Old 19th October 2011, 15:01   #16
Thanked: 110 Times
Default Re: Issue with Palio 1.6 GTX Engine oil levels dropping
Are you seeing any blue smoke or oil burning smell from the exhaust?. Also check for sticky soot from the exhaust tip. Other best way to check for oil entering into the combustion chamber by reading the spark plugs. Check all these and let us know. 86K is nothing for fiat engines unless proper care is not given. When was the timing belt changed.
Vijay
vijaycool is offline   (1) Thanks Reply With Quote
Old 19th October 2011, 15:23   #17
planet_rocker's Avatar
Thanked: 365 Times
is the engine over heating?
if i am not wrong, another way to check engine oil loss is to see the condition of the engine coolant in the reservoir. if the coolant is creamy / frothy - there could be a problem with the head gasket.
planet_rocker is online now   Reply With Quote
Old 19th October 2011, 18:31   #18
kicha's Avatar
Hi Vijay/Planet_rocker,
Thanks for the reply.
Yes I verified the exhaust tip, no soot-oil residue present.Timing belt was changed 7 months back.Coolant levels are ok at the moment and not creamy/frothy as you had mentioned.Also, on revving the engine, dont see black/blue smoke either.
Need to check the plugs now, will do that probably next week.Just topped up the engine oil now, a long drive (1000km+) is due in 2 weeks time and may be, will check the oil levels then.
kicha is offline   Reply With Quote
Old 19th October 2011, 21:33   #19
dhanushs's Avatar
Thanked: 4,054 Times
Well, oil levels will be different when checked on a hot engine and a cold engine.
If that too is ruled out, could you please elaborate on how much oil is used up in say.. 500 kms ?
Old 19th October 2011, 22:28   #20
SS-Traveller's Avatar
Thanked: 10,775 Times
...engine oil levels are dropping within 500 Kms of driving.Checked for leaks and found none.Daily drive is around 10 kms, and the car is well maintained.Not sure if this is a known issue with 1.6, any ideas, what could be the cause?Experts here, your opinions pls
You might find more information in this post.
Performance twins on a Budget- Palio 1.6 GTX Vs Ikon 1.6 (Edit - Its a Palio 1.6 GTX) Makesh Hatchbacks 48 9th October 2012 01:34
The GTX arriveth. Palio 1.6 GTX thedragula Long-Term Ownership Reviews 36 12th June 2011 12:40
PALIO 1.6 GTX 2001-1.5 LAKHS?? ( calling all palio GTX owners ) karizma_devil Hatchbacks 18 28th December 2008 13:04
Engine Oil Query For Palio GTX Dark Knight Technical Stuff 13 7th February 2007 19:07
coolant guzzling Esteem chandan Technical Stuff 10 21st July 2005 12:28
