Old 10th May 2006, 19:43   #1
ECM
ECM's Avatar
Thanked: 9 Times
Default How important this small relay is.......views invited
A small relay for Fuel pump is fitted in every MPFI cars i.e recent ones and most of them are fitted with ecms.NOw see what happened to my friend when his fuel pump went off and.....
He had a horrible experence in his car and he saved well.what happened is suddenly his engine went off resulting in almost a zero brake and hard steering(power break aur power steering ka kamal !!)This happened on a high traffic highway and he had to stop his car by using a hand break though he almost collided with a light pole on the side of the road.Not much damage to his car but this can happen to any of us and perhaps no car markets as per my small knowledge thought about the solution if fuel pump or it relay fails and car go mad after wards.Input plz.
ECM is offline   Reply With Quote
Old 10th May 2006, 19:56   #2
autopsyche's Avatar
Thanked: 15 Times
Its not just about the fuel pump, say for instance the ignition module or the ecm goes youll end up with the same result. You never know with these electronic items, and im sure its no easy feat to make them failproof.
autopsyche is offline   Reply With Quote
Old 10th May 2006, 21:45   #3
DRC
DRC's Avatar
Thanked: 48 Times
Lets face it .
Quite a few components are critical.
Is n't brake itself critical? all it takes for a failure is a rupture in the brake hose right..
DRC is online now   Reply With Quote
Old 10th May 2006, 21:59   #4
speed0mania's Avatar
Exclamation
true! i faced this problem especially in the ikon !! i mean the brakes become nonexistant if the engine goes off!! that is seriously scary and dangerous!!
i mean the power steering going off is still handlable but the brakes giving way is seriously scary mann!!
speed0mania is offline   Reply With Quote
Old 10th May 2006, 22:32   #5
ECM
ECM's Avatar
Thanked: 9 Times
Exactly and thats the point of discussion.No matter brake fails or driver get a heart attack while driving but if something l mentioned happens we are in soup!No alternative!
Old 10th May 2006, 22:46   #6
drifter's Avatar
In such a situation, the braking power will obviously reduce considerably. But the safest way to get the car to a standstill is to try to press the brake pedal as firmly as possible, while keeping the car in gear. A non-firing engine will provide more than adequate engine braking. Using the clutch to control the amount of engine braking.
Drifter
drifter is offline   Reply With Quote
Views invited from all SUV experts & women drivers Sugeeta SUVs, MUVs & 4x4s 37 8th March 2011 14:07
Suggestions invited for ICE upgrade for Octavia vRS - currently stock ilovefls In-Car Entertainment 24 20th November 2008 14:06
Spark, Santro, i10 or others - FE important - 1500kms/month, Rear seat not important monishdesign Hatchbacks 7 11th March 2008 12:27
My Long journy itinerary from Pune to costal Karnataka - Suggestions/comments invited KVS Route / Travel Queries 8 27th December 2007 21:11
You are invited! Harrie Shifting gears 73 24th December 2005 10:40
