Old 30th April 2009, 13:17   #796
Thanked: 146 Times
RKB,
Spot on there!
After installation of MgMaps, when it asked for network connection, I specified not to connect to internet at all! And this did not strike me till now!!!
Just got out and tested it. Works like a charm!
Thanks a ton!
HappyWheels is offline   Reply With Quote
Old 30th April 2009, 13:38   #797
Thanked: 146 Times
(Just missed the 20minutes mark for editing!)
Done with download South India map from zoom 12-15 (enough for driving directions). A whopping 1GB.
So next question: How does one combine the downloaded MgMaps? I have zoom 16 & 17 for Bangalore. So how to get that into this?
Old 30th April 2009, 13:44   #798
rkbharat's Avatar
Thanked: 613 Times
In your stored folders, you should have structure like
South/MGMapsCache/GoogleMap_12
South/MGMapsCache/GoogleMap_13
South/MGMapsCache/GoogleMap_******
Just copy GoogleMap_16 and 17 under the above MGMapsCache Folder.
Before you try all these, take a backup of all the downloaded maps.
Now there is catch, what if you now want the 16,17 zoom level for Kerala. Do a simple thing. You have a combined base of above.
When downloading map for kerala, point the download folder to the above base. gMapMaker, will automatically merge the new download with the existing one.
rkbharat is offline   Reply With Quote
Old 30th April 2009, 14:48   #799
Thanked: 212 Times
like rkbharat said, you can download them to the same folder base, and then copy these additional folders to the phone like he mentioned.
You can also download to a different folder in the PC as long as you use the same tiles_per_image value (which is what it is by default), and then copy these folders to the right location in the phone...
Either way, it will work.
Cheers,
lancer_rit is offline   Reply With Quote
Old 30th April 2009, 17:12   #800
Thanked: 146 Times
Originally Posted by rkbharat View Post
...Just copy GoogleMap_16 and 17 under the above MGMapsCache Folder.
Originally Posted by lancer_rit View Post
...You can also download to a different folder in the PC as long as you use the same tiles_per_image value (which is what it is by default), and then copy these folders to the right location in the phone...
Thanks guys for the response.
RKB, your edit answered my concern, that is how to use the base again if I need to download another place with the same zoom level what will I do. Since I have a base now for South with 12-15 zoom, getting 16 & 17 will not be too much.
Old 5th May 2009, 16:20   #801
Rohit26's Avatar
which is the best gps which can use offline google maps in india? I have offline google maps,i want to put them in gps & then gps shows me the route/road from those offline maps.
Rohit26 is offline   Reply With Quote
Old 6th May 2009, 15:25   #802
splitsecond's Avatar
Thanked: 12 Times
Question
How is Nokia n82's gps performance when compared to a bluetooth gps receiver costing 3k ??
Is anyone here using nokia mobiles for car navigation? how is the gps performance of nokia n78 & n82 in heavy rain inside a car?
I am thinking of buying either Bluetooth gps receiver or secondhand Nokia n82
please reply...
splitsecond is offline   Reply With Quote
Old 6th May 2009, 16:25   #803
ask77's Avatar
External bluetooth receivers are more sensitive then nokia n series gps phones . only nokia navigator series phones have good internal gps.
ask77 is offline   Reply With Quote
Old 6th May 2009, 16:27   #804
NetfreakBombay's Avatar
Thanked: 402 Times
N82's performance is decent in rains and overcast sky. Use it regularly in Mumbai.
Used number of Navigation options, From Nokia's built in Maps to Satguide. I like Nokia's maps most. That is you can plan your router online on PC / Laptop and then save that route in cell.
That is not possible with other packages.
Which mobile you have at present? Adding bluetooth receiver should be a better idea since it costs jsut 3k.
Old 6th May 2009, 18:24   #805
Thanked: 12 Times
^ Thanks for the info, now i need to find a n82, i have Nokia 3110c
Bluetooth gps receiver is cheaper option for me,but its not available in any online Indian store and the models listed in "ebay.in" are all overpriced.
I have already set upped mgmaps with south india maps in my 3110, mgmaps is very good.
Is there any free or paid navigation software which support both voice navigation and stored map mode(storing google map).
Do "Nokia maps" allow google maps to be used with it as stored map?
Old 6th May 2009, 20:08   #806
Thanked: 402 Times
Nokia map would not use google maps. It would use its own maps but hose are raster maps and do not have satellite images for India.
Try this site for Bluetooth : GPS Receivers | iRide Technologies
However, on N82 you can run both Nokia Maps and mgmaps at the same time. And switch between them whenever required.
Old 8th May 2009, 14:35   #807
Default MMI 430m Classic GPS
After a lot of deliberations, finally bought the MapMyIndia 430 Classic 4.3" screen GPS,
Will test/try it out during my weekend trip to GOA via NH4, So far it has been working fine within the city. Still getting used how to handle it etc.. So far it seems to be OK.
Has anyone else on this forum bought this device, and how is the performance?.
Will post a full review of this device as soon as I complete my trip.
Irwin is offline   Reply With Quote
Old 8th May 2009, 19:12   #808
gopinathann's Avatar
Thanked: 20 Times
Guys,
If you hava QVGA device with Built in GPS, try this GPS Speedometer app and let me know whether it works and the accuracy of the value.
http://www.team-bhp.com/forum/gadget...gital-wm6.html (GPS Speedometer (Analog & Digital) for WM6)
gopinathann is offline   Reply With Quote
Old 8th May 2009, 19:30   #809
FlyingSpur's Avatar
Thanked: 1,336 Times
Haven't used GPS in India ever, but here in USA it works very well I'd say, except in the heart of the city it does go a little berserk. But more or less accurate, and that's alright considering it's been with me over an 1800-mile road trip.
FlyingSpur is offline   Reply With Quote
Old 9th May 2009, 03:57   #810
SLK
SLK's Avatar
Thanked: 192 Times
Try this if you have a Garmin unit/ software, quite workable-ly detailed I'd say Garmin india map
Well, address search doesn't work, but you search mostly by POIs - works. And routing works.
SLK is offline   Reply With Quote
In Dash GPS/Audio Receiver mav2000 In-Car Entertainment 16 1st April 2010 20:25
How to configure MireoPC edition with USB GPS receiver contactme27 Gadgets, Computers & Software 1 4th November 2009 21:56
Fully loaded Car receiver morphean In-Car Entertainment 20 26th July 2009 13:19
How To Use A Qstarz BT-Q1000P GPS Receiver with Ubuntu? Sankar Gadgets, Computers & Software 3 1st December 2008 20:05
