Old 9th May 2006, 11:43   #1
Question How to improve brakes in baleno?
Hi fellow team members,
I was wondering if any of you (baleno owners) have come across this poor braking problem in baleno? I would like to improve the brakes in Baleno, anyone has tips for me?
or
Is this issue already discussed anywhere in a forum? please let me know
*thanks*
RoaringEngine is offline   Reply With Quote
Old 9th May 2006, 12:16   #2
aseem's Avatar
Thanked: 419 Times
I face the same problem with Esteem brakes, every time after driving Swift or Santro for a week, if I drive Esteem I feel that the pedal has to travel very long before the car brakes. I have had a few close calls, but off late I drive Esteem very rarely so not bothered. But it would be nice to know how this can be fixed, I presume both Baleno and Esteem can be fixed in similar fashion.
aseem is offline   Reply With Quote
Old 9th May 2006, 13:13   #3
v1p3r's Avatar
Thanked: 27 Times
I haven't come across this. Maybe you need to upgrade your tyres. Better rubber stops quicker.
Old 9th May 2006, 15:23   #4
but the car has alloy wheels and good year tyres and they are really really good on roads, it has free flow too so, now the car is not really listening to me when I apply brakes, I mean when speeding. I was wondering if there is any upgrade for the brakes and also car is fitted with metal brake pads :-)
Old 9th May 2006, 15:27   #5
amitoj's Avatar
Thanked: 1,691 Times
by "better rubber", v1p3r meant upgraded as well. What size are your wheels?
amitoj is offline   Reply With Quote
Old 9th May 2006, 15:40   #6
Thanked: 15 Times
Haven't noticed the same in my baby. If you have upgraded to wider rubber, better get the same checked at your workshop. How many kms has your baleno run?
kewlferrari is offline   Reply With Quote
Old 9th May 2006, 15:44   #7
v1p3r's Avatar
Thanked: 27 Times
Like Amitoj said, I meant wider tyres. I would suggest the following upsizes:
1. 185/70 R13: This is what I run, though on 5J rims, the tyres bulge out a little.
2. 195/60 R14
3. 195/55 R15
4. 205/50 R15
Old 9th May 2006, 16:28   #8
Smile
2. 195/60 R14
3. 195/55 R15
4. 205/50 R15
Yea, The car has 205/50 R15 and has 80k kms on it :-)
Old 10th May 2006, 14:12   #9
revharder's Avatar
Thanked: 49 Times
besides improving on tyres and all, try to change your style of braking!
use engine braking and start pumping that pedal!
revharder is offline   Reply With Quote
Old 10th May 2006, 14:32   #10
killjoy's Avatar
Thanked: 191 Times
try the kbx brake pads, helps to a certain extent.
killjoy is offline   Reply With Quote
Old 10th May 2006, 19:33   #11
ECM
ECM's Avatar
Thanked: 9 Times
or
*thanks*
I never had any prob in braking my Baleno till now.Why don't you take a ride in other car i.e Baleno and see the difference,Do u get "heeeeeeeeees" sound while braking in front tyres?Put a hand break and jack up the car and see if u can turn tyres or put a car on a small slope with hand break on and see if it skids or not,if it skids it means you have to change rear wheel liners.When last you changed your pads(front and rear)?If u get that "heeeeeeeees"sound get new disc for front drums.Poor maintainance of not changing pads on time results in disc loss.
One suggestion when ever someone put a quary kindly write how much is the odo reading,model,car make etc.. so it will be easier to reply to his/her query.
ECM is offline   Reply With Quote
Old 12th May 2006, 17:47   #12
Smile :-)
heehee... thats what I have been doing now. I pump it couple times before I fully apply the brakes :-)
Old 12th May 2006, 17:55   #13
naveendhyani's Avatar
Thanked: 7 Times
BTW how much do the baleno brake pads cost including labour charges?
naveendhyani is offline   Reply With Quote
Old 12th May 2006, 17:55   #14
Thumbs up everythings new
Originally Posted by ECM
I never had any prob in braking my Baleno till now.Why don't you take a ride in other car i.e Baleno and see the difference,Do u get "heeeeeeeeees" ........
Actually the car has been slightly modified for the power so, it has more power than the normal baleno but I am trying to improve the brakes which actually will go in sync with the power of the car. :-)
Can we fit disc brakes to the rear too?? heehee
*thanks*
Old 12th May 2006, 18:33   #15
kb100's Avatar
Hi
Please contact TURBO INDIA ... he has brake kits for all vehicles... You could actually do an all disc set up too if you so desire..
kb100 is offline   Reply With Quote
Baleno - Brakes shadyrulez Technical Stuff 43 4th August 2015 10:33
How to improve lower end torque.. DRC Technical Stuff 19 10th July 2012 16:50
How does high octane fuel improve performance? DCEite Technical Stuff 130 21st May 2011 01:08
Retarder in Volvo B7R buses (air-brakes / jake brakes) sfilinto Commercial Vehicles 12 30th March 2010 00:55
Improve Indigo Ride bhaskarcse Modifications & Accessories 6 14th May 2004 08:27
