Closed Thread
Old 9th May 2006, 11:13   #1
Smile purpose of tachometer
i heard the tachometer should be used to help in the gerashifting at 2000rpm ,can anybody exlain it in detail.
jagjeet is offline
Old 9th May 2006, 16:36   #2
sidharth_j's Avatar
Jagjeet,
To get maximum fuel efficiency,a car has to be driven in certain ways.
The general guideline is to shift earlier rather than later.
The tachometer essentially helps to shoot for a target of about 1500 to 2000 RPM in the next gear, when accelerating gently. This is especially true for diesels where the torque band peaks at lower RPM than in petrol engines.
Remember that, the engine's efficiency is greatest at near to its maximum torque speed, which is usually half to two thirds of it redline rpm.
Hope this helps
sidharth_j is offline
Old 27th June 2008, 15:47   #3
condor's Avatar
Thanked: 4,906 Times
Mods, pls close / del -or- merge with :
http://www.team-bhp.com/forum/techni...uired-car.html (Is a tachometer required on a CAR ?)
condor is offline
Old 27th June 2008, 16:12   #4
Technocrat's Avatar
Thanked: 2,589 Times
Thanks Condor
Btw this is a two year old thread & the one you quoted is three years old
Thread Closed
Technocrat is offline
Closed Thread
EGR system - What's it purpose & when does the EGR valve open/close? rranjith_kum Technical Stuff 60 14th August 2017 20:15
Tyre Polish - Does it serve any purpose ? mithun Tyre & Alloy wheel Section 35 28th August 2015 20:07
CELEBRITY:which car they drive? for which purpose? Bob Shifting gears 24 2nd July 2015 07:36
Mercedes-Benz Unimog : Best offroader amongst special-purpose vehicles hanmust 4x4 Vehicles 12 12th February 2011 17:50
Purpose? To not have any. Tarang Introduce yourself 3 20th August 2010 08:02
