Old 26th December 2008, 16:23   #676
ask77's Avatar
sorry the quick post button got clicked accidently and i couldnt edit it quick enough . I have map my india wayfinder inav loaded software for symbian on my nokia n95 8gb . I find it quite useful , it has voice navigation as well as the map come preloaded and you dont need a gprs connection all the time also the license is transferable to other symbian device when i change my phone . the app. has life time license and free updates. the satguide software seems to be cheaper but i have not used it so i dont know how it compares with map my india inav.
regarding sirf iii chipset it is not necessary that all gps devices contain them because gps chipsets are being made by lots of chip manufacturers so you have to query whether the particular device has sirf iii some the chinese one are not that good . even the built in gps in nokia n95 takes at least 10 - 20m - min to lock from cold start while my gps bt module with sirf star iii takes hardly 1 min to lock. the sensitivity is also much better in bt module so that it can maintain sattellite lock even indoors. This is crucial when using gps in real time situations.
ask77 is offline   Reply With Quote
Old 27th December 2008, 17:37   #677
NetfreakBombay's Avatar
Thanked: 336 Times
What is your experience with inav? Specifically as compared to built-in Nokia maps navigation?
I mean things like UI, ease of use and finding places.
Old 27th December 2008, 18:39   #678
ask77's Avatar
Inav is much more user friendly and has much greater number of POI ( point of interest ) also it covers many more cities than nokia maps it does not require any gprs data unlike nokia maps which require some data download the only bit somewhat lacking is the voice navigation part where voice navigation instructions are more frequent and detailed in nokia maps than in Inav
Old 29th December 2008, 08:09   #679
vinaydas's Avatar
Thanked: 85 Times
well i have been using the n82 for a year now the connecting to a satellite will take you a long time and according to its maps kerala does not exist !! not even road maps or NH routes available for kerala but on the same time the google maps software for your phone is amazing!! but too bad it needs a net connection or a gprs connnection to start it up(to download the maps) it has detailed maps of most places in india.
vinaydas is offline   Reply With Quote
Old 29th December 2008, 08:55   #680
kailashnj's Avatar
Thanked: 275 Times
Originally Posted by rkbharat View Post
finally success
I manage to connect to internal GPS of my HTC with mgmaps, now this is turning out to be a very good tool as it gives me the freedom to download any area map. Very useful where I do not need directions but need to keep my track.
Attachment 77275
Attachment 77276
Try mgmaps for downloading maps and beelineGPS for logging your track. There are many other endless tools I can list down for your requirements
Hi
How did you get your internal GPS from HTC to work with MGMaps. I have been trying it since long but could not do it. Can you please provide step by step guide so that I can also enjoy free maps
kailashnj is offline   Reply With Quote
Old 29th December 2008, 11:00   #681
rkbharat's Avatar
Thanked: 608 Times
Ok here are the steps I followed.
I gathered following softwares first:
1. JBED J2me container, the one in HTC does not allow file reading.(http://forum.mgmaps.com/download.php?id=466). Thread Mobile GMaps :: View topic - Use JBed instead of IBM J9 on Windows-Mobile. There are multiple version in the thread, try the one I posted the link first. if it does not work, let me know and I will test the other version.
2. mgmaps 1.4 http://wap.mgmaps.com/14/mgmaps-1_41_03.jad :
3. GPSPort. To split the GPS data to mgmaps.
Steps:
a. first install jbed on your HTC.
b. Then install mgmaps(1.4 version). Start jbed, menu, Install(either Browser if you have Wifi or GPRS or Local files).
c. For the maps. use Map Creation Tool for MGMaps to point the download area and save .map file. Select the zoom level ar required. I downloaded upto zoom level 11 for all north india and zoom level 17 for delhi and chandigarh, and merged both of them. Also google maps work well.
d. Download http://www.mgmaps.com/cache/gMapMaker-setup.exe, and in there select cache folder and in operation mode select "MGMAps mode, use .map file".
e. Once maps are downloaded, folder structure should look like \maps\North India\MGMapsCache\GoogleMap_0
\maps\North India\MGMapsCache\GoogleMap_1
\maps\North India\MGMapsCache\GoogleMap_2
etc...
Here North India is the main root folder of the maps
f. copy maps to Storage card, in the root. prefer copying using the card reader instead of direct connection to htc as it will take lots of time.
g. Now open Jbed and then launch mgmaps.
It might give you alert like , mgmaps wants to access internet, say no to all sessions. (please make sure that it is not an alert like mgmaps wants to access 127.0.0.1, because you need to say yes to it, though it will come only after to set the stored maps on).
h. Go to menu/setting/maps/Stored Maps, Check Stored Maps and Offline mode. in the Stored map folder enter following:
Storage Card/maps/North India/MGMapsCache
Assuming you have following folder structure on the card
CARD/maps/North India/MGMapsCache/GoogleMap_*****
Save.
