Old 6th August 2009, 17:45   #946
Thank you tsk and netfreak will head to Chenoy trade center in Sec'bad this weekend and try my luck
ubsmart is offline   Reply With Quote
Old 6th August 2009, 18:34   #947
trrk's Avatar
Thanked: 12 Times
Originally Posted by ubsmart View Post
I have couple of WinMo phones. One a smartphone and the other is a PDA phone(t-mobile MDA).
What are the models / brands of the phones? Sure they do not have GPS built in?
Originally Posted by NetfreakBombay View Post
This would work and it plugs in car charger socket.
However, I think software that this seller is "giving away" is pirated.
I really would not go for this type as it would necessarily block the power socket for it to be used. Even the regular ones come with a car charger. They work upto 8-10 hours on a full charge.
You could be right about the software though!
All the best.
Guys, should he get one with the SIRF III chipset or any chipset would do?
trrk is offline   Reply With Quote
Old 6th August 2009, 20:00   #948
trrk's Avatar
Thanked: 12 Times
Originally Posted by neoonwheels View Post
Thanks bro !!. lets see which phone ppl recommend me given that I want WiFi and GPS both in the phone.
See the Map Browsing settings option for Mobile mgmaps:
Size:  225.1 KB<br /> <br />
When I tried the GPS settings:<br /> <br /> <img src=
Old 6th August 2009, 20:15   #949
Thanked: 128 Times
My question is more or less related to Asus P320. It has got WiFi and GPS both. Thats why I was wondering if I go for this phone will I be able to use built in gps with mgmaps for navigation without the use of GPRS.
Neo,
Get a phone with GPS inbuilt and I will take you thru setting up the MGMaps and offline stored maps. No need for GPRS.
Originally Posted by trrk View Post
... See the Map Browsing settings option for Mobile mgmaps:...The last may be related to my phone not having in built GPS. The offline mode setting was also not saved.
Trrk, Your version of JBlend is the reason you are not having couple of extra options. But since you say that your phone does not have inbuilt GPS, are you using MGMaps with an external GPS device?
HappyWheels is offline   Reply With Quote
Old 7th August 2009, 14:15   #950
neoonwheels's Avatar
Thanked: 599 Times
Originally Posted by HappyWheels View Post
Neo,
Hey thanks HappyWheels. I will buy a new phone this weekend in Mumbai. I came to know about the slow speed of P320 so as of now it is not in my list, but a few new entrants are:
1. HTC P3300 with GPS
2. Nokia N79
3. Acer X960/F900 - Dont know price
I am not very inclined towards Symbian phones. Acer phones look good but i dont know their price. HTC P3300 with GPS would be a good buy I guess.
neoonwheels is offline   Reply With Quote
Old 7th August 2009, 14:21   #951
Thanked: 128 Times
Neo,
I have a HTC HD, so you will know what I would recommend!
Old 7th August 2009, 14:23   #952
Yes, I installed Google Maps and it is prompting me for GPRS or GPS. So, Sure it does not have GPS in it. I am using HTC Excalibur and HTC TyTn.
Old 7th August 2009, 14:31   #953
Thanked: 599 Times
Anybody have any idea about Acer X960/F900?? Both looks good? Any hint on price??
Old 7th August 2009, 14:46   #954
Thanked: 128 Times
I reckon that TyTn has GPS in it but not Excalibur.
For using the inbuilt GPS with MGMaps, you will need an application like GPSPort, which routes the GPS signal to a port that MGMaps listens to.
And for the prompt on using GPRS, you can set it disabled in the option that comes after you deny access. It will ask whether the denial is for current session or always, just click on always.
Old 7th August 2009, 17:27   #955
Hi guys
I know that this must have been already discussed on the forum but can somebody please point me to link detailing the steps for downloading maps for mgmaps. I would like to use this functionality for rajasthan and U.P. and would not mind using the saved maps (offline mode) for the same.
I would appreciate any help that you guys might offer. I have already downloaded mgmaps on my phone and it has inbuilt gps.
