Old 9th May 2009, 21:54   #811
Thanked: 146 Times
Question to people using memory card for storage on hand held's: The MiniSD card in my phone is using Fat32 format and due to this the 1.2GB of Google Map tiles is going way above 7~8GB (size on disk) when I try to copy it to that.
Can someone tell me as to how do I over come this?
(Cursing myself for not buying the 16GB high speed MiniSD card when I had a chance!!!)
HappyWheels is offline   Reply With Quote
Old 9th May 2009, 22:04   #812
Thanked: 212 Times
Are you sure its FAT32 format ? All SD cards are formatted by default in FAT16 format (since MS has patents on FAT32).
If you format it in FAT32, such a wastage of storage space won't happen if you used smaller cluster sizes ...
Do check that you used a cluster size of 4096 bytes and not 32K or something (that is default for FAT16 for a 2GB disk).
I had solved this problem for my 1GB uSD card, and later 4GB uSDHC card by formatting both to FAT32 with 4K cluster size. Downside, is storage I/o performance is somewhat lower...
lancer_rit is offline   Reply With Quote
Old 9th May 2009, 22:31   #813
Thanked: 146 Times
Yup, it is FAT32.
A 14.8MB size-on-disk folder became 95MB on the HD! :(
Old 9th May 2009, 23:04   #814
NetfreakBombay's Avatar
Thanked: 402 Times
Format it with smaller cluster / page size. That will reduce wastage.
Old 10th May 2009, 17:51   #815
Thanked: 212 Times
Yup, it is FAT32.
In that case, it obviously is using a cluster size of 16K or 32K. Please refer to my post about using 4K cluster size, and your problems will vanish !
Old 10th May 2009, 18:23   #816
Thanked: 146 Times
@Lancer_Rit & NetFreakBombay,
Thanks for the response. Will try it out. But formatting will mean that I will have to uninstall and then reinstall all the applications I have now. :(
Old 10th May 2009, 18:30   #817
Thanked: 212 Times
Need not be the case. Use a PC based copy program to copy everything to HDD , and back after formatting. The only issues can be phone OS special attributes etc (like Symbian has hidden and system file attributes). These should only be a few folders. You can use a phone based file browser to note such folders at top level, and later on set the file attributes accordingly...
Maybe, someone else has an idea about whether there is a program to copy with the mobile OS folder attributes in a way that it can be restored back ? Probably, the Nokia PC suite backup/restore feature can achieve this ?
You maybe able to use normal copy for regular folders/files, and use backup/restore for your phone's system / hidden folders in storage ...
In any case, the earlier you do the conversion, the better for obvious reasons :-)
Old 10th May 2009, 21:14   #818
Thanked: 402 Times
Use NokiaPC suite to backup entire card. Would take a while so leave it running and go for a coffee .
And then format the card, and later restore the backup.
Old 10th May 2009, 21:39   #819
Thanked: 146 Times
Thanks guys for the tips.
I tried formatting an 2GB card with FAT32 and 8kb cluster and the files size is for the same folder in just 25MB compared to the 95MB in the current SD. So Yes, need to reformat to new cluster size.
Will try out the suggestion for back up and let you guys know.
Will post the update @ http://www.team-bhp.com/forum/gadget...-htc-hd-8.html (My new friend - HTC HD) since I have dragged this discussion OT here!
Old 11th May 2009, 18:12   #820
splitsecond's Avatar
Thanked: 12 Times
Smile
HappyWheels don't format memory card with fat32,instead u can download maps with "Tiles per file" set to 32 or 64 or even 256 in gmapmaker. This way 470mb will only take some 500mb in memory card and also copying speed will increase.
Set "Has Size" to 1 in gmapmaker to change "Tiles per file"
splitsecond is offline   Reply With Quote
Old 13th May 2009, 22:32   #821
Thanked: 146 Times
SplitSecond,
The deed is done!
Will follow this advice and check out the file size and then decide which to use. Thanks for the information.
Old 14th May 2009, 00:10   #822
Thanked: 212 Times
SplitSecond,
The deed is done!
Personally, I wouldn't recommend the tiles_per_file option ... It has impact on RAM use and performance, so is only really that useful if one has very small SD card or lots of RAM. Besides, you need to ensure you use the same tiles per file value for all your future downloads as this is a global setting.
I was one of the people who suggested such methods (and more advanced ones) on mgmaps forum long back, but as it happens, you'll land up with other small files with other apps which mess up your SD storage space. For eg., I have Nokia maps for certain locations, and they face the same kind of problem (though these are vector maps not bitmaps).
Old 14th May 2009, 00:48   #823
For GPS I use my HTC tytn II with windows 6.1.
The software I use is called Destinator 7.0. Itís a 100 MB (inclusive of maps from one_india maps) program and has all the mapping info of India including highways and most of the major cities. it's obviously independent and needs not GPRS connection. Works solely on GPS and is totally free to run
On an average i get connected to the satellites (Without any external antenna) in about 3 minutes in the city and considerable faster on more open roads. 3 satellites are enough but on an average i get about 6-7. Apart from the location it also offers Height above sea level, Speed and distance to arrival.
It's was a pain finding the mapping info for India on the net (very scarce) and then trying to crack it, but after using it for over 8 months it's probably the best feature on my phone and well worth the 2 hours i spent getting it working on the phone!
Just my two bits. :-)
Need_4_Speed is offline   Reply With Quote
Old 14th May 2009, 00:57   #824
SLK
SLK's Avatar
Thanked: 192 Times
Well, I haven't gone through every page of this thread but the other day I was just checking out mgmaps and realised that it actually routes!
I'm not sure but how does this work? does it work only if its using the online yahoo maps or offline tiles as well?
And if routing doesn't work on the offline tiles! why is everybody here so much after the offline maps! Isn't it just better to get a flat rate gprs plan?
Also, wanted to know, if searching works the same way with offline as online?
SLK is offline   Reply With Quote
Old 14th May 2009, 08:57   #825
Thanked: 212 Times
Ok, mgmaps does routing by sending driving direction requests to google.com over GPRS/EDGE/3G. When it gets the results, it shows the steps to be taken, and it can also show this on the map.
Driving directions for India in Google maps was not supported till 2 or 3 months back, so routing would not work for India till recently (I had used it in US, and it worked with some quirks).
Finally, routing works the same way if you use online maps or offline maps, so I didn't get your point ? You need GPRS/EDGE access for contacting google.com, but since maps are locally stored, its
a) less download (lower cost)
b) faster to display the map (downloading map tiles over GPRS sometimes takes 30-40s or even more, so how do you navigate precisely @ that time)
c) Works for areas w/o GPRS/EDGE or even mobile signal access, if the route was already done where one had access!
Hope this helps.
In Dash GPS/Audio Receiver mav2000 In-Car Entertainment 16 1st April 2010 20:25
How to configure MireoPC edition with USB GPS receiver contactme27 Gadgets, Computers & Software 1 4th November 2009 21:56
Fully loaded Car receiver morphean In-Car Entertainment 20 26th July 2009 13:19
How To Use A Qstarz BT-Q1000P GPS Receiver with Ubuntu? Sankar Gadgets, Computers & Software 3 1st December 2008 20:05
