Old 25th January 2013, 23:03   #31
Thanked: 716 Times
Default Re: Letting your Car's fuel tank run empty? Drop the habit!
Originally Posted by vnabhi View Post
As Fiesta owners know, the DTE is a wee bit erratic. But the low fuel light comes on only when the reading is 80 kms on the DTE..
This method is a bit troublesome, especially on a highway, where we get higher mileages, so DTE and fuel warning lamp will come up when there's very little fuel in the tank.
This happened once for me, when DTE started to drop rapidly from 80 to 70 and to 50 within seconds as the car was on the move.
In my old car(Uno D) the warning led came up based on fuel, it was so accurate so that FE calculations was spot on!
ramzsys is offline   Reply With Quote
Old 25th January 2013, 23:16   #32
Thanked: 21 Times
Holy Cow! I am in splits reading this. How on earth do you save money by filling fuel when its almost but finished? What fuel has gone in is only yours, whether you burn it till the last drop or you tank up before you run dry, unless you rent out your car which no self-respecting team-bhpian is likely to. Ah, may be you are talking about saving interest cost of keeping 200 bucks in the Bank for 2 days extra during which you might extract few more kms out of the last few drops of fuel left in the tank. Come on, own a car? Fill it up. Cant fill it up? Sell it! What if there's a personal emergency at night and your fuel tank is almost dry and no bunk is open, or even if its open then it has run dry because the 'conservative' pump owner wanted to sell the last drop till he indented fresh stock!
Least I care, because I top up much sooner, but I have also read in the car manual that running dry conks off the catalytic converter.
anujatwork is offline   Reply With Quote
Old 25th January 2013, 23:17   #33
Thanked: 9,021 Times
I always fill up completely and run it down to within the last 0.5 litre. It's a bit of game. My wife hates it. If you know your car reasonable well, it's easy to do.
With modern fuel, residuals are minimal, and all fuel systems have filters. Running the tank empty and thus stalling the engine, is embarrassing, but not necessarily a big deal. Make sure you know what to do, and whether your fuel system needs priming or de-airing after the tank has run dry. By and large petrol engines will self prime, but on diesels you often need to prime manually.
Also, starting endless to try and prime the system might have some wear and tear on the high pressure pump. It's the petrol/diesel itself that provides lubrication for the plungers. No fuel, no lubrication. Hence, make sure what the procedure is for you car.
Petrol can and does go stale. Modern Petrol with ethanol are particularly prone to quality degradation if left for long periods. Having said that, I've only experienced it once. Currently I have three cars in storage in the Netherlands that get very little usage. I drove all three of them during a recent visit to my home country. One of them hadn't been driven for more than a year. Fired up fine, nothing wrong with the petrol.
On the other hand, my little power lawn mower in the US, would refuse to start on fuel older than 6-7 weeks consistently. Only way to get it going was to clean out the carburetor and put fresh fuel in.
If your car isn't going to be used for an extended period of time, most would advise to fill your tank to the brim. Reason is that with the tank full, there is less room for air and potential condensation occurring. So I always fill up my cars before they go back in storage.
Jeroen
Jeroen is offline   (1) Thanks Reply With Quote
How do you refill your fuel tank? What is the best practice? souravbasu Technical Stuff 132 18th April 2017 22:34
Excessive Honking? Here's a "bleep" to kick the habit GTO Modifications & Accessories 38 12th June 2013 16:25
Is there a drop in FE in your vehicle after BS IV fuel ? raghosh The Indian Car Scene 39 19th July 2010 12:18
What the the most difficult habit you kicked and how? download2live Shifting gears 39 8th June 2010 13:59
fuel tank 42lt.- fuel in-44lt. v.tec Technical Stuff 55 29th August 2006 20:50