Nishant B is offline   Reply With Quote
Old 7th August 2009, 19:39   #956
trrk's Avatar
Thanked: 12 Times
Originally Posted by esteem_lover View Post
@trrk, you got to do better than that unless you wanted us to see only ghosts.
Luck did not favour me yet again. Sun and the fact that I have been using a HTC phone to capture the images. Still:
Using a GPS Receiver in the Car-image_220.jpg <br />
Whatever we say about Bill Gates / Windows, my HTC had enough gadgets and so this is what I got off it at the same location:<br /> <img src=
The older version of Mgmaps that I installed had all those extra options, but then it also told me that my phone does not have a Bluetooth.
I do use an external BT receiver, but I tried Mgmaps only to give some answers to ubsmart's query. I don't intend to use it.
Google Maps, to the extent that I know will only work with a GPRS connection, so may not be useful to you. Since I have an unlimited connection, I do try it once in a while.
Though I asked about the models, I hardly know the details of those models and luckily HappyWheels seems to have answers.
I forgot all about this though I had read about it long back. I also read somewhere that the newer versions don't need GPSPort.
Old 7th August 2009, 20:02   #957
Thanked: 128 Times
...Google Maps, to the extent that I know will only work with a GPRS connection, so may not be useful to you. Since I have an unlimited connection, I do try it once in a while...
Not exactly. For using Google Maps, what you need are the map tiles. GPRS is required if you do not download and store the maps locally. But if you do store the maps locally (ie, on your storage card) you need no GPRS.
I have Google Maps and I do not have GPRS, but I still use them. Since I use GPRPort, I can run MGMaps and also another GPS program.
Do note that Nokia, with its "free 3 months" GPS does this GPRS thing. They download the Google Map tiles are and when your position changes. After the trial period, you need to foot the bill.
...Though I asked about the models, I hardly know the details of those models and luckily HappyWheels seems to have answers...
Psst.... let you in on a secret. I know nuts about those two models; my knowledge is from Google & Wikipedia!
... I forgot all about this though I had read about it long back. I also read somewhere that the newer versions don't need GPSPort.
The latest version had some compatibility issue with my HD, hence took the last stable release.
Old 7th August 2009, 20:19   #958
Default GPS Tracking system resricted to Mobile phone service providers network
I think, the GPS tracking devices in cars are linked with Mobile phone's networks like vodafone or Idea. in this way would not the Tracking ability of the GPS device be restricted to the service providers network?
Maximum_torque is offline   Reply With Quote
Old 8th August 2009, 00:57   #959
NetfreakBombay's Avatar
Thanked: 336 Times
Nokia's navigation does not require GPRS in 3 months trial or otherwise.
Maps are free (these are vector maps so are searchable).
Thing that is not free beyond 3 months is turn by turn guidance.
Maps use GPRS just to get a quicker fix on GPS, that is by sending current basestation id to Nokia's servers and they quicly tell approx location to GPS chip. GPS chip now knows which satellites to scan for.
Old 8th August 2009, 13:31   #960
trrk's Avatar
Thanked: 12 Times
I did not know that! I will remember that.
Now why did I not think of that?
I am not very sure about what you mean! Whether in cars or other devices, the GPS is not dependant on the mobile provider's network. If the navigating part / map part requires updates from the Internet, then it would need the GPRS connection of the mobile network and that may depend on the network availability.
I have used a Reliance phone and its GPRS for Mgmaps in my travel from Alleppey to Belgaum and back and it worked without problems in Kerala, Tamil Nadu and Karnataka. My Idea connection from Kerala also worked with GPRS in all these regions.
In Dash GPS/Audio Receiver mav2000 In-Car Entertainment 16 1st April 2010 20:25
How to configure MireoPC edition with USB GPS receiver contactme27 Gadgets, Computers & Software 1 4th November 2009 21:56
Fully loaded Car receiver morphean In-Car Entertainment 20 26th July 2009 13:19
How To Use A Qstarz BT-Q1000P GPS Receiver with Ubuntu? Sankar Gadgets, Computers & Software 3 1st December 2008 20:05
