spadival's Avatar
Thanked: 16 Times
You need to install the signed version of mgmaps and set the file read/write permissions to "Yes, never ask again" or something like that. Note that this never ask option comes up only for the signed version of mgmaps.
spadival is offline   Reply With Quote
Old 13th August 2008, 22:45   #553
phamilyman's Avatar
Thanked: 3,526 Times
DerAlte, your symptom is typical of FAT systems with like 32 kb clusters. Comp would be FAT 32, which can take like 4kb even (techies please help).
basically you have these micro tiles in gadzillion numbers - since the minimum size of a file on your phone is much bigger than on hdd (say 32 kb vs 8 kb), so the 100 mb data actually resides in 900+ MB.
What can be done - techies to help
Old 14th August 2008, 09:32   #554
Thanked: 83 Times
DerAlte, which mobile phone will you be using for the GPS? I am using a HP hw6828 Windows Mobile phone and I am using a Hash Level of 1 and 256 tiles per file. I have all of India here upto level 17 and the total size is 340MB and the number of files are also manageable. You can try what works best for your phone in terms of speed and then stick to that.
SumitB is offline   Reply With Quote
Old 14th August 2008, 10:32   #555
DerAlte's Avatar
Thanks for the clues, guys.
Originally Posted by spadival View Post
You need to install the signed version of mgmaps ...
I downloaded directly on the mobile from mgmaps. I think there was a jar and a jad option, but I don't remember which one I downloaded (one of them had a problem, so I used the other one). Which one is the signed one?
DerAlte, your symptom is typical of FAT systems with like 32 kb clusters. ... What can be done - techies to help
Makes sense. I somehow need to reduce the number of files.
Originally Posted by SumitB View Post
... I am using a Hash Level of 1 and 256 tiles per file. I have all of India here upto level 17 and the total size is 340MB and the number of files are also manageable. ...
N82. That sounds like a good plan - let me download once again. Do you have Google or Yahoo India? How was the download 'experience'?
The current file count and size problem leaves the N82 in tangles. Mgmaps takes an aeon to load (for some reason it is not loading this morning; it was working last evening), never appears in the running apps list and generally slows everything else down.
In Dash GPS/Audio Receiver mav2000 In-Car Entertainment 16 1st April 2010 20:25
How to configure MireoPC edition with USB GPS receiver contactme27 Gadgets, Computers & Software 1 4th November 2009 21:56
Fully loaded Car receiver morphean In-Car Entertainment 20 26th July 2009 13:19
How To Use A Qstarz BT-Q1000P GPS Receiver with Ubuntu? Sankar Gadgets, Computers & Software 3 1st December 2008 20:05
