Old 7th January 2016, 12:42   #301
Thanked: 460 Times
Default Re: Why you must practice the "Idling Rule" with Turbo-Charged Cars
You can try lot of things, some years back a GMC Duramax V8 diesel engine had a run away when hooked to a dynamometer. With only one bank burning oil. and other off the engine which is supposed to be 397 BHP was generating over 1000 BHP, as dynamometer meter could not measure more than that. A FWD or 4WD may stop with brakes applied, but we don't know how much the engine is generating, and weather brakes, will be able to hold, or tyres grip against the wall, or everything has to be done together.
Whatever it is it is better to stop the engine before pieces of valves, and turbo shoot out like sharpnel through the exhaust, or worse still the cylinderhead disintegrates and kills people.
Rahul
Rahul Rao is offline   (1) Thanks Reply With Quote
Old 7th January 2016, 13:22   #302
Thanked: 370 Times
Rahul
Yes, these factors too need to be considered.
The engine can also be stopped by opening the engine hood and blocking the air intake with a big piece of cloth, properly held in place.
Rahul Bhalgat is offline   Reply With Quote
Old 25th January 2016, 09:31   #303
Cowardly Lion's Avatar
Thanked: 41 Times
Default Warming up your car
This article recommends against warming your car through idling and recommends driving straight away. Experts?
http://www.popularmechanics.com/cars...-harms-engine/
Cowardly Lion is offline   (2) Thanks Reply With Quote
Old 25th January 2016, 09:43   #304
sidzz's Avatar
Thanked: 90 Times
Default Re: Warming up your car
Well, the explanation sounds convincing.
In my case, I always try to warm the engine up for a minute and then start off in the morning.
Gears shifts and the ride as a whole is smooth comparatively when the engine is at optimum temperature.
sidzz is offline   Reply With Quote
Old 25th January 2016, 09:45   #305
Sheel's Avatar
Thanked: 3,934 Times
I have no clue as to what the article is trying to say, but I do idle as my car is equipped with a turbo, as most cars are. Related thread
Secondly, when ever I fire the car or my bike, it takes at least 10 seconds for the car to get back to its idle rpm, at least in winters, so I don't over do it but yes, I do idle while starting & while parking the car.
I don't idle a NA engine while shutting down. But sometimes the ECU is over enthusiastic varying the revs [have seen this in a Nano] so let it settle down a bit.
Sheel is offline   (1) Thanks Reply With Quote
Old 25th January 2016, 10:40   #306
Divya Sharan's Avatar
Thanked: 459 Times
Be it summer or winter, I idle my car as well as bike (both NA) for 45-60 seconds in the morning and take the first 4-5 km steady with no outbursts at all. At night/parking time, I do the idling thingy again for 30 odd seconds on both.
I guess, the author of the post meant to say that prolonged idling is bad.
Divya Sharan is offline   Reply With Quote
Old 25th January 2016, 10:59   #307
Thanked: 319 Times
Isn't it better to drive slowly in the first minute (without turbo), rather than wasting fuel for idling 30 seconds?
jinojohnt is offline   Reply With Quote
Old 25th January 2016, 11:14   #308
mxh
mxh's Avatar
Thanked: 128 Times
I generally enter the car, start the engine, wear my belt, turn on the stereo and AC and drive away. I guess it's around 30s? I remember reading an article that also talked of the additional pollution and wasted gas caused due to so many cars idling when they start up. I think I read somewhere in the Honda manual that no idling is required, get in the car and drive away.
mxh is offline   Reply With Quote
Old 25th January 2016, 11:23   #309
Gansan's Avatar
Thanked: 841 Times
"The best thing is to start your car, take a minute to knock the ice off your Windows, and drive". ( Paragraph 5, last line of the article).
That is a minute of idling right there, which is what most people do anyway, or at the most two minutes. I don't catch the point they are trying to make, unless they mean extended idling during severe winters.
Old 25th January 2016, 12:01   #310
Thanked: 36 Times
In US, I never idled my Civic. Start and go, and drove it for more than 130,000 miles and never had any issue. Of course, the first few minutes would anyway be sedate driving, but there was no reason to idle, and the user manual too didn't mention that idling was required.
sanchari is offline   Reply With Quote
Old 25th January 2016, 12:44   #311
rrsteer's Avatar
Thanked: 739 Times
I think its best to refer to your car manual. The advice given there should be your gospel truth and indisputable.
For e.g the Innova car manual advises against idle and asks the driver to start moving immediately after firing the engine, though keeping sure that the rpm is not too high or too low within the different gears.
This is what I have been doing, I keep an eye on the rpm needle, and as soon as I feel the engine is sufficiently warmed up, I drive normally. But I have never idled the Innova.
And i have pointed this out to so many taxi drivers and Innova owners not to idle when starting the engine, but most don't agree. Its contrary to their reasoning.
rrsteer is offline   Reply With Quote
Old 25th January 2016, 13:47   #312
I have a Dec-2014 Polo GT Tdi which is used sparingly (parked in the stilt) and till date it has clocked 1283 Kms. I have this practice of idling the car (every 10-15 days) till temperature reaches 90 degrees. Is this ok or should I discontinue this
Night Rider is offline   Reply With Quote
Old 25th January 2016, 13:49   #313
jkdas's Avatar
Thanked: 1,261 Times
http://www.team-bhp.com/forum/techni...ing-off-2.html (Warming Up / Idling Engine before starting off...)
http://www.team-bhp.com/forum/techni...rged-cars.html (Why you must practice the "Idling Rule" with Turbo-Charged Cars)
Old 23rd March 2016, 08:53   #314
Can someone comment on the New Vento's TSI TurboCharger, whether its Oil Cooled or Water Cooled?
meetzap is offline   Reply With Quote
Old 26th March 2016, 01:02   #315
firstguri's Avatar
Thanked: 295 Times
Well you need to stop it. The technical argument given is that if you let your car warm up on idle then the engine spends more time in the cold zone. However if you start driving after starting, albeit mildly, then the engine warms up faster and consequently the engine spends less time in the cold zone.
The main point is that there is always an unfavourable condition when the engine is started after a considerable time. So the aim is to reduce the damage to minimum.
A lot of manufacturer manuals these days state clearly to start driving off straight away. If the makers are telling you that then I would like to believe them.
firstguri is offline   Reply With Quote
10 Engine Idling "did you knows" EDIT: Myths & Facts added! amit Technical Stuff 32 16th November 2013 20:38
The 20:20:20 Rule - Practice it and preserve your Eyesight GTO Shifting gears 27 9th November 2013 16:14
