Old 22nd December 2012, 11:17   #16
dutta_d1's Avatar
Thanked: 35 Times
Default Re: Is power/weight all that matters?
The power/weight ratio is just like the Ghz of a computer processor. Matters for performance, but it is not the only thing that matters.
In two words, it's marketing strategy that there is so much fuss about power/weight ratio.
dutta_d1 is offline   Reply With Quote
Old 23rd December 2012, 22:02   #17
Ricci's Avatar
Thanked: 995 Times
@Accelerate, when you say feels quicker - as in the Verna feeling quicker than the Linea, did you do this comparison starting from rest, giving it all it can acceleration, or was it already on the move - then press pedal (or maybe downshift , then accelerate ) ?
P:W ratio only measures the peak - which you can avail of only at 5 speeds, the shape of the rest of the torque curve is important. A very peaky engine, with a high sudden peak with significant drop in torque above and below that RPM , will show a high power to weight ratio, but an engine with somewhat less peak power/torque but a wider useful RPM range over which it makes over 90% of max torque, will be quicker despite lower power:weight ratio. This is very rare of course, most engines have sufficiently wide band around the peak torque/power to have 1500-3000RPM bands that will make you smile , but I'm talking more out of observation with petrol engines. Diesels tend to have more narrower rev ranges.
So, it would be great to get the power/torque curves of the said cars, the gear ratios and know the effective output (after transmission losses) to get a better understanding of why the Linea was slower even with similar P:W ratio. I might be simply down to turbo-lag, since most engines for general consumer use are not tuned for high performance over narrow powerbands.
Ricci is offline   Reply With Quote
Power/Weight ratio : relevance for driving vina Technical Stuff 42 30th November 2013 18:48
Power or skills! What matters more? sapna gurukar The Indian Car Scene 33 15th March 2013 13:29
Fiat Palio 1.6 vis-a-vis 1.2 (ELX): power matters trravindran Hatchbacks 0 15th October 2009 22:09
power or torque, which one matters more ? joecherian Technical Stuff 1 15th September 2008 14:03
what matters more speedsatya The Indian Car Scene 8 25th September 2004 02:02