Then again go to Menu/GPS/Setup/Select Device/ and check the GPSGate radio
Save and exit mgmaps.
i. start gpsport, its just an executable, no need to install, put it some somewhere and link on today screen.
Set Input COM4
Set Putput 20175.
and hit start button.
j. now again launch mgmaps from jbed,
IMP: It will prompt to allow access to 127.0.0.1, for GPS data, allow yes to all sessions.
k. You are all done, to use it effectively here are some tips:
To move the maps as as per you current location.
Go to menu/settings/GPS/Mobile Tracking/
check Show marker
check Move Map
Hope this will help, let me know if does not works and error.
BTW bad news is that I lost my HTC last week , could not live without it as it was loaded to neck. good part is that I had a self destruct app install on it which do a hard reset on new sim unless I set it off. So all the data will be erased.
Bought ASUS P552W, with much faster processor, better GPS.
Originally Posted by kailashnj View Post
Hi
rkbharat is offline   (1) Thanks Reply With Quote
Old 1st January 2009, 21:15   #682
both are bluetooth gps receivers . the satguide receiver has sirf iii chipset which is the best chip for gps receivers . any software can be used with these receivers. You need a symbian based software from either map my india or satguide . I am using map my india inav loaded of map my india and find it quite
The mapmyindia receiver is also a sirfIII as per their website?
deepakvrao is offline   Reply With Quote
Old 3rd January 2009, 23:44   #683
DerAlte's Avatar
Thanked: 2,876 Times
I tried your process on HTC Touch (the original one), but was stymied by a couple of things:
* mgmaps says "This device does not support a file system" when I try to configure Stored Maps
* mgmaps says "This device does not have Bluetooth", whereas I have coupled a Holux device via Bluetooth and assigned COM6 as the port to it
What gives?
BTW, where do we get this "gpsport" executable?
Old 4th January 2009, 09:35   #684
ask77's Avatar
Yes on reading detailed specs for mapmyindia receiver seems to be sirf star iii
Old 4th January 2009, 10:57   #685
rkbharat's Avatar
Thanked: 608 Times
What version of J2ME container you are using?
I have not tired with Bluetooth GPS device. I will try to get hold of one and test it.I am sure you must have selected blutooth in GPS settings, bluetooth started etc etc
I downloaded it from mgmaps site, but could not find the location now. I can send it to you on mail if you want.
What gives?
rkbharat is offline   Reply With Quote
Old 6th January 2009, 19:55   #686
Thanked: 336 Times
Nokia maps + navigation just got better.
Nokia - Nokia Maps 3.0 with Maps on Ovi - Beta Labs
Now you can :
1. Browse and plan routes on PC
2. Some landmarks / buildings have 3D vector images. Not sure if any of Indian cities have that feature yet.
Old 7th January 2009, 10:01   #687
ask77's Avatar
Now you can :
will try this out and report back. lets see if they have improved data on Indian cities
Old 7th January 2009, 11:03   #688
ask77's Avatar
supports only S60 3rd Ed FP2 . my nokia n95 8gb is S60 3rd Ed FP1 device so it is not supported although the video on the site shows a fellow demonstrating the new software on a N95 8Gb they say update for fp1 devices are coming soon so will try it as soon as available
Old 7th January 2009, 12:01   #689
Thanked: 336 Times
With this version, you can try out maps on PC as well.
Mumbai maps have been updated and lots of buildings have 3D images. Gateway, BSE, Oberoi, VT and so on.
Old 8th January 2009, 19:07   #690
DerAlte's Avatar
What version of J2ME container you are using ...
Esmertek Jeodek - Build ID: 20070425.1.1, midp2.0/lockstream. (JBed is also from Esmertec)
This comes built-in - I even re-flashed the ROM and reloaded the mgmaps application. The "This device does not support a file system" error persists when I try to specify Stored Maps! :-( The application displays the map fine otherwise (network, over WiFi).
Could you send me the GPSGate on deralte (at) team-bhp.com, please? Let me try if it reads the external GPS. (There is a built-in port mapper though, provided with the OS, BUT the mgmaps GPS selector says "No serial ports").
In Dash GPS/Audio Receiver mav2000 In-Car Entertainment 16 1st April 2010 20:25
How to configure MireoPC edition with USB GPS receiver contactme27 Gadgets, Computers & Software 1 4th November 2009 21:56
Fully loaded Car receiver morphean In-Car Entertainment 20 26th July 2009 13:19
How To Use A Qstarz BT-Q1000P GPS Receiver with Ubuntu? Sankar Gadgets, Computers & Software 3 1st December 2008 20:05
