Old 27th May 2013, 20:14   #31
sushil_n79's Avatar
Thanked: 97 Times
Smile Re: My Salute to the Fiat Uno - Restored
Hi All
I have been thinking of incorporating the alloys in the same considering the same would complete the muscle car looks. Presenting a few pictures which really impressed me . request inputs please. of course with a request that if you want to pass any personal comments please mark it as same so that no arguement arises but anything on improvement is welcome
Also the picture of my car which has fancy rims in the rear wheel am trying to source the adapters for the front wheel which can help me install the rims in the front as well.
The Rims have just been installed to check the feasibility and trial purpose only as once ascertained we will do the chorme or paintwork to the same before it is finally installed. Request inputs on whether the rims should be given chrome plated or painted.
Thanks and Regards
Sushil Narayanan
sushil_n79 is offline   Reply With Quote
Old 27th May 2013, 20:23   #32
Samba's Avatar
Thanked: 6,028 Times
Default Re: My Salute to the Fiat Uno - Restored
For the design you selected i would say chrome should look better than painting it with any other colors. Though its just my personal opinion. You please wait for the other experts to comment on this too.
Samba is offline   (1) Thanks Reply With Quote
Old 28th May 2013, 08:34   #33
sushil_n79's Avatar
Thanked: 97 Times
Hi Samba
Thanks for the encouragement on the same even I was thinking on the same lines but just also wanted to reconfirm the same before going ahead. appreciate your inputs indeed.
Thanks and Regards
Sushil Narayanan
sushil_n79 is offline   (1) Thanks Reply With Quote
Old 28th May 2013, 21:35   #34
sushil_n79's Avatar
Thanked: 97 Times
Hi Again
I need to get the spacers like the one in the below picture to fit the new rims.
Can someone please let me know, where I can get it in Hyderabad?
Thanks and Regards
Sushil Narayanan
Old 29th May 2013, 23:58   #35
sushil_n79's Avatar
Thanked: 97 Times
Hi All
The red picture I guess shows the alloys but is too distorted request the person to post it again
S.N
Old 30th May 2013, 11:37   #36
ilangop's Avatar
Thanked: 591 Times
Hi Sushil,
Nice to see your Uno. Could you please explain why you need an adaptor for the fron wheel? - For PCD matching or as a spacer?
Regarding chrome plating the wheel rim, it would be really difficult to protect it from rust. You can apply a coat of lacquer over the plated surface though. Compared to chrome plating, painting would workout cheaper. Are the fancy rims from an NE?
ilangop is offline   Reply With Quote
Old 30th May 2013, 19:04   #37
sushil_n79's Avatar
Thanked: 97 Times
Originally Posted by ilangop View Post
Hi Sushil,
Hi Illangpop
Thanks for dropping by this thread . Yes the need for adapter is to be used as a spacer between the disc brake assembly and the rim as it is rubbing against the assembly without the spacer and creating a lot of friction which is resulting in the rim getting heated up
Yes regarding painting the same or chroming is concerned we can ascertain the same once we are able to successfully fit it , thanks for the inputs on the same though
I am really not sure if they are from NE as I was told by a person that they used to be used in Rally sports and will fit the UNO with a little bit of modifications/ spacer Awaiting inputs from you on the same
Thanks and Regards
Sushil Narayanan
Old 31st May 2013, 09:00   #38
ilangop's Avatar
Thanked: 591 Times
Can you please post a picture of the inner side of the rim where the rubbing was happening? Just to understand if a spacer could sover the problem or to know if you need a rim with a larger inner dia.
-Ilango
Old 1st June 2013, 13:42   #39
Scarlet_Rider's Avatar
Thanked: 434 Times
Post Re: My Salute to the Fiat Uno - Restored
Ilango, there is no problem when these wheels are fitted at the back. When fitted at the front, they are rubbing against the disc brake caliper. You will get a clearer picture when Sushil posts the pictures. An adapter is required as a spacer and not for PCD matching. Is there any alternative other than an adapter?
