Old 5th September 2009, 20:16   #1051
Thanked: 212 Times
Originally Posted by di1in View Post
Like I'd said some posts earlier i did a test run with the GTXi app and the results were not all that great. I've posted the programs output at s603rd.blogspot.com I'm online from my mob so cant get the exact URL. Bottomline is that the app is good, but if you want to calculate 0-100 times you'll need way better GPS modules than those that come embedded on a mobile.
Well with most mobiles having a 1HZ GPS update, no wonder you can't get very accurate GPS based timing not to talk of lesser satellites they lock in, and obstructions like tall trees/buildings etc. So, 0-100 does not make sense on the phone... Accelerometer based stuff is more accurate (relatively) but you need smooth roads etc
@NetfreakBombay, thanks for pointing it out. Yes, maps for Garmin happened later than when the iNav's came out. Actually, the iNav WF navigation software and adaptation to mapmyindia maps is pretty crappy, I am sure Garmin XT with the new mapmyindia maps will be 10times better. I still keep using mgmaps simultaneously with the iNav WF - the reroute on the iNav is fast and its best feature...
lancer_rit is offline   Reply With Quote
Old 5th September 2009, 20:30   #1052
di1in's Avatar
Thanked: 92 Times
oh. Netfreak had said that cell phone level gps modules work at 5hz..
And how does a accelerometer gather 0-100 times ??
di1in is offline   Reply With Quote
Old 5th September 2009, 20:46   #1053
Thanked: 212 Times
Check out the dynolicious thread on tbhp. It works on iphone. When I searched many months before, I did not find a accelerometer based app for S60, though N95 and N82 have a 3d accelerometer just like the iphone ...
Old 6th September 2009, 19:12   #1054
can anybody help me in deciding whether to go in for gps receiver or map software. I am looking for a device for my ANHC.
Vinod AirNav is offline   Reply With Quote
Old 6th September 2009, 20:47   #1055
Thanked: 84 Times
Your question itself is unclear, but you would need both Map Software and GPS Receiver.
Digital Vampire is offline   Reply With Quote
Old 6th September 2009, 21:06   #1056
DerAlte's Avatar
Thanked: 2,879 Times
Perhaps @Vinod_AirNav meant whether he should buy a dedicated GPS unit (PND) or software for a phone?
@vinod, the experiences and cost are completely different. Both come with maps. A dedicated GPS device has a much bigger screen, is costlier but doesn't do anything other than navigation (discount the odd unit's ability to show pics or videos). These units always have the GPS receiver built in.
Navigation software for a phone (there are more available for WiMo phones, but even Symbian phones are not far behind) is cheaper, but works on a smaller screen and is limited by a relatively slower processor on the phone. If you don't have GPS in your phone, you will need to buy a matchbox-sized GPS receiver which costs around 3K.
Garmin, Sat Guide and MapMyIndia have both dedicated units as well as software for phones available. It is also possible to buy a generic PND (Personal Navigation Device, usually comes without the navigation software) and load the navigation software.
Old 7th September 2009, 17:04   #1057
Thanks DerAlte for putting my question in correct perspective. Also thanks a lot for the explanation in simple language. looking for a garmin gps Rx in Kochi. Any outlets and probable costing!
Old 7th September 2009, 18:47   #1058
DerAlte's Avatar
Not sure who in Kochi stocks Garmin - maybe you can enquire at large shops like eZone or Croma if they have a branch there. A friend got a Garmin 215 for 17K in Bangalore.
Old 12th September 2009, 18:16   #1059
Please let me know the pros and cons of using the Nokia 5800 as a GPS unit. I am considering it since its cost is said to have come down to 13-14K.
janitha is offline   Reply With Quote
Old 12th September 2009, 18:34   #1060
splitsecond's Avatar
Thanked: 12 Times
Pros
Good gps unit,fast locking when AGPS is enabled,don't need to carry two units
Cons.
Some programs may have compatibility problems with its touch screen(not sure),battery will only last 4hrs if gps is continuously used, so car mobile charger is needed.
Software you can use with 5800
MGMaps=free,can use both google map and yahoo maps
Mapmyindia=Rs3500,same as yahoo map coverage,voice navigation
I am using n82+mgmaps only problem is no voice navigation.
splitsecond is offline   Reply With Quote
Old 12th September 2009, 20:36   #1061
DerAlte's Avatar
@splitsecond, you could use Garmin or Route66 on the Nokia if you want voice-guided navigation. Not sure of the cost.
Even the Nokia maps are good in the cities (better than mgmaps, since it is road-oriented), though voice-guided navigation is a paid Nokia service.
Old 12th September 2009, 20:36   #1062
di1in's Avatar
Thanked: 92 Times
Unless you have an unlimited data plan don't go for these internal gps units on cell phones. The a-gps feature requires a constant gprs connection and if you don't have an unlimited plan things won't end up good. Other than that not only are they slow to get a satellite lock, they'll have precision problems at higher speeds as well. But if you still want them then you could use mgmaps application and store maps on your cell. I've posted an article about that here ₪ In Focus: Symbian S60 3rd and 5th Edition ₪ There'll be a link either in "tricks and tweaks" or in "nseries stuff" on the horizontal menu. I can't post the exact address because i'm mobile right now.
Vodafone has a good data plan which i use - 50mb per month for 95rs. It was an unlimited offer until last month.
@DerAlte I'm not sure of Nokia maps' details for cities in Kerala, the last time i tried it was pathetic. I'd prefer the hybrid view of google maps anytime for places here. But it's a different story for major areas like Kochi though.
Old 12th September 2009, 20:39   #1063
NetfreakBombay's Avatar
Thanked: 402 Times
Cons:
  1. Nokia maps is expensive as it is not priced as per Indian market.
  2. MapmyIndia maps are available on Nokia (Available, but costs 7k).
Pros:
  1. Garmin Mobile XT runs fine with touchscreen on 5800
  2. Satguide maps for Gamin costs just 2k.
  3. Sports tracker is excellent for logging your tracks and uploading it to net.
Old 12th September 2009, 20:44   #1064
Unlimited data plan for my BSNL costs only Rs.199/- per month. But speed is pathetic here.
Old 12th September 2009, 20:57   #1065
Thanked: 402 Times
GPRS is NOT an issue at all.
GPRS is only required when you are starting the navigation. It helps is speeding up "fix", I.e. the time it takes for GPS to calculate current position.
And A-GPS can be turned off. In that case, GPRS would not be required.
In Dash GPS/Audio Receiver mav2000 In-Car Entertainment 16 1st April 2010 20:25
How to configure MireoPC edition with USB GPS receiver contactme27 Gadgets, Computers & Software 1 4th November 2009 21:56
Fully loaded Car receiver morphean In-Car Entertainment 20 26th July 2009 13:19
How To Use A Qstarz BT-Q1000P GPS Receiver with Ubuntu? Sankar Gadgets, Computers & Software 3 1st December 2008 20:05
