Old 15th January 2013, 20:35   #31
Thanked: 2,071 Times
Default Re: Power Window Failure? How to manually roll your window up
Piqued my interest, Went through the whole thread!
Fiddling with wiring, without a circuit diagram or proper diagnosis of fault, is not what is recommended in general.
Originally Posted by pranavt View Post
I did assume a level of intimacy with wiring and electrical stuff in general, considering the OP explicitly told us twice that he had an IT background.
My two bits on what seems to be the crux of a dispute:
If a person needs advice (ie unable to figure it out for himself) on what to do about a power window problem, I for one would not advise him to fiddle around electrical connections (to a presumably DPDT switch). My advice would be the same as SSTs, mechanical in nature.
Sutripta
Sutripta is offline   (2) Thanks Reply With Quote
Old 15th January 2013, 21:59   #32
bj96's Avatar
Thanked: 127 Times
Originally Posted by lsp View Post
... I park on the road outside my house so it wasn't safe to park the car whole night with a window open... other ideas which can be implemented.
Good post. I have another idea, if the purpose is to protect for a night- a full body cover for the car, I think, could be used to hide the open window from vandals.
-BJ
bj96 is offline   Reply With Quote
Old 9th April 2014, 12:28   #33
Thanked: 28 Times
Unhappy Re: Ford Ikon Power Window Cable Replacement GUIDE
Sorry for reviving such an old thread but, I'm having a problem with the driver's window on my Ikon. It seems to be stuck in the downward direction!
Is there a quick fix for this because my local mechanic claims that it'll cost around 1500-2000 for a switch that I'll have to procure myself from Opera House (with no warranty!)!
yash1229 is offline   Reply With Quote
Old 12th April 2014, 08:24   #34
RM2488's Avatar
Thanked: 117 Times
Default Re: Ford Ikon Power Window Cable Replacement GUIDE
The switch can be fixed in some cases. If you are competent enough to open it up. You only need a screwdriver to check. And when you say stuck- describe the symptoms a little more. Is the window stuck and refuses to go up or down? Or does it go down, but refuses to come up?
RM2488 is offline   (1) Thanks Reply With Quote
Old 13th April 2014, 12:06   #35
Thanked: 28 Times
The window is stuck(closed). The upward direction of the switch for the driver's window doesn't have a tactile feel like the other three window switches. When I press the switch in the downward direction(to roll down the window), the tactile feel is present but the window doesn't roll down at all! This gets really annoying when I have to pay tolls et cetera!
Old 13th April 2014, 14:27   #36
RM2488's Avatar
Thanked: 117 Times
Your switch does appear to be damaged. Perhaps it can be repaired, but you'll have to open it up to see. I doubt this is the case, but you can have a buildup of crud on the contacts. Cleaning them does the trick.
Old 13th April 2014, 15:24   #37
Thanked: 28 Times
Yeah, I'll check up on that, then! Thanks for the help!
SWIFT - Power Steering failure goldsun Technical Stuff 47 11th August 2017 10:52
Skoda Rapid Warranty Issues: ICE blamed for Power Window Failure veeru27 In-Car Entertainment 93 23rd June 2013 12:14
Retractable ORVMs. Boon or burden (folding them manually)? pgsagar Technical Stuff 42 7th September 2011 14:16
Fabia Central Door Locking - No way to lock the doors manually from inside the car kunaalsaigal Technical Stuff 11 22nd December 2010 12:49
Need Info: Sunfilm/SeatCover/Power Window/Fog Lamp souravbasu Modifications & Accessories 3 3rd April 2006 10:53