Scarlet_Rider is offline   Reply With Quote
Old 1st June 2013, 23:59   #40
sushil_n79's Avatar
Thanked: 97 Times
Hi Guys
I am enclosing the below picture which will make things clear
so In my case i have highlighted the brake pad assembly which is rubbing against the back of the rim
Awaiting response soon on a workable solution.
Thanks and Regards
Sushil Narayanan
Last edited by Rehaan : 20th May 2014 at 11:49. Reason: Old post, but removing one corrupt image.
Old 2nd June 2013, 00:34   #41
ilangop's Avatar
Thanked: 591 Times
So, by how much would you need to bring the wheel outside? And how does the hub center protrude out on the front axle. If you think the new rimm will be seated on th hub center even after having a spacer then it is worth giving a thought. To check if a spacer can solver the problem, you may jack the car and remove the front wheel. Introduce a washer each in between the front hub and the rim. Bolt it back. Rotate the wheel while the car is jacked. If it still rubs, try 2, 3, ... washers. If you see that the scrubbing stops at the point where the rim centre hole wont be able to rest on the hub centre, I think you will be far deviating from the designed wheel geometry. So let us take a call once you try the above experiment. Please post pictures as you introduce washers to measure the distance.
Old 2nd June 2013, 20:43   #42
sushil_n79's Avatar
Thanked: 97 Times
Hi Brother,
I tried the above experiments today but to my surprise the type is bolt type where the thread rests on the wheel assembly and you bolt it up from out side so no option to place the washers
They are like the one on the right as against like the one on Left that you have in alto
so no possibility of using a washer. I guess
Thanks and Regards
Sushil Narayanan
Old 4th June 2013, 20:29   #43
ilangop's Avatar
Thanked: 591 Times
Dude, think a little out of the box. Anyways you will be painting the wheel rims. So there is no harm is spending Rs5/- on feviquik and glue the washer to the back side of the rim or to the brake drum. What say?
Old 6th June 2013, 21:59   #44
sushil_n79's Avatar
Thanked: 97 Times
Hi Bro
Thanks for the suggestion indeed . Its a Good suggestion and really out of the box thinking which did not strike me earlier.
But I had a few questions on the same:
  • Will the feviquick be able to stand the heat emitted from the disk brakes assembly during movement
  • Is that sure that it will not lose its grip even when the car is at high speeds say average of 100 or 110Kmph.
  • Would the nuts or washers be able to withstand the pressure without cracking in between because even if one side washers crack they will disturb the balance of the entire vehicle which is risky at high speeds and also can cause severe damage to the vehicle and life.
  • Has anyone tried it before. If yes , would request the person to share his experience.
  • Requests the experts to comment on the same please. Dhabhar Sir, Bala, Rahul bhai, Anjan Sir request inputs please.
Thanks and Regards
Sushil Narayanan
Old 7th June 2013, 00:19   #45
ilangop's Avatar
Thanked: 591 Times
Oh dude, Good that you asked in the forum and did not try driving at 110 Kmph. It was only a suggestion to understand how much offset you really need with this rim, and if offestting would really help you in the rim fitment. Please do not experiment driving the car with a washer like spacer. Only jack up the car and rotate the wheel by hand. It is very much possible that all your above mentioned forecasts turn true if you drive with this setup.
-Ilango
Numero Uno : Fiat Uno hillram Test-Drives & Initial Ownership Reports 84 29th November 2012 11:32
Progetto di restauro FIAT Uno (Uno Restoration) arununo Technical Stuff 35 6th May 2010 10:44
Fiat Uno Wanted! moralfibre Shifting gears 27 21st May 2009 13:07
Fiat Uno GT?? ported_head The Indian Car Scene 25 17th August 2008 00:27
90k kms of the Fiat Uno Harrie Long-Term Ownership Reviews 15 11th February 2006 12:13
