| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #16 (permalink) |
| Newbie Join Date: May 2006 Location: Gurgaon
| Yes the flush Mounting would be custom job. I am working on preparing readymade panels for the most common cars and then it would be a snap to fit. Regarding the OS and Applications, it runs a Custom Linux with the latest kernel and everything including the frontend is installed in the 128MB of USB. It also included the Maps of one City. The frontend specifically is again custom software developed by me and is similar to what is available from other sources. It however does not utilize any existing frontends. The Screen is a stand alone Dash mounted. Please see the links I sent earlier for the pictures of the components and the Car PC. Manik Last edited by manikahuja : 8th May 2006 at 16:00. |
| | #17 (permalink) |
| BHPian | but when do you plan to market this ?? how about giving t-bhpians special discounts during testing stages ;-) !! hehe , also if you need any asisstance i can try and help ! (mechanics is my area of expertise as i am a mech engg. student) also if you need any help on the electronics i can help you out as my dad is an electronics engg and runs authorised service centres for sony , aiwa , sony ericsson , etc.!! so i shall be happy to offer any help that is possible!! |
| | #18 (permalink) |
| Hi Speedomania, Really appreciate your concern and thanks a lot for offering your help. I will definitely get in touch with you in case I require something. Now regarding "When" . Well like I told earlier I am finishing the software frontend part through which the entire system will be controlled. Right now it is all working but as standalone components. This should take me atleast a month to get right and after that I need to do some field testing. My guess is that earliest it should be available by July End. I know it is two months but I dont want to rush out a half baked product. Thanks Manik |
| | #19 (permalink) |
| BHPian Join Date: Dec 2005 Location: Mumbai
| custom benzels for different cars for mounting the lcd would be super slick. fitting an os with your frontend and a city map on a 128 mb stick is impressive. but then your frontend should have pretty much everything covered incld obd & gps since you're runnin linux, cause these programmes are more freely available under windows. btwn what car are you instaling it into for your ' field testing' please post pics as and when you have an update. its different seeing an actual install vs seening the components by themselves... |
| | #20 (permalink) |
| Hi Shldn, My initial testing was done in a Maruti Omni as I wanted to check the ruggedness (The Omni has the worst suspension , I will definitely post pictures of the setup soon. Dont want to spoli the fun by putting up pictures of something that does not look neat.The interface will have a touchscreen operated frontend that will have option to run the GPS, Media Player, OBDII etc. I am taking complete care of the fact to make it fast and slick. Really appreciate all your concerns, I will not dissapoint you all. Thanks Manik |
| | #21 (permalink) |
| BHPian Join Date: Feb 2006 Location: Bangalore
| Manik Some things that you should keep in mind , IMO, is the fit and finish should be top notch , since at least initially the target segment will be the above average income group and people who travel extensively in which case having multiple maps and greater coverage can be a USP. The success of such a product is in convincing the people that this is a gadget that you cannot do without and it's not a luxury. All the best Deepu |
| | #24 (permalink) |
| Hi All, The power supply is basically a SMPS based unit that draws power from the car's battery. It is connected to both the Main Battery Positive and the ACC line. When the ACC line is switched on it will power on the Computer automatically, however when you switch off the car comletely the computer keeps running for a fixed amount of time after which the power supply signals the computer to go in hibernation mode or switch off depending on your setting. This is typically the scenario when you switch off the car and lock it and walk away. However many times we just sit in the car e.g. on a red light when the engine is off , however this time the ACC position is still on. In this scenario the Computer remains fully powered and you can keep listening to music etc. Now the difficult part, when you start your car, depending on your battery condition and the load the started motor takes to turn the potential of the battery drops to well below the 12V level. In certain cases I have seen it going doing to upto 9 volts. However the computer is sensitive to even small changes in voltage and would reboot in such a situation. To avoid this the SMSs is designed to withstand power variation from 7 volts upto 16 Volts or even higher. The objective being to keep the computer running flawlessly. All this has been designed and made strictly according to internationally accepted SMPS power standards and I have tested this unit extensively. So basically you dont need to worry about switching on the computer or switching it off. It is all handled automatically much like a Car Stereo. The time after which you need the computer to turn off automatically can also be tuned according to your preference. Finally the Power supply has upto 120 W of power avaialble to power the commonly used peripherals like CD Drives, Hard Disks etc without any issues and comes with standard Power connectors that fit directly onto the computer motherboard. Hope this clarifies the working of the Power Supply. Thanks Manik |
« Does Fuel Injection really give that much of an advantage?
How important this small relay is.......views invited »
| Thread Tools | |
Similar Threads | ||||
| PICS : Indian SX4 sedan SPORT prototype! | iTNerd | The Indian Car Scene!! | 24 | 19th December 2007 20:17 |
| Motogp 800cc prototype info thread | devsus | Motor-Sports!! | 11 | 15th November 2006 19:01 |
| Ducati unleashes Desmosedici RR production prototype! | turbo_v12 | Motorbikes | 7 | 22nd August 2006 16:54 |
| 2005 Mercedes S Class Prototype | v12 | The International Automotive Scene | 19 | 5th April 2004 12:40 |
| Awesome looking Nissan prototype sedan | _Crazi4Speed_ | The International Automotive Scene | 5 | 28th February 2004 20:56 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
