Old 11th May 2006, 02:11   #1
Default corsa problem
just wanted to ask you guys what exactly is the problem with my corsa . suddenly when im in neutral or press the clutch...the rpm keeps on reducing and goin up the car keeps on vibrating and then even when i try to go ahead . i feel something is pulling my car back. please help
racingismylife is offline   Reply With Quote
Old 11th May 2006, 08:25   #2
ECM
ECM's Avatar
What I gathered is,
*WHen you press your clutch rpm goes down
and
When you free it and ready to go it vibrates!
Am I right?Why dont you tell me one thing?Your odo reading!Do u have a habit to keep pressing the cluth too often while traveling?Plz check the "free gap"of clutch cable and if all fails I suspect a faulty pressure plate and a clutch plate.
ECM is offline   Reply With Quote
Old 11th May 2006, 08:58   #3
karthik247's Avatar
Thanked: 16 Times
I think i should be something to do with the clutch cuz this also causes the revs to go up when the clutch is used..
karthik247 is offline   Reply With Quote
Old 14th September 2006, 01:27   #4
iam too having the same problem with my corsa.
did you take the car to the service centre. what did they say?
dhir_d is offline   Reply With Quote
Old 14th September 2006, 09:06   #5
Pankaj401's Avatar
From what I understood you might need to get the injectors cleaned. It could be bad/severed wiring or bad O2/EGR sensor also.
Pankaj401 is offline   Reply With Quote
Opel Corsa Sail 1.4 2004 model ignition problem ranabirghosh Technical Stuff 14 12th December 2011 21:21
Opel Corsa 1.4 Petrol : Weird overheating problem Klub Class Technical Stuff 15 10th November 2011 22:30
Opel Corsa Sail 1.4 Engine heating problem. Please Help! stevie Technical Stuff 15 20th January 2010 00:59
Overheating problem in corsa... gkrishn Technical Stuff 2 14th March 2007 10:52
Opel Corsa 1.4 GSi/ Corsa Sail 1.4 dsrins Hatchbacks 2 8th August 2006 17:47
