Old 6th February 2010, 10:43   #1231
trrk's Avatar
Thanked: 13 Times
Probably have to save a few route points along the shorcuts for it to 'learn' them.
Does the software have the options of route calculation which takes into account your 'made by you' route points on its own?
trrk is offline   Reply With Quote
Old 6th February 2010, 11:44   #1232
manim's Avatar
Thanked: 393 Times
Post same with me
I use my Nokia 5800 with the new free Ovi Maps and it works like a charm in Bangalore and also in Kolkata city limits. Excellent turn-by-turn directions and reasonably quick route recalculations. But it DOES get addled if I dive into my usual shortcuts. Probably have to save a few route points along the shorcuts for it to 'learn' them.
Overall, extremely satisfied and have effectively saved 11k as I was on the verge of buying a standalone GPS device.
Same with me, I was going to buy a PND but now have gone in for a Nokia 5230 which costs much less and has many other features.
The Ovi map software is good, but in my area it shows only the highways. The town itself is not covered.
'Google earth for mobile' is great and I have changed my GPRS connection to unlimited now!
Very satisfied with my purchase.
manim is offline   Reply With Quote
Old 6th February 2010, 19:08   #1233
NetfreakBombay's Avatar
Thanked: 402 Times
Originally Posted by trrk View Post
Yes. It is quite easy since you can do that on PC. Route would be transferred to device next time you sync.
Old 12th February 2010, 20:11   #1234
manim's Avatar
Thanked: 393 Times
Post Learning to use Google Maps
Google maps looks great on my Nokia 5230.
I am yet to take a long drive with it.
On a short drive, I found that the satellite images moves along showing my car in the centre.
Old 12th February 2010, 21:57   #1235
Thanked: 402 Times
If you are palling to use Google maps, do look at "mgmaps" software.
With this you can download Google maps on PC and then transfer to mobile. This way you need not pay data charges while roaming.
Old 12th February 2010, 22:50   #1236
Would you please explain the procedure with respect to Nokia 5230? The site doesn't list the model and says first of all Java is to be installed. Also, can it be installed in the memory card instead of phone memory?
janitha is offline   Reply With Quote
Old 18th February 2010, 13:24   #1237
surd_biker's Avatar
Thanked: 30 Times
Originally Posted by bblost View Post
That is possible via Mobile GMaps - View maps from various sources on your mobile phone!
But I have not been able to install it on my mobile.
I use this in my SE w810i. Woks flawlessly. Very useful on the go. Although my mobile doesn't have GPS but the s/w works great.
Great thing is that you can actually customize your download for the maps by selecting the actual drawing area on the map.
Use this guide for how to do it
Offline maps on a Java Mobile - Guides and Tutorials | TechEnclave
Use Map Creation Tool for MGMaps to create your maps and then use gMapMaker to download the tiles for your map
MGMaps :: View topic - gMapMaker - Map Tile Downloader for Windows
ANother beauty of this is that you can also view the downloaded maps on your windows machine by using this guide
MGMaps :: View topic - MGMaps on Windows XP using WTK - Instructions
You can use Yahoo maps, Microsoft maps, Google maps, ask.com maps, and Openstreet maps with MgMaps which is simply great means you can actually select from a variety of maps.
surd_biker is offline   Reply With Quote
Old 18th February 2010, 13:30   #1238
praful's Avatar
Thanked: 442 Times
Praful, I think you are not married yet and hence this question.
Some features I really liked.
It claims to find my location within 600 m.
In reality it found it within 100m.
But that is based on cell tower coverage. So it will change based on where I am.
Lol at the marriage point!
I guess your phone is A-GPS enabled hence the approximate location fixes. I usually get a fix which is accurate to within 10 metres, but thats coz I have GPS receiver inbuilt with the phone.
praful is offline   Reply With Quote
Old 18th February 2010, 14:22   #1239
ampere's Avatar
Thanked: 9,108 Times
Bumping up an old thread.
Just installed on my Asus P527.
Google Maps for mobile
All I did was goto m.google.com/maps
Click on install.
Maps a really good and it found my location in less than a second.
However I am connected via my LAN network and not gprs.
Will test GPS & GPRS later today.
But if you have a phone that can install it. Then do it. Its really neat.
Latitude will allow you to sign in and others to see where you are.
Am never gonna sign in.
Thats the only issue that you need a GPRS connection to access the maps. The offline would be very good. Though MGMAPs is available, but would be good if Google directly supports it. Its been promised for Android 2.1 though.
Old 18th February 2010, 14:24   #1240
nkapoor777's Avatar
Thanked: 91 Times
No, you will not be able to use google maps with this device.
But you can search for places on google maps and store results in your device. E.g. you can search for "XYZ Club" and store it in your device.
Tutorials here :
How to Load Google Maps to Garmin | eHow.com
Hi NFB,
I tried to import a location from Google maps to my Garmin Nuvi 750 but it doesn't give me an option to send it to GPS. When I click the send button on top of the page in Google Maps, it only gives an option to send to email. Am I missing something?
nkapoor777 is offline   Reply With Quote
Old 18th February 2010, 16:23   #1241
Thanked: 402 Times
5230 has Java. Just install "generic" version and you should be good to go.
Old 18th February 2010, 17:33   #1242
ravindran353's Avatar
Hi Ram
Some of your questions prompts me to write the folloeing details.
!.The GPS refered here is the ordinary handhelds which are easy to fix all the new pOI, where ever u travel
2.A car charger is absolutely necessary, cause the battery drains out faster.
3.An antenna is a must otherwise you have hold the navigator in your hand closer to the windshield.
4.For different GPS thre are software from the manufacturer.This wil help you to load the contents to your comp.For these type of road mapping I used to keep a Garmin 12xl with external antenna.
regards
ravindran353 is offline   Reply With Quote
Old 18th February 2010, 18:10   #1243
getsurya's Avatar
Thanked: 967 Times
guys, one basic query for using GPS in India-
How does this work with so many unplanned lanes, bylanes, unmentioned diversions, different routes to same place?? I am asking this because I use GPS in US and is very useful to say the least. However in India, I am faced with these questions>
getsurya is offline   Reply With Quote
Old 19th February 2010, 13:02   #1244
Thanked: 137 Times
How does one know which phones also have built-in GPS receiver?
Don't all high end phones with GPS (Not-Only Assisted GPS) come with GPS receiver.
You have me worried there. I bought an E72 a week back. Is it likely that it also does not have GPS receiver?
skdking is offline   Reply With Quote
Old 19th February 2010, 13:06   #1245
abhibh's Avatar
Thanked: 34 Times
Google Maps will still work if your phone lacks GPS. I have been using it on N70 and works fine to get the location and route from one place to another.
In Dash GPS/Audio Receiver mav2000 In-Car Entertainment 16 1st April 2010 20:25
How to configure MireoPC edition with USB GPS receiver contactme27 Gadgets, Computers & Software 1 4th November 2009 21:56
Fully loaded Car receiver morphean In-Car Entertainment 20 26th July 2009 13:19
How To Use A Qstarz BT-Q1000P GPS Receiver with Ubuntu? Sankar Gadgets, Computers & Software 3 1st December 2008 20:05
