Closed Thread
Old 27th January 2013, 19:14   #1
Default Use Cluch or Brake
When I travel to my work , there are stretches of clear roads with signals in between them.
Which of the following is good for the car's health and fuel economy?
When I am Driving at about 60KPH and see a STOP signal about 500 meters ahead, I press the clutch bring the car to neural and let it go along the momentum till it reaches the signal and then hit the brakes.
Is this a good practice ? or should I keep on cruising at the same speed and hit the brakes near the signal to halt or should I release the accelerator pedal shift to lower gear and then press the brakes near the signal.
Carafooz is offline
Old 27th January 2013, 20:56   #2
comfortablynumb's Avatar
Thanked: 1,028 Times
Default Re: Use Cluch or Brake
Originally Posted by Carafooz View Post
When I travel to my work , there are stretches of clear roads with signals in between them.Which of the following is good for the car's health and fuel economy?.
Please check this thread: http://www.team-bhp.com/forum/techni...ing-right.html (Shifting to Neutral or Pressing the Clutch when Braking - Is this right?)
Another thread on a related topic: http://www.team-bhp.com/forum/techni...ar-brakes.html (The best way to use the clutch, gear and brakes)
Cheers,
Vikram
comfortablynumb is offline   (2) Thanks
Old 27th January 2013, 22:20   #3
anekho's Avatar
Thanked: 661 Times
The highlighted part.
You're driving along. You see the red light a fair distance away. You let go of the accelerator. As you get closer, you downshift (1 or even 2 gears). The car slows down even more.
By now if you're lucky the light has turned, and you can proceed without stopping at all. If not, brake. Finally dump the clutch to stop the engine from stalling.
Never cruise around in neutral. You should always be in gear. Cruising in neutral = no control in case you need to perform a sudden maneuver.
anekho is offline   (1) Thanks
Old 27th January 2013, 23:44   #4
Octane_Power's Avatar
Thanked: 414 Times
In addition to what anekho has stated if you are in neutral your braking effect will also reduce substantially.
As you have stated if you are say 500 metres away from the signal, and at about 80 or 60kmph; then you may keep your foot lightly on the pedal and brake from say about 300 metres. Also while slowing down you may just press the clutch only when you are about to stall, before that pressing the clutch isn't required.
Slight OT - It is a very common practice(and I really hate it) with bike riders and car drivers to press the clutch as soon as they stop accelerating. I mean, why is it needed in the first place? Let the car roll on its own. It wont come to a stop if you aren't pressing any pedal. Also, how would you control your braking if you need to stop abruptly for a pedestrian or an errant driver? The Clutch should be used very judiciously.
-Bhargav
Octane_Power is offline   (1) Thanks
Old 27th January 2013, 23:46   #5
Eddy's Avatar
Thanked: 5,074 Times
Note from Support : Please continue in the threads suggested by comfortablynumb (post # 2). Thanks.
Eddy is offline
Closed Thread
Hand Brake - Do you use it everytime ? mithun Technical Stuff 111 24th June 2015 10:07
1964 W110 mercedes benz cluch problem msaudf Technical Stuff 4 31st October 2013 17:32
help me choose for 60% highway use 40% city use nawabnabeel SUVs, MUVs & 4x4s 43 7th April 2009 17:48
Only brake OR clutch+brake swiftcrazy Technical Stuff 8 10th July 2007 23:19
Which is the right Sequence Clutch-Brake Or Brake-Clutch ankura12 Technical Stuff 2 9th July 2007 10:02
