Closed Thread
Old 10th May 2006, 00:18   #46
ECM
ECM's Avatar
Thanked: 9 Times
harmless means cable connectors connected in sensors.You will soon have check engine indicator in your car mostly.Change plugs plz as 69K is a long inuf run to perform this job.Do all jobs what I have mentioned,if all fails wait for c.e.indicator and then like me(I hope so)change cam position sensor.
ECM is offline
Old 10th May 2006, 00:40   #47
The Wolf's Avatar
Thanked: 58 Times
ECM, its "Harness" and not harmless!!!
Im not surprised Karthik got it right!!!
"rdkarthik" is the only guy in India who builds his own performance ECU's for Indian cars...His business functions under the name "Race Dynamics"(www.racedynamics.in)
So if the problem is anywhere close to ECU's and stuff, he is our man!!!
The Wolf is offline
Old 10th May 2006, 00:46   #48
ECM
ECM's Avatar
Thanked: 9 Times
Thx for pointing my error,I shall keep this in mind next time.Yes I meant harness which is harmless!
ECM is offline
Old 10th May 2006, 00:52   #49
ECM
ECM's Avatar
Thanked: 9 Times
WOW!! Amazing man with lot of talents.I shall call him tomorrow w.out fail.He is my man in short.It is so much delight to see someone doing this wonderful job in India and most of ppl(without you I could have never come to know about him)not knowing at all.Cudos to him and to his parents.
ECM is offline
Old 10th May 2006, 01:05   #50
The Wolf's Avatar
Thanked: 58 Times
Infact Karthik happens to be my tuner hence I could open my mouth without hesitation...He knows ECU's damn bloody well.
4 out of 5 cars that ran his custom performance ECU's had podium finishes(including mine) in the last months Speed Run...a drag racing event that happened in bangalore.
Pls contact him if you have any doubts regarding ECU issues, he would be more than glad to assist Im sure...
p.s: Sorry if Ive gone off topic.
The Wolf is offline
Old 10th May 2006, 22:12   #51
shrivz's Avatar
Thanked: 92 Times
my plugs have run for only 5000 kms as i changed them last service... i will get my sensors checked as soon as i can...
shrivz is offline
Old 10th May 2006, 22:30   #52
ECM
ECM's Avatar
Thanked: 9 Times
When u changed your fuel filter buddy?Dont worry and think much and let check engine light comes if it is a begining of a saga like mine,cost is 2200 bucks for the sensor which I replaced.
ECM is offline
Old 10th May 2006, 22:41   #53
pramodkumar's Avatar
Thanked: 947 Times
Hey ECM,
even i am facing this problem. check my post on car knocking at higher speed
pramodkumar is online now
Old 11th May 2006, 10:06   #54
naveendhyani's Avatar
Thanked: 7 Times
@ all: i have a 2002 baleno with 185/80R13 rubber and it returns me an average of 10.5 in heavy gurgaon traffic. even with occasional standings while my wife is doin some shopping. haven't checked the highway mileage but will post as soon as i do it.
naveendhyani is offline
Old 11th May 2006, 11:09   #55
supremeBaleno's Avatar
Thanked: 1,705 Times
Now that @ECM's problem with his Baleno is solved, I guess it won't hurt to get back to that 20kmpl FE claim.
During my highway drives (around 1700kms), I have got FE ranging between 16 and 16.5 kmpl (measured by the tankfull-to-tankfull method). I drive at the max speed that the road and traffic permits - have gone upto 140kmph max. My average speed was in the whereabouts of 80kmph. And I always keep the AC on.
Instead, if I were to drive at a steady pace of 70kmph (a la ECM), I am sure that I could get an FE of atleast 18kmpl. And on top of it, if I do not use AC and keep windows closed (a surefire recipe to get grilled in Tamilnadu), and ensure minimal load in car, a 20kmpl FE does not look impossible. So, even though @ECM's claim of 20kmpl FE on highways might look like a big deal, it is actually quite possible with some effort and sacrifice.
But, then will I give up the comfort of AC and the fun of high speed (not rash) driving to get a 3-4kmpl increase in FE ? No, Thanks.
supremeBaleno is offline
Old 11th May 2006, 11:38   #56
shrivz's Avatar
Thanked: 92 Times
you said it man chk out gto's post on why do indians only car abt FE!!!
shrivz is offline
Old 11th May 2006, 14:13   #57
DRC
DRC's Avatar
Thanked: 48 Times
Good to know the problem is sorted out. And we all know one more possibility a car can go wrong and to check in case of a problem. That is the purpose and spirit of this team.
Regarding the FE, it is not impossible. we all know in spite we redicule each other for fun . I get 12.6km/l on my petra on highways, have tried and got 16 once, it can be repeated, but with out fun.
To discuss more about it , I think there is a thread about it already, can we move there, Just not to confuse subject of the thread and the content. Mods please...
DRC is online now
Old 11th May 2006, 17:26   #58
Samurai's Avatar
Thanked: 15,757 Times
Since the problem has been fixed, this thread will be closed. The discussion on FE can happen elsewhere.
Samurai is offline
Closed Thread
The DRL Thread: Everything about daytime running lights zenren Technical Stuff 133 28th June 2018 18:01
Philips India launches Daytime running lamps & an In-cabin Air purification system GTO Modifications & Accessories 144 30th December 2015 12:09
GQ Run II (Golden Quadrilateral Run II) arindamray Travelogues 327 6th August 2013 00:00
Ride on but with your headlights on during daytime in Kerala! jkdas Ride Safe 58 10th June 2010 16:34
