Old 8th February 2013, 15:17   #16
comfortablynumb's Avatar
Thanked: 1,029 Times
Default Re: How to repair a dead horn?
Originally Posted by ketantendulkar View Post
Thanks to @Automaton I was able to get it repaired at the shop mentioned below for Rs.200 (for two horns which he said were 'original' and of good quality - the brand said MICA or MICRA).
Hi Ketan,
Where exactly on Shankarsheth road is this horn repair shop[s]?
Cheers,
Vikram
comfortablynumb is offline   Reply With Quote
Old 8th February 2013, 15:21   #17
Automaton's Avatar
Thanked: 181 Times
My Skoda Octavia's dual horn had reduced to a feeble single meek peep just a few weeks ago.
I visited Team-BHP after a blue moon and this was listed right at the top in the "hot threads" - god bless Team-BHP!!
Glad that is sorted. Always happy whenever someone makes the Part Replacer (a.k.a. Service Engineer) at the dealership redundant.
Horn OK
After Swargate, on SS Road, look for the first crossroad. Its a small shop on the right hand side with horns hanging outside. Just before the Tyre dealer/garage.
Or if you are coming from the other side, Handloom House, then, its ahead of the Petrol Pump, and the tyre dealer, on the left.
Last edited by Automaton : 8th February 2013 at 15:26. Reason: Adding info for @comfortablynumb
Automaton is offline   (2) Thanks Reply With Quote
Old 29th June 2013, 00:53   #18
StrangeWizard's Avatar
Thanked: 229 Times
Today I was waiting in line at a petrol pump where a lady driving with an L sign was about to bang my car so I honked for about 10 secs at a stretch.
Now after this happened I pressed the horn pad and to my horror the horn wasn't sounding at all !
I tried for sometime but I couldn't get any sound.
Now how do I find out whether the problem is with the horn or the horn pad?
I have a Seger VW type horn which I'm using since june '12.
StrangeWizard is offline   Reply With Quote
Old 29th June 2013, 01:13   #19
greenhorn's Avatar
Thanked: 1,519 Times
possiblity of a stuck relay as well. Check if there is a faint ticking sound coming from the fusebox when you press the horn pad. if not, busted relay. Chances of the horn pad dying are less
greenhorn is offline   (1) Thanks Reply With Quote
Old 29th June 2013, 18:12   #20
Gerardfdz's Avatar
Thanked: 60 Times
Had a similar problem with my Zen. Finally found that the relay was touching the body and would get stuck. Bent the bracket -since then no problem.
Gerardfdz is offline   Reply With Quote
Old 30th June 2013, 00:45   #21
Thanked: 229 Times
Thanks guys. I got it checked today morning and it was a blown fuse.
Changed the fuse and now the horn is working fine
Body Repair & Painting, Glass Repair, Detailing etc. - Trend Automobiles (Bangalore) decode Bangalore 291 16th June 2018 10:59
Using Reverse Horn. Good or Bad? narasimha raju The Indian Car Scene 132 9th March 2015 09:22
Air-horn installation for new Honda Accord. Challenger Modifications & Accessories 21 1st June 2006 19:14
Turn your headlights off and only use the horn! Rtech Street Experiences 37 13th April 2006 16:04
