Old 16th July 2009, 18:44   #856
NetfreakBombay's Avatar
Thanked: 402 Times
Originally Posted by whitemm550 View Post
Map my india or any other software on mobiles in crap, as there is absolutely no detailing available.
Mapmyindia and other providers (E.g. Garmin) use the same map on Mobile and PND versions.
You can copy maps from mobile to PND from PND to Mobile.
If you have older maps on mobile you can call them to get updated once. MMI updated mpas in May 09.
Old 16th July 2009, 19:26   #857
sathee46's Avatar
I use Map my India in my mobile and the detailing is really great. I use the May'09 maps of MMI. I have also checked this with a friend's MMI navigation unit and find no difference between both.
sathee46 is offline   Reply With Quote
Old 16th July 2009, 19:41   #858
Thanked: 402 Times
Its actually the same file and same software (Miero ViaGPS) that is used on both mobile and PND.
And now this software is available for PC (Windows) as well. So if you want to browse maps and plan route you can do it on PC as well.
Old 17th July 2009, 09:47   #859
tsk1979's Avatar
Thanked: 16,420 Times
The format of maps is not PND/mobile related but software related.
for exmaple if you use garmin you will get an img file. This img file can be used across all garmin based solutions.
However if you use MMI the format of the map file is different from garmin
Old 17th July 2009, 10:32   #860
shyamhegde's Avatar
Does cloudy weather OR rain affect GPS receiver's perfromance ? (like taking long time to acquire fix)
shyamhegde is offline   Reply With Quote
Old 17th July 2009, 10:48   #861
tsk1979's Avatar
Not at all. Your biggest hindrance will be driving in areas like lots of high rise buildings or high mountains on the sides.
Old 17th July 2009, 10:51   #862
rkbharat's Avatar
Thanked: 613 Times
As per books, cloudy weather does affect the reception. But I have not experienced anything like that till date.
rkbharat is offline   Reply With Quote
Old 17th July 2009, 10:57   #863
tsk1979's Avatar
Not clouds but heavy snow sleet can affect reception. The reason is reflections which cause formation of multiple paths from a single satellite.
In our country, only the Himalayan regions experience such weather, so most people will not have any issues
however if your GPS antenna itself is wet, thats a difference issue altogether.
Old 17th July 2009, 13:41   #864
Add to them tree canopy. In a heavily wooded area it is very difficult to get a fix. But I had tried earlier generation Magellans, Garmins etc.
janitha is offline   Reply With Quote
Old 17th July 2009, 14:07   #865
spadival's Avatar
Thanked: 16 Times
Dunno where to post this, If there are some corrections needed in google maps, how do you get it done?
NH17 breaks up into 2 when it reaches Bhatkal. Not that there are any real highway road surface over the area. I checked the same area in Google mapmaker and it seems fine.
bhatkal, india - Google Maps
spadival is offline   Reply With Quote
Old 17th July 2009, 14:19   #866
tsk1979's Avatar
Google has something called "mapedit".
You make the change, and then a moderator approves it.
Old 17th July 2009, 17:26   #867
Thanked: 402 Times
In India, Google buys data from Europa. They (Europa) need to correct it.
To report it to that team, raise a query at : https://earth.google.com/support/bin...tact_type=data
Once you select proper region in map, query would be sent to actual provider (E.g. Europa, Teleatlas, AND).
Old 19th July 2009, 22:25   #868
Default Outlander and GPS
I have a Mitsubishi Outlander and I am planning to get a Garmin Nuvi GPS. Does anyone have experience installing GPS in an Outlander? Any advice/suggestions/recommendations would be helpful.
Also, how do you conceal the power cable to the GPS unit?
tia
_aperture is offline   Reply With Quote
Old 19th July 2009, 23:33   #869
Abes's Avatar
Thanked: 57 Times
Depends on which one you are purchasing. Most of the portable ones are front glass mounted, no installation required. And the power cable is just hanging from the unit.
Abes is offline   Reply With Quote
Old 20th July 2009, 10:04   #870
I am thinking of a Garmin nüvi 760. I noticed that there is a little square (looks like removable) case in the dashboard above the audio unit towards the windshield. Please see the attachment (you can see it about 1/3rd from the top). Wonder if it is a little power outlet conveniently placed for a glass mounted GPS unit :-)
In Dash GPS/Audio Receiver mav2000 In-Car Entertainment 16 1st April 2010 20:25
How to configure MireoPC edition with USB GPS receiver contactme27 Gadgets, Computers & Software 1 4th November 2009 21:56
Fully loaded Car receiver morphean In-Car Entertainment 20 26th July 2009 13:19
How To Use A Qstarz BT-Q1000P GPS Receiver with Ubuntu? Sankar Gadgets, Computers & Software 3 1st December 2008 20:05
