Old 26th December 2012, 01:15   #16
Thanked: 101 Times
Default Re: Shuddering problem at highway speeds
Originally Posted by swarnava.m View Post
Around 120, it is a distinct shudder. Felt through the steering wheel, pedals/floor, and the seat. I have tried keeping the speed exactly at 120 and noticed that this remains constant throughout. The moment I start reducing the speed, the shudder reduces, and completely disappears once you drop below 110.
Originally Posted by rangakishen View Post
Not only that. If you continue to accelerate you will find that after a certain speed the shuddering will again disappear...
...My car vibrates between 120 to 140kmph after which vibrations reduce.
I had a similar shudder at high speeds which disappeared when I went higher. It was because the engine was not getting enough oxygen. I got a conical air intake and the shuddering disappeared.
Try it.
lapsi is offline   Reply With Quote
Old 26th December 2012, 08:24   #17
VW2010's Avatar
Thanked: 2,124 Times
May be the vibration was to wake us up and say "Dude, are you sure its safe in your country"
Jokes apart. The problem can be as simple as alignment to worn our suspension parts.
At high speeds the suspension is put to enough strain that even a simple process of maintaining the car in a straight line exposes any weakness in the suspension set up.
Be it a early stage worn out bushings or lose nuts somewhere in Strut assembly or even engine mount.
Do the wheel alignment first and if that does not solve, its definitely suspension set up.
VW2010 is offline   Reply With Quote
Old 26th December 2012, 18:48   #18
praveengupta's Avatar
Thanked: 11 Times
An unbalanced wheel resonates with the suspension at a certain speed, get that balanced and realigned and you should be fine. I used to have exactly the same problem when I got the balancing done through Fiat-***, but since I started getting the balancing done for real at a dedicated wheel shop I have not experienced any vibration at high speeds.
praveengupta is offline   Reply With Quote
Old 26th December 2012, 22:22   #19
vnabhi's Avatar
Thanked: 1,309 Times
I had the same judder of the steering wheel when my Fiesta was new, and this was at speeds between 110 to 120, not below or above.
When I complained to Ford A.S.S. in the first service, they got it fixed with wheel balancing and alignment. I've never had the problem since then.
Old 10th January 2013, 20:57   #20
swarnava.m's Avatar
Thanked: 268 Times
I did get the wheel balancing/alignment done again (from a local shop, and quite a lot of weight needed to be added to the rear RHS wheel), and post that have had quite a few highway runs, going upto 140 kph.
Happy to report that the car runs perfectly stable, and the issue has not occurred again. Looks like it was incorrect wheel balancing/alignment after all. Need to take it up with HASS.
Thanks for all your inputs.
swarnava.m is offline   Reply With Quote
Old 11th January 2013, 06:17   #21
KarthikK's Avatar
Thanked: 3,498 Times
It had to be a wheel balancing issue if there was shudder at high speeds. Alloy wheel bends seldom show up as high speed wobbles. Bent alloys will produce low speed wobble (mostly below 40-50 kmph) but will not be perceptible at the high speeds you mentioned. Anyway your problem is solved, which is the important thing
KarthikK is offline   (1) Thanks Reply With Quote
Shuddering/Vibrations while braking! Need help! asethi Technical Stuff 76 17th February 2013 18:16
Shuddering of wipers in my Ford Fiesta ghodlur Technical Stuff 32 13th September 2010 00:00
Shuddering on Civic surfatwork Technical Stuff 18 9th February 2009 22:56
