Old 14th January 2013, 00:12   #1
Thanked: 45 Times
Default Temperature gauge stuck at the same level. Help?
My lancer diesel's Temperature needle in dash, is showing just below half way mark, always, even when cold, i just noticed today, i think this problem cropped up only before1-2 days. Due to this the fan starts working when i on the key to start the car. What might be problem? I do not think the needle got stuck
rajivanoj is offline   Reply With Quote
Old 14th January 2013, 02:13   #2
Thanked: 716 Times
Default re: Temperature gauge stuck at the same level. Help?
I guess it is the coolant temperature sensor that has failed, otherwise fan will not come up when cold.
ramzsys is offline   (2) Thanks Reply With Quote
Old 14th January 2013, 05:54   #3
1self's Avatar
Thanked: 270 Times
As stated above, the coolant temperature sensor has failed. So, the ECU, not having a way to know engine temps keeps the fan on all the time as a fail safe measure. Please replace the sensor ASAP.
1self is offline   (3) Thanks Reply With Quote
Old 14th January 2013, 10:59   #4
dhanushs's Avatar
Thanked: 4,504 Times
Agree to the above.
In the ikon, if the coolant temp sensor fails, the needle will be stuck in the hottest position, and the engine will not start. Similarly, your fan turning on, is one way, the car is keeping itself safe.
Old 14th January 2013, 14:11   #5
Thanked: 45 Times
Default Re: Temperature gauge stuck at the same level. Help?
there are two sensors, one near engine block, and other under the radiator, i think you people are speaking about the thermocouple in radiator. am i right?
Old 15th January 2013, 07:48   #6
Thanked: 716 Times
Try disconnecting one sensor at a time, observe the temperature gauge. You can find which went wrong by this way.
ramzsys is offline   Reply With Quote
Good 'ol Temperature Gauge : Yes or No? GTO Technical Stuff 160 1st March 2017 18:39
After temperature gauge - oil dipstick to go as well? Takumi-san Technical Stuff 2 27th April 2010 16:57
Cabin hot but temperature gauge normal paish Technical Stuff 10 9th April 2010 14:45
Temperature Gauge links to Fuel Efficieny 2fast4u Technical Stuff 12 21st June 2006 15:39
